Hi !
I’m using Bauh for a long time.
I’ve seen challenges : there should not be as there is no match (some overlap sometimes).
Btw, I use Bauh on my Manjaros & on my Debians
First use : PWA !
Firefox dropped SSB support from FF85 on, Chromium is installing strange stuff with the PWA, the only almost clean one left is Epiphany.
But, much better is bauh !
pip3 install bauh
sudo pacman -S timeshift axel libappindicator-gtk2 libappindicator-gtk3 wget sqlite fuse2 fuse3 python-lxml python-beautifulsoup4
[Note] as @Yochanan says next, you can also install it from the comunity repos
sudo pacman -S bauh
Usage
For PWA, for instance install:
https:/web.marp.app (tool for presentations)
https:/wavemaker.card (tool for book writing)
You can find the apps by searching for “bauh” in your apps menu.
With bauh, you can also install stuff from
You can also manage your regular packages, flatpak, snap (eerk !)
(it’s slower than pamac for those)
