Hello,
I’m facing issues to start battle.net application. In general it needs around 3 application run attempts to proper launch it and and so I can play Starcraft 2. Unfortunately It also let a lot of things duplicated/triplicated/quadruplicated running in background. I already tried to reinstall almost everything but nothing fixed the issue that. I opened another thread related to this issue, but focused on battle.net reinstall issue / ProtonGE witch I was able to fix it by myself.
To improve feedback and to detect where the issue is (Lutris? Manjaro? Plasma? Wayland?,…) I was able to found Lutris LOG and I got all 4 logs according to each attempt. If other LOG are needed, let me know, I will try to get them.
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=69678a39-1940-48ee-8d02-88e765985137 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=b136d668-4460-4cf7-9211-93b9a5283ab3 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
Type: Desktop Mobo: N/A model: X99 serial: <superuser required>
UEFI: American Megatrends v: 5.11 date: 07/30/2021
RAM: total: 15.53 GiB used: 2.7 GiB (17.4%)
RAM Report:
Info: model: Intel Xeon E5-2640 v3 bits: 64 type: MT MCP arch: Haswell
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3F (63) stepping: 2
microcode: 0x49
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1198 high: 1200 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1197 3: 1198
4: 1198 5: 1199 6: 1198 7: 1199 8: 1199 9: 1198 10: 1199 11: 1198 12: 1197
13: 1198 14: 1198 15: 1198 16: 1198 bogomips: 83048
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc
cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep smx
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DVI-D-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
alternate: fbdev,vesa gpu: amdgpu display-ID: 0
Monitor-1: DVI-D-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 13.0.1 DRM 3.42
5.15.49-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 1.61 TiB (59.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 233010WD temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20PURZ-85GU6Y0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: MBR
ID-1: / raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
used: 100.16 GiB (22.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
label: LINUX uuid: 69678a39-1940-48ee-8d02-88e765985137
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
label: NO_LABEL uuid: CDC5-157E
ID-3: /home raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
ID-4: /home/<filter>/GAMES raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 38.03 GiB (8.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:2
label: GAMES uuid: 9467047a-a0d0-46ff-859d-67a1bfff2456
ID-5: /home/<filter>/HDD-2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.48 TiB (82.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: 2TB-EXT4
uuid: b9d4d0f9-d1ce-425d-8fe4-e2f830005289
ID-6: /var/cache raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
ID-7: /var/log raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5 label: swap
uuid: b136d668-4460-4cf7-9211-93b9a5283ab3
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-7:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2521 class-ID: 0301
Device-2: 3-8:3 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 28.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 202
Processes: 400 Uptime: 22m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1365 pacman: 1344 lib: 366 flatpak: 21 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
Moderator edit: Screenshots of terminal text removed
Please copy and paste the terminal output here. Do not post screenshots of text.
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to f…
omano
4 July 2022 09:27
3
I would have suggested to read comments on the Lutris page for Battlenet , but apparently they removed the comments. Check here docs/Battle.Net.md at master · lutris/docs · GitHub
This application is known to not work properly under WINE.
my bad, will do in this way next time.
I tried, the indications looks old and don’t match correctly Lutris settings, so is risky to proceed in that way, I tried also get some help in Lutris Discord without success, it mention some issues with KDE, so maybe is just about wait longer to see if any update fixes my issue in the next releases.
omano
4 July 2022 15:54
6
What did you try? Which indication looks old and doesn’t match Lutris settings? What issues are mentioned for KDE?
This indication does not match:
Sleeping Agent / issues with installing / updating
If you’re using an AMD GPU, try setting radeon_icd.x86_64.json in Lutris System preferences → System options → Vulkan ICD loader. Make sure to tick “Show advanced options”.
Regarding KDE
The installer window does not show up, installation is stuck
Usually it’s caused by missing wine dependencies, but sometimes it’s a result of an unknown bug in KDE. There are no known workarounds to this, so the only solution is to use another DE.
This is not directly related to my case, but sometimes when they fixing a issue, other can be created, so KDE is always suspected.
It simply won’t start
Try to change executable from Battle.net Launcher.exe to Battle.net.exe, and try again.
My Lutris is already pointing executable to Battle.net.exe by default, no action needed from my side.
omano
4 July 2022 18:26
8
It matches for me. Or you mean because it says Global Options instead of System Options , it doesn’t match? It is the only tab with the word Options , so worst case scenario, you check four tabs that don’t match, then find the good one. It is both in Lutris settings, and on the game properties too (not in Global Options, in System Options there, and there is one less tab so you could have checked too).
