[BCM4360] No Wifi Connections in Network Connections
(Mod-edit: Topic title length)
No Wifi Connection in Network Connections; No Wifi Networks; Using BCM4360 Wireless Network Adapter
I am running Manjaro (kernel 5.9.11-3) with a Broadcom BCM4360 network adapter.
I read a few posts on the forum for people with similar issues, but cannot seem to get my wireless network adapter working.
The inxi -Fxxn command produces the following:
System:    Host: matt-linux Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASRock model: Z490 Phantom Gaming-ITX/TB3
           serial: <superuser/root required> UEFI: American Megatrends v: P1.40 date: 06/08/2020
Battery:   Device-1: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
           serial: e7:c1:cf:0e:0c:8b charge: 100% (should be ignored) status: Discharging
CPU:       Info: 8-Core model: Intel Core i7-10700K bits: 64 type: MT MCP arch: N/A
           L2 cache: 16.0 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 121639
           Speed: 800 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 802 12: 800 13: 800 14: 800 15: 800
           16: 800
Graphics:  Device-1: Intel vendor: ASRock driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9bc5
           Device-2: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASUSTeK
           driver: amdgpu v: kernel bus ID: 03:00.0 chip ID: 1002:731f
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati,intel
           unloaded: modesetting,radeon alternate: fbdev,vesa resolution: 2560x1440~60Hz s-dpi: 96
           OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0)
           v: 4.6 Mesa 20.2.3 direct render: Yes
Audio:     Device-1: Intel Comet Lake PCH cAVS vendor: ASRock driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:06c8
           Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 03:00.1
           chip ID: 1002:ab38
           Device-3: Logitech Logitech BRIO type: USB
           driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 2-6:2 chip ID: 046d:085e
           Sound Server: ALSA v: k5.9.11-3-MANJARO
Network:   Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel port: 3000
           bus ID: 3e:00.0 chip ID: 10ec:8125
           IF: enp62s0 state: up speed: 100 Mbps duplex: full mac: a8:a1:59:28:cc:16
           Device-2: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network Adapter
           vendor: Apple driver: N/A port: 3000 bus ID: 3f:00.0 chip ID: 14e4:43a0
Drives:    Local Storage: total: 4.89 TiB used: 9.09 GiB (0.2%)
           ID-1: /dev/nvme0n1 vendor: Seagate model: BarraCuda 510 SSD ZP500CM30001 size: 465.76 GiB
           speed: 31.6 Gb/s lanes: 4 serial: 7QK00JX4
           ID-2: /dev/nvme1n1 vendor: Seagate model: BarraCuda 510 SSD ZP500CM30001 size: 465.76 GiB
           speed: 31.6 Gb/s lanes: 4 serial: 7QK00RSL
           ID-3: /dev/sda vendor: Seagate model: BarraCuda 120 SSD ZA250CM10003 size: 232.89 GiB
           speed: 6.0 Gb/s serial: 7QT01YLH
           ID-4: /dev/sdb vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB speed: 6.0 Gb/s
           serial: ZFN3BKE5
           ID-5: /dev/sdc type: USB vendor: SanDisk model: Ultra size: 115.69 GiB
           serial: 4C530001301212121254
Partition: ID-1: / size: 194.35 GiB used: 9.09 GiB (4.7%) fs: ext4 dev: /dev/sda2
Swap:      ID-1: swap-1 type: partition size: 34.12 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/sda3
Sensors:   System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 44.0 C mem: 42.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info:      Processes: 340 Uptime: 1m Memory: 31.20 GiB used: 1.32 GiB (4.2%) Init: systemd v: 246
           Compilers: gcc: 10.2.0 Packages: pacman: 1228 Shell: Bash v: 5.0.18 running in: konsole
           inxi: 3.1.08
I tried following this forum post closely, which included blacklisting other Broadcom drivers and installing broadcom-wl-dkms.
When I tried installing the broadcom-wl-dkms module, it didn’t appear to install properly.
This is the output I get when running pacman:
[matt@matt-linux ~]$ sudo pacman -S broadcom-wl-dkms
[sudo] password for matt:
warning: downgrading package broadcom-wl-dkms (6.30.223.271-23 => 6.30.223.271-11)
resolving dependencies...
Packages (1) broadcom-wl-dkms-6.30.223.271-11
Total Installed Size:  7.61 MiB
Net Upgrade Size:      0.01 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring                                                          [##################################################] 100%
(1/1) checking package integrity                                                        [##################################################] 100%
(1/1) loading package files                                                             [##################################################] 100%
(1/1) checking for file conflicts                                                       [##################################################] 100%
(1/1) checking available disk space                                                     [##################################################] 100%
(1/1) Remove upgraded DKMS modules
==> Unable to remove module broadcom-wl/6.30.223.271 for kernel 4.14.209-1-MANJARO: Not found in dkms status output.
==> Unable to remove module broadcom-wl/6.30.223.271 for kernel 5.9.11-3-MANJARO: Not found in dkms status output.
(1/1) downgrading broadcom-wl-dkms                                                      [##################################################] 100%
To load the new module, run as root:
rmmod b43 b43legacy ssb bcm43xx brcm80211 brcmfmac brcmsmac bcma wl
modprobe wl
or just reboot the system.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Install DKMS modules
==> Unable to install module broadcom-wl/6.30.223.271 for kernel 4.14.209-1-MANJARO: Missing kernel modules tree.
==> Unable to install module broadcom-wl/6.30.223.271 for kernel 5.9.11-3-MANJARO: Missing kernel headers.
Any ideas on what I can do to resolve this and get my Broadcom network adapter working?
Is the broadcom-wl-dkms module the correct one I should be using?
Where did you get that 23 version from, the official stable repo has the 11 version that’s why it is trying to downgrade it.
I would suggest to start with removing that package first before trying to install it from official repo.
These speak for themselfs, you don’t have linux414-headers and linux59-headers installed.
Huh. I’m not sure where I got that module, but it must have been in the beginning trying to figure out this issue.
Anyway - your suggestion worked and I’m up and running.
I uninstalled the module, then re-ran sudo pacman -S broadcom-wl-dkms to install the correct module, and then rebooted.
It works fine now.
It was a long journey for me to solve this issue. This forum post was what ultimately got me there.
I am running a multiboot Hackintosh (macOS, Windows 10, Manjaro), and so I needed to use this Broadcom adapter to get full functionality on macOS.
Thank you for your help with the last mile.
