I’ve notice that…there are two different way to install a same python package
example:
- pacman -S python-django
- pip install django
why there is two option & which method should use for install packages?
example:
Because Python made their own package manager for Python packages.
When installing packages using pip, it is recommended to use a virtual environment to prevent conflicts with system packages in
/usr. Alternatively,pip install --usercan be used to install packages into the user scheme instead of/usr.