You tried the other way around?
If you successfully launches it (by the way don’t run multiple ones on top of one another when it doesn’t work, properly kill the remaining processes if that doesn’t close properly), maybe you can try to get into the settings and see if there are things you can toggle on/off to help. I don’t use that launcher so I don’t know. The doc I linked talk about thing you can do like clearing the AppData cache folder, disabling hardware acceleration, things like that. Maybe your prefix is corrupted too, or is missing things. Not sure how you created it.
Also maybe you can share logs at some point so maybe someone can see something, you have been told not to post images of text, that was implying that you repost your logs as text, we’re still waiting.
“radeon_icd.x86_64.json”
The above option is not available in my system. it’s a drop box menu option the the Vulkan ICD Loader.
The default option here is: AMD RADV open source (MESA: RADV)(default)
the second option is: Intel Open Source (MESA: ANV)
I will share the LOG again, unfortunately the ADMIN deleted all LOGS because they were posted by me using images, I will post as text soon.
omano
4 July 2022 18:48
10
Of course they did, it’s a big nono, for many reasons, only post an image for text in specific case where it is important to SEE the text for explanation (video issues, things like that), when you share text, you share it as text, using proper formatting with the </> button, that’s mandatory. Nobody wants to watch text, they want to be able to read it, copy it, search it, modify it, also the forum itselfs doesn’t benefit at all of images for text, it nullifies completely indexation of content, forum searches don’t bring relevant content, google doesn’t index relevant content… and so on, I’m sure there are many more reasons why not to post text as image.
I see the Lutris installer does many things (including downloading, installing, the shader cache for Overwatch game, and creating configs for this game… weird…), maybe it messes up some config files, or maybe it applies settings, and environment variables, that don’t work well with your system.
I may give it a try later, on my KDE installation to see what’s going on.
Below you can find the Lutris LOG I collect again, but different from the original post, this time the Battle.net successfully run at the 2nd attempt.
1st attempt - Fail
lutris-wrapper: Blizzard Battle.net
Started initial process 1522 from gamemoderun /home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/wine /home/lordsansui/Games/battlenet/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
Start monitoring process.
ERROR: ld.so: object 'libgamemodeauto.so.0' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
[2022-07-04 16:18:14.889] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-07-04 16:18:14.889] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/MangoHud.conf' [ not found ]
[2022-07-04 16:18:14.890] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-07-04 16:18:14.890] [MANGOHUD] [info] [config.cpp:117] parsing config: '/home/lordsansui/.config/MangoHud/MangoHud.conf'
[0704/161817.995:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
2nd attempt - Success
Started initial process 1894 from gamemoderun /home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/wine /home/lordsansui/Games/battlenet/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
fsync: warning: a previous shm file /wine-11bb4f-fsync was not properly removed
[2022-07-04 16:20:48.810] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-07-04 16:20:48.810] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/MangoHud.conf' [ not found ]
[2022-07-04 16:20:48.810] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-07-04 16:20:48.810] [MANGOHUD] [info] [config.cpp:117] parsing config: '/home/lordsansui/.config/MangoHud/MangoHud.conf'
[0704/162051.663:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0704/162052.316:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0704/162052.318:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
[0704/162052.481:ERROR:dxva_video_decode_accelerator_win.cc(1320)] DXVAVDA fatal error: Could not load msmpeg2vdec.dll: Module not found. (0x7E)
[0704/162053.183:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0704/162055.675:ERROR:angle_platform_impl.cc(40)] rx::SwapChain11::reset(615): Could not create additional swap chains or offscreen surfaces, HRESULT: 0x80070057
[0704/162055.676:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglCreateWindowSurface: Bad allocation.
[0704/162055.676:ERROR:gl_surface_egl.cc(1394)] eglCreateWindowSurface failed with error EGL_BAD_ALLOC
[0704/162055.676:ERROR:in_process_command_buffer.cc(450)] ContextResult::kSurfaceFailure: Failed to create surface.
I found the command below to kill and app running duplicated/triplicated/quadruplicated. But how to know witch one are part of the same process initiated from Lutris? for instance, the first attempt fail, so how can I identify the executable related to the Lutris process 1522 and close the correct ones?
Started initial process 1522 - Fatil
Started initial process 1894 - Success
$ killall Agent.exe Battle.net.exe wineserver
KDE System Monitor not even mention process number, maybe it will require terminal stuffs and a way to improve the command above.
