SDDM has had trouble with applying certain settings, especially DPI, since Plasma 6.
There was a recent Plasma release that was supposed to fix it, but I dont think its in the repos yet.
Manjaro should configure SDDM to start under Wayland to fix the scaling problem, because scaling on X11 for multi monitors is broken and will never be fixed.
Plus set EnableHiDPI=true both under [X11] and [Wayland] sections in /etc/sddm.conf to fix HiDPI.
KDE is willing to take over SDDM under its wing to integrate it with Plasma, in the last 3 years they have been doing most of the work, but the discussion is not going anywhere with the main maintainer, and KDE didn’t want to create a hostile fork.
But I think they will do it, because Nate Graham started yesterday to list what could be added when SDDM is adopted by KDE.
For some reason the stance so far has been to try and undo things like wayland session by default.
So I might guess that setting wayland by default for SDDM will also be considered a no-go.
But I can confirm that here at least the following works for me
(kwin_wayland being used, hidpi and cursor size appears correct) /etc/sddm.conf.d/custom.conf
