Is there a way in Manjaro to generate a battery report? I know you can get battery details through the acpi and upower packages. But I’m looking for a full break-down of everything if possible. I hate to link to a Windows article, but in Windows 10 you can generate battery reports fairly easily:
Battery Report:
Is there a way to do something similar in Linux?
Thanks in advance to everyone for your time and feedback, it is greatly appreciated!
Since you are on KDE, you can go to Info Center > Energy. It does what windozs does but better. You can see both charge percentage and energy consumption for over 7 days.
Your profile said KDE Nevertheless, can you try installing gnome-power-manager. It does shows some battery statistics and stuff. You might want to wait sometime so that it can log some history.