I just updated my system for the newest version of Manjaro and tried again. The issue remains, and coincidentally, I run at the 2nd attempt but the logs are slightly different from previous ones.
1st attempt - Fail (after Manjaro update)
Started initial process 1592 from gamemoderun /home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/wine /home/lordsansui/Games/battlenet/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
[2022-07-04 17:15:10.790] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-07-04 17:15:10.790] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/MangoHud.conf' [ not found ]
[2022-07-04 17:15:10.790] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-07-04 17:15:10.790] [MANGOHUD] [info] [config.cpp:117] parsing config: '/home/lordsansui/.config/MangoHud/MangoHud.conf'
[0704/171513.932:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
2nd attempt - Success (after Manjaro update)
Started initial process 1901 from gamemoderun /home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/wine /home/lordsansui/Games/battlenet/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
[2022-07-04 17:16:28.397] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-07-04 17:16:28.397] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.local/share/lutris/runners/wine/lutris-GE-Proton7-16-x86_64/bin/MangoHud.conf' [ not found ]
[2022-07-04 17:16:28.397] [MANGOHUD] [info] [config.cpp:112] skipping config: '/home/lordsansui/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-07-04 17:16:28.397] [MANGOHUD] [info] [config.cpp:117] parsing config: '/home/lordsansui/.config/MangoHud/MangoHud.conf'
[0704/171631.274:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0704/171631.962:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0704/171631.964:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
[0704/171632.105:ERROR:dxva_video_decode_accelerator_win.cc(1320)] DXVAVDA fatal error: Could not load msmpeg2vdec.dll: Module not found. (0x7E)
[0704/171632.831:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0704/171635.935:ERROR:angle_platform_impl.cc(40)] rx::SwapChain11::reset(615): Could not create additional swap chains or offscreen surfaces, HRESULT: 0x80070057
[0704/171635.935:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglCreateWindowSurface: Bad allocation.
[0704/171635.935:ERROR:gl_surface_egl.cc(1394)] eglCreateWindowSurface failed with error EGL_BAD_ALLOC
[0704/171635.935:ERROR:in_process_command_buffer.cc(450)] ContextResult::kSurfaceFailure: Failed to create surface.
[0704/171636.620:ERROR:command_buffer_proxy_impl.cc(122)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.
Updated system info.
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
RAM: total: 15.53 GiB used: 3.75 GiB (24.1%)
RAM Report:
microcode: 0x49
Speed (MHz): avg: 2871 high: 2989 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2865 2: 2829 3: 2977
4: 2920 5: 2842 6: 2898 7: 2878 8: 2989 9: 2818 10: 2802 11: 2792 12: 2884
13: 2904 14: 2877 15: 2795 16: 2867 bogomips: 83047
xtopology xtpr
Type: l1tf
class-ID: 0300
5.15.50-1-MANJARO)
class-ID: 0403
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Local Storage: total: 2.73 TiB used: 1.66 TiB (60.7%)
used: 142.54 GiB (31.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 235
Processes: 393 Uptime: 8m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1366
pacman: 1345 lib: 366 flatpak: 21 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
I saw someone posting at Lutris Discord a reference to WINE dependencies, see the link below
Wine Dependencies
Some one of lib32 versions were not available in my current installation, I just installed all missing ones but the results is still the same.
omano
4 July 2022 21:58
15
I modified the install script to make it more basic, I can consistently open and close BattleNet without issue. Didn’t try a game though.
Here is the modified JSON I used. Basically I removed everything related to Overwatch, Heartstone, and all the configs it did to BattleNet and WINE. I also changed the WINE version to one I had installed from within Lutris lutris-7.1-x86_64 (no manual installation), and not a Proton one (Proton-GE is not meant to be run outside of Steam , this is why the maintainer of Proton-GE creates another version called Wine-GE to use outside of Steam, maybe this is part of the issue I don’t know).
Disable all the useless stuff like MangoHud, GameMode, to avoid adding a layer of potential issues when you troubleshoot.
All I can say is that I have no issue so far to launch BattleNet on KDE (I use Nvidia card though). And that is without all the tweaks meant to “make it work”.
You can try this install script, copy/paste to a new file, save as battlenet.json on your desktop or where you want, click ADD A GAME (the [+] button) in Lutris, select from local install script , and select the script file.
//EDIT: note that it can take up to 30 seconds to kill all processes when you close it on my side.
Thank you.
Definitely GameMode is part of the issue, I just disable it and and now battle.net open faster with less attempts, going to do some more tests also disabling MangoHud and once confirmed what is causing the issue I will mark your post as the solution.
