Before I start using linux63
For… reasons I decided to uninstall the 515 kernel, keep the 61 LTS as fallback and start using 6.3 as the daily kernel.
I have had these errors since installing Linux but never expereinced anything other than what might be connected to this, hibernation not working.
sudo dmesg -l 3
[    0.244535] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
[    0.244539] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[    0.253777] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
[    0.253779] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[    0.253781] ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20220331/dswload2-326)
[    0.253783] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[    6.981922] hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
I find no real substanse by searching the interweb about this.
Should I go on with the new kernel (still on 61 LTS here) or should I really try to solve this first?
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=700d034d-b99a-482b-880b-9060acf3a6b3 rw rootflags=subvol=@
    nvidia_drm.modeset=1 quiet splash
    resume=UUID=5ae8fbf5-a704-41ea-be6d-bf26b38325ed udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: X670 AORUS ELITE AX v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F9b
    date: 06/01/2023
  System RAM: available: 31.09 GiB used: 4.89 GiB (15.7%)
  Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3472 high: 5412 min/max: 3000/5733 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4700 2: 3000
    3: 3000 4: 4700 5: 3000 6: 4700 7: 4700 8: 3000 9: 3000 10: 3000 11: 3000
    12: 3000 13: 3000 14: 3000 15: 3000 16: 3000 17: 3000 18: 3000 19: 3426
    20: 3000 21: 4700 22: 5412 23: 3000 24: 3000 bogomips: 225243
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
    gfni ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku
    pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
    sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: eVga.com. driver: nvidia
    v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2204 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
    s-diag: 693mm (27.28")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Asus VX279
    serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2
    size: 621x341mm (24.45x13.43") diag: 690mm (27.2") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
    3090/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
    bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
  IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp15s0 state: down mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:5 chip-ID: 0e8d:0616
  Local Storage: total: 4.09 TiB used: 1.49 TiB (36.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-1: / raw-size: 122 GiB size: 122 GiB (100.00%) used: 60.26 GiB (49.4%)
    fs: btrfs dev: /dev/sda7 maj-min: 8:7 label: N/A
    uuid: 700d034d-b99a-482b-880b-9060acf3a6b3
    used: 292 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: AC73-C072
  ID-3: /home raw-size: 104.53 GiB size: 104.53 GiB (100.00%)
    used: 39.93 GiB (38.2%) fs: btrfs dev: /dev/sda8 maj-min: 8:8 label: N/A
    uuid: 2a875645-5701-4450-bd08-adf1f966a07c
  ID-4: /media/diverse raw-size: N/A size: 3.56 TiB used: 1.77 TiB (49.7%)
    fs: cifs dev: /dev/diverse
  ID-5: /media/fil-fitt raw-size: 2.72 TiB size: 2.72 TiB (100.00%)
    used: 1.26 TiB (46.3%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
    label: Lilla Fil-fitt disken uuid: CE8C0EC38C0EA655
  ID-6: /media/games raw-size: 384 GiB size: 376.91 GiB (98.15%)
    used: 136 GiB (36.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: Games uuid: ccfef3ee-65e0-45e4-aac2-4604ad2e696d
  ID-7: /var/cache raw-size: 122 GiB size: 122 GiB (100.00%)
    used: 60.26 GiB (49.4%) fs: btrfs dev: /dev/sda7 maj-min: 8:7 label: N/A
  ID-8: /var/log raw-size: 122 GiB size: 122 GiB (100.00%)
  ID-1: swap-1 type: partition size: 38 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 5ae8fbf5-a704-41ea-be6d-bf26b38325ed
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 289 GiB fs: ntfs label: Games
    uuid: 68A4C531A4C50294
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 258.5 GiB fs: ext4 label: backup
    uuid: 2b1e42bb-fe37-4fa1-991e-aab694b6b16f
  ID-4: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: WIN-BOOT
    uuid: 5483-0EFB
  ID-5: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sda3 maj-min: 8:3 size: 200 GiB fs: ntfs label: windows
    uuid: 6654845D5484323B
  ID-7: /dev/sda4 maj-min: 8:4 size: 633 MiB fs: ntfs label: windows-extra
    uuid: E61A49731A4941B3
  ID-8: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
  ID-9: /dev/sdb3 maj-min: 8:19 size: 10 GiB fs: ext4 label: MISO
    uuid: bd6e3634-1f2f-405f-87a1-5115bda000de
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-2:2 info: Areson USB Device type: mouse,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: e0ff:0005 class-ID: 0300
  Device-2: 3-3:3 info: Microsoft Sidewinder X4 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 045e:0768 class-ID: 0300
  Device-3: 3-6:4 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-4: 3-7:5 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-11: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 57.6 C mobo: N/A gpu: nvidia temp: 45 C
  Processes: 464 Uptime: 4h 45m wakeups: 0 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1484 libs: 396 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
  inxi: 3.3.27
Edit
When installing the 63 kernel I got ==> WARNING: Possibly missing firmware for module: 'xhci_pci' so I think the last error might be about that, and I don’t care. Seems to only be connected to the usb and they are working just fine for me.
Edit 2
I just realized, there is a F9 and an F10a firmware for my mobo released, could that be connected to this?
Long story short - could be a real error … could be benign … could just be ACPI table doesnt follow standards and its a warning that will never go away … might be fixed by newer kernel or newer BIOS/Firmware.
(something like nomodeset might make it go away … but cause other problems)
Sooooo, I just ignore and go with new kernel and see what happens?
Pretty much.
It may be addressed by newer kernel or BIOS/EFI/Firmware.
To take a snippet from somewhere else:
... Your BIOS has tables which are evaluated by Linux during boot.
Very often, those tables don't follow the ACPI standard, which nobody notices
on Windows because the Vendor who wrote the tables also supply their own
Windows driver which work with those tables.
However, there's no driver for Linux, so Linux has to somehow interpret even
buggy tables.
The ACPI BIOS you are seeing may or may not be harmful ...
As for the hibernation, you have to activate it.
lsblk -f # to see the UUID of the swap
sudo nano /etc/mkinitcpio.conf # insert resume hook at the end or before fsck
sudo mkinitcpio -p linux63
sudo nano /etc/default/grub # add kernel parameter resume=UUID=XXXXXXXXXXXXX
sudo update-grub
