I have News – Manjaro as my homepage but I saw that the news topics are from last year.
What do you use for Manjaro news?
Depending upon what kind of news you’re after, the Update Announcements are worthwhile monitoring.
Additionally, you can add .rss to the end of topic URLs to create a feed source that can be added to most News/Feed applications. Try it. ![]()
Some examples from another topic.
Welcome to the forum! ![]()
Truth be told, you’ll always get the most recent news here on the forum, and specifically, from the Announcements category — that’s a clickable link, by the way. ![]()
As a new member, you may especially want to subscribe to notifications for the Stable Updates category — or Testing Updates, or Unstable Updates, depending on what branch you’re on. Every bundled update, whether it’s for Manjaro Testing or Manjaro Stable, always comes accompanied by a dedicated announcement thread.
The first post of the thread contains the changes with regard to the previous bundled update.
The second post of the thread details the potential problems, and how to deal with them.
The announcement thread also always contains a poll (in the first post), and a summary of past issues (in the second post), for those who’ve skipped an update — which is not advised with a rolling-release distribution, but it does happen.
Bookmark https://forum.manjaro.org/latest, log in and check regularly and you’ll be informed of all updates, issues and news.
To get instantly notified of every update log in, go to ‘Categories’ >> ‘Announcements’, pick your branch, eg ‘Stable Updates’, hit the bell icon top right and pick ‘Watching first Post’.
This enables users on low/expensive data volume networks to deactivate pamac’s update checker (30Mb every 6h) and save around 5Gb a month.
I’ve just created a simple script that is launched by my backup script. It opens an announcement page when there are update news. It can also be launched from systemd or cron.
#!/bin/zsh
RSS="https://forum.manjaro.org/c/announcements/testing-updates/13.rss"
#RSS="https://forum.manjaro.org/c/announcements/stable-updates/12.rss"
FILE="$HOME/.cache/last_link_update.txt"
LINK=$(curl -s "$RSS" | sed -n 's:.*<link>\(.*\)</link>.*:\1:p' | sed -n '2p')
[[ -f "$FILE" && "$LINK" == "$(cat $FILE)" ]] && exit 0
XDG_RUNTIME_DIR=/run/user/$(id -u) notify-send -i face-smile "Updates News!"
xdg-open "$LINK" >/dev/null 2>&1 &!
echo "$LINK" > "$FILE"
Edit: added missing line.
@triam I hope you don’t mind, but I tested your script and it doesn’t actually write the last_link_update.txt so it always opens the page when run. It also allowed for curl errors to load the browser. The updated script, with error checking, is below.
#!/bin/zsh
# Define the source RSS feed and the cache file location
# Ensure the cache directory exists
mkdir -p "$(dirname "$FILE")"
# Fetch the latest link from the RSS feed
# The first <link> is to the category, the second is the latest post.
# 1. Exit if the LINK variable is empty (e.g., curl failed)
[[ -z "$LINK" ]] && exit 1
# 2. Exit if the cache file exists and its content matches the latest link
[[ -f "$FILE" && "$LINK" == "$(cat "$FILE")" ]] && exit 0
# If the script continues, the link is new. Send a notification and open it.
XDG_RUNTIME_DIR=/run/user/$(id -u) notify-send -i face-smile "Manjaro Updates!" "New testing update posted."
xdg-open "$LINK" &> /dev/null &
# 3. Save the new link to the cache file for the next check
exit 0
My bad. What I posted was only a part of the whole solution, and I missed one line. Thanks ![]()
When updates come, the Announcement thread. Otherwise from recent posts in the forum - everything shows up here.
Thank you all! I got the information I wanted. I will now also use that script.
I have been having some fun and modified the script to take a variable of (stable/testing/unstable) to select which announcement it looks for so I can run it on multiple machines with systemd. If no variable added then it defaults to stable. In case anyone is curious, here it is:
#!/bin/zsh
# 1. Set the branch based on the first command-line argument ($1)
# The asterisk (*) is a wildcard that acts as the default case.
case $1 in
testing)
BRANCH="testing"
unstable)
BRANCH="unstable"
RSS="https://forum.manjaro.org/c/announcements/unstable-updates/15.rss"
*) # Default to stable if the argument is "stable", empty, or anything else
BRANCH="stable"
esac
FILE="$HOME/.cache/last_link_update_${BRANCH}.txt"
# Exit if the LINK variable is empty (e.g., curl failed)
# Exit if the cache file exists and its content matches the latest link
# 2. Make the notification body dynamic using the $BRANCH variable
NOTIFY_BODY=$(echo "$LINK" | sed -E "s|.*/t/(.*)/[0-9]+$|\1|; s/^${BRANCH}-update-//i; s/([a-zA-Z])-([a-zA-Z])/\1 \2/g; s/([a-zA-Z])-([0-9])/\1 \2/g; s/([0-9])-([a-zA-Z])/\1 \2/g")
# 3. Make the notification title dynamic. ${BRANCH:u} capitalizes the first letter.
NOTIFY_TITLE="Manjaro ${BRANCH:u} Update!"
# Send the notification with the hint to make it persistent
XDG_RUNTIME_DIR=/run/user/$(id -u) notify-send -i manjaro -h boolean:transient:false "$NOTIFY_TITLE" "$NOTIFY_BODY"
# Open the link in the background
# Save the new link to the cache file for the next check
exit 0
@Kielcelaria
The script is pasted twice.
Thanks and fixed.