Mangohud show no affect in the issue, while game mode was in fact cause soe issue, not only to open battle.met itself but also slowing a lot the shutdown process because the system needs to kill some duplicated process.
So I remove the Battle.net and installed it using the scrip you post, it improves little more, now it basically open in the 1st attempt and sometimes also it requires 2nd attempt. But now i do not open more then one process at time, i Ask Lutris to stop the 1st process before opening a new one.
The scrip you provided also, for any reason, increased a lot the Lutris LOG showing much more errors, but maybe those erros doesn’t affect Starcraft 2, don’t know about other games.
Started initial process 2774 from /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/bin/wine /home/lordsansui/Games/battlenet/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
fsync: warning: a previous shm file /wine-139182-fsync was not properly removed
[0710/151957.004:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0710/151957.879:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0710/151957.881:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
[0710/151958.028:ERROR:dxva_video_decode_accelerator_win.cc(1320)] DXVAVDA fatal error: Could not load msmpeg2vdec.dll: Module not found. (0x7E)
(wine:3097): GStreamer-WARNING **: 15:19:58.045: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstlegacyrawparse.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstlegacyrawparse.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.045: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofiltersbad.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofiltersbad.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.045: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmidi.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmidi.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.046: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioresample.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioresample.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.046: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideobox.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideobox.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.046: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsctp.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsctp.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.047: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioparsers.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioparsers.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.047: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfaceoverlay.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfaceoverlay.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.047: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstproxy.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstproxy.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.048: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsdpelem.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsdpelem.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.048: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstuvch264.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstuvch264.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.048: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstnetsim.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstnetsim.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.048: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoscale.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoscale.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.049: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvorbis.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvorbis.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.049: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstjp2kdecimator.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstjp2kdecimator.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.049: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstjpeg.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstjpeg.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.050: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstplayback.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstplayback.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.050: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstopus.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstopus.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.050: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstshm.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstshm.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.050: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstivtc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstivtc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.050: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsubenc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsubenc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.051: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstjpegformat.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstjpegformat.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.051: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmxf.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmxf.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.051: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsubenc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsubenc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.051: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiofxbad.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiofxbad.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.052: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsndfile.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsndfile.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.052: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstid3tag.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstid3tag.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.052: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfreeverb.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfreeverb.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.052: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcoreelements.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcoreelements.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.053: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvb.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvb.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.053: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstopusparse.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstopusparse.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.053: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfieldanalysis.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfieldanalysis.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.053: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsthls.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsthls.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.054: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstclosedcaption.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstclosedcaption.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.054: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstlibav.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstlibav.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.054: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiovisualizers.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiovisualizers.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.054: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstremovesilence.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstremovesilence.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.055: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstflxdec.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstflxdec.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.055: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfrei0r.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfrei0r.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.055: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstopenal.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstopenal.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.055: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoframe_audiolevel.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoframe_audiolevel.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.056: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstautoconvert.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstautoconvert.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.056: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstxingmux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstxingmux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.056: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstavi.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstavi.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.056: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstnvcodec.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstnvcodec.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.056: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdebugutilsbad.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdebugutilsbad.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.057: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstttmlsubs.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstttmlsubs.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.057: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsiren.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsiren.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.057: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideosignal.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideosignal.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.057: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsmooth.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsmooth.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.058: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstadder.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstadder.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.058: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsdemux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsdemux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.058: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiomixmatrix.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiomixmatrix.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.058: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsmux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsmux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.058: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdeinterlace.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdeinterlace.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.058: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstswitchbin.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstswitchbin.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.059: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstpcapparse.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstpcapparse.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.059: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmenc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmenc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.059: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvmnc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvmnc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.059: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcoloreffects.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcoloreffects.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.059: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstflv.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstflv.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.060: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsty4mdec.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsty4mdec.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.060: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstogg.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstogg.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.060: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdlpcmdec.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdlpcmdec.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.060: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttheora.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttheora.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.061: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcoretracers.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcoretracers.