I’m on Manjaro KDE and I’d like to limit the battery charging threshold.
My laptop is Lenovo V130
and I have tried tlp but no luck.
I’m kinda noob so, will give any other info if needed.
Thank you for your reply and time in advance.
The easy solution is to set the battery charging levels in Windows and then reboot.
The more difficult approach is to ensure the TLP service is enabled:
sudo sytemctl enable tlp
and then RTFM and set your ThinkPad specific settings in TLP.
Also, for the future, please read this:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Thank you @Fabby for you reply.
I’m sorry, I’ll add the info right now.
Tlp didnt work and im not on dual boot currently
Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81HN v: Lenovo V130-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo V130-15IKB serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: 8VCN17WW date: 05/02/2019
ID-1: BAT0 charge: 22.0 Wh condition: 30.5/30.6 Wh (100%) volts: 7.8/7.6
model: CPT-COS L17C2PB3 type: Li-poly serial: <filter> status: Discharging
RAM: total: 7.12 GiB used: 2.81 GiB (39.4%)
RAM Report:
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB bogomips: 28808
Speed: 948 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 900 2: 901
3: 900 4: 900 5: 900 6: 900 7: 901 8: 901
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04ca:7070
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: amdgpu,intel FAILED: ati unloaded: modesetting
alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.4.60-2-MANJARO
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: efa0 bus ID: 02:00.0 chip ID: 8086:3166
IF: wlp2s0 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: c000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 42.55 GiB (3.7%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WDS240G2G0B-00EPW0
size: 223.58 GiB speed: 6.0 Gb/s serial: <filter> rev: 0000 scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DA8AESH rev: XL6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / size: 210.11 GiB used: 42.18 GiB (20.1%) fs: ext4 dev: /dev/sdb2
label: N/A uuid: 5e8adfe5-574a-4645-aa11-241e3d75faed
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
dev: /dev/sdb1 label: N/A uuid: 99E8-AC6A
ID-1: swap-1 type: partition size: 8.80 GiB used: 385.0 MiB (4.3%)
priority: -2 dev: /dev/sdb3 label: N/A
uuid: 141c0d1a-02fb-4946-9d37-d63fe7566fc7
ID-1: /dev/sda1 size: 232.83 GiB fs: ext4 label: HDD.Part1 Bkps
uuid: 6ba795dc-2154-4b2e-bb88-3e55ebd23235
ID-2: /dev/sda2 size: 7.45 GiB fs: swap label: swap
uuid: d7488ea0-db70-4f68-9f0e-e35530a0c752
ID-3: /dev/sda3 size: 465.85 GiB fs: ntfs label: HDD.Part3 Personal
uuid: 1A306D1F34155F53
ID-4: /dev/sda4 size: 225.38 GiB fs: ext4 label: HDD.Part4 PCBkp
uuid: 12032873-a888-4fbb-b4da-f5c523b559b4
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 25a7:fa23
Device-2: 1-5:3 info: Lite-On Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04ca:7070
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2a
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 50.0 C mobo: 45.0 C gpu: amdgpu temp: 49 C
Processes: 243 Uptime: 3h 30m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1295 pacman: 1291 snap: 4 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.05
If sudo sytemctl enable tlp
gave you the following error:
Failed to enable unit: Unit file tlp.service does not exist
you need to install it first:
pamac install tlp
then go back to #2 above.
I have installed tlp and seen, it doesnt work… battery thresholds dont hold
What’s the output of sudo tlp-stat -b
It says, the battery isnt supported… So, is there any other work around then?
Well, one thing you could try is sudo modprobe thinkpad_acpi
, and if it succeeds (meaning it prints nothing), check sudo tlp-stat -b
again.
--- TLP 1.3.1 --------------------------------------------
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi = inactive (laptop not supported)
tpacpi-bat = inactive (laptop not supported)
tp-smapi = inactive (laptop not supported)
+++ Battery Status: BAT0
/sys/class/power_supply/BAT0/manufacturer = CPT-COS
/sys/class/power_supply/BAT0/model_name = L17C2PB3
/sys/class/power_supply/BAT0/cycle_count = (not supported)
/sys/class/power_supply/BAT0/energy_full_design = 30630 [mWh]
/sys/class/power_supply/BAT0/energy_full = 29960 [mWh]
/sys/class/power_supply/BAT0/energy_now = 26180 [mWh]
/sys/class/power_supply/BAT0/power_now = 7379 [mW]
/sys/class/power_supply/BAT0/status = Discharging
Charge = 87.4 [%]
Capacity = 97.8 [%]
I tried, still same thing
I’m in the same case as you and that’s how companies sell more batteries:
sudo tlp-stat --battery
Defective by design…
Sad, that this happened :’’’(((