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.061: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrtponvif.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrtponvif.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.061: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoparsersbad.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoparsersbad.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.061: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstisomp4.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstisomp4.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.061: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstgdp.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstgdp.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.061: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstspeex.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstspeex.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.062: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmatroska.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmatroska.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.062: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaccurip.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaccurip.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.062: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrfbsrc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrfbsrc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.062: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdash.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdash.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.063: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdtls.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdtls.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.063: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsmux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegtsmux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.063: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstspeed.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstspeed.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.064: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstid3demux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstid3demux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.064: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaiff.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaiff.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.064: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstasf.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstasf.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.064: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrtmp2.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrtmp2.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.064: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioconvert.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudioconvert.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.065: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsty4menc.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsty4menc.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.065: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofilter.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideofilter.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.065: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttypefindfunctions.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttypefindfunctions.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.066: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstv4l2codecs.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstv4l2codecs.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.066: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiolatency.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiolatency.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.066: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstwaylandsink.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstwaylandsink.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.066: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcamerabin.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcamerabin.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.067: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrawparse.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrawparse.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.067: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsmoothstreaming.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsmoothstreaming.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.067: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstivfparse.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstivfparse.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.067: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstinterlace.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstinterlace.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.068: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstgaudieffects.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstgaudieffects.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.068: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsuboverlay.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvbsuboverlay.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.068: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfestival.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstfestival.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.068: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstflac.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstflac.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.069: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstipcpipeline.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstipcpipeline.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.069: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrist.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrist.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.069: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstnavigationtest.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstnavigationtest.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.069: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmdec.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstadpcmdec.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.069: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstbayer.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstbayer.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.070: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstapp.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstapp.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.070: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstbz2.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstbz2.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.070: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstautodetect.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstautodetect.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.070: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdebug.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdebug.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.071: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstasfmux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstasfmux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.071: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdsub.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdsub.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.071: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsegmentclip.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstsegmentclip.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.071: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstpbtypes.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstpbtypes.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.071: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstgeometrictransform.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstgeometrictransform.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.071: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttimecode.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttimecode.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.072: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiobuffersplit.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstaudiobuffersplit.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.072: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstwavparse.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstwavparse.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.072: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstpnm.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstpnm.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.072: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrtpmanagerbad.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrtpmanagerbad.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.072: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpg123.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpg123.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.073: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstinter.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstinter.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.073: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdspu.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstdvdspu.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.073: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcolormanagement.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstcolormanagement.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.073: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrealmedia.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstrealmedia.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.073: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttranscode.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgsttranscode.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.073: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsdemux.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstmpegpsdemux.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.074: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoconvert.so': /home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib64/gstreamer-1.0/libgstvideoconvert.so: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.091: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib/gstreamer-1.0/libgstuvch264.so': libgudev-1.0.so.0: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.130: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib/gstreamer-1.0/libgstlibav.so': libspeex.so.1: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.166: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib/gstreamer-1.0/libgsttheora.so': libtheoradec.so.1: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.172: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib/gstreamer-1.0/libgstspeex.so': libspeex.so.1: wrong ELF class: ELFCLASS64
(wine:3097): GStreamer-WARNING **: 15:19:58.186: Failed to load plugin '/home/lordsansui/.local/share/lutris/runners/wine/lutris-7.1-x86_64/lib/gstreamer-1.0/libgstv4l2codecs.so': libgudev-1.0.so.0: wrong ELF class: ELFCLASS64
[0710/151958.946:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0710/152005.774:ERROR:angle_platform_impl.cc(40)] rx::SwapChain11::reset(615): Could not create additional swap chains or offscreen surfaces, HRESULT: 0x80070057
[0710/152005.775:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglCreateWindowSurface: Bad allocation.
[0710/152005.775:ERROR:gl_surface_egl.cc(1394)] eglCreateWindowSurface failed with error EGL_BAD_ALLOC
[0710/152005.775:ERROR:in_process_command_buffer.cc(450)] ContextResult::kSurfaceFailure: Failed to create surface.
omano
10 July 2022 20:33
18
There is a Lutris install script specifically for Starcraft 2, doing other settings specific for the game StarCraft II - Lutris example:
- task:
arch: win64
description: 'Wine Staging: Enabling DXVA2'
key: backend
path: HKEY_CURRENT_USER\Software\Wine\DXVA2
prefix: $GAMEDIR
value: va
yes, this was the original one I used at the first time, them I tried a second one inside Lutris using search function (don’t know if they are equal or different), and the third one was the one you share.
I might try back to xorg and see if there is any influence vs wayland.
I saw no behavior difference opening Battle.net using Xorg or Wayland.
@omano , if you still have battle.net installed do you mind to check one additional thing?
I saw some differences if I just launch battle.net application directly vs launching Lutris 1st and them inside Lutris starting Battle.net .
Maybe while launch battle.net directly it should open Lutris in the background but it’s not, don’t know but it could be part of the issue as well. I don’t have the right skills to check all this things.
Thanks for all the help.
