Hi community,
I have a lenovo thinkpad carbon X1 with manjaro+plasma KDE. This is the output of inxi -Fxz
Kernel: 6.6.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 20QESA1200 v: ThinkPad X1 Carbon 7th
serial: <superuser required>
Mobo: LENOVO model: 20QESA1200 serial: <superuser required> UEFI: LENOVO
v: N2HET46W (1.29 ) date: 02/21/2020
ID-1: BAT0 charge: 0 Wh (0.0%) condition: 52.0/51.0 Wh (101.9%) volts: 13.1
min: 15.4 model: LGC 5B10W13930 status: not charging
Info: quad core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
Speed (MHz): avg: 800 min/max: 400/4600 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 32012
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB
bus-ID: 1-8:5
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1: 2560x1440~60Hz
2: 2560x1440~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
GT2)
API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib devices: 1
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
API: ALSA v: k6.6.41-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.1 status: off
Server-3: PulseAudio v: 17.0 status: active
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
bus-ID: 4-1.1.2:4
IF: enp45s0u1u1u2 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB bus-ID: 1-10:8
Local Storage: total: 953.87 GiB used: 161.75 GiB (17.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730
SDBQNTY-1T00-1001 size: 953.87 GiB temp: 40.9 C
ID-1: / size: 928.86 GiB used: 161.75 GiB (17.4%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 56.0 C pch: 57.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Memory: total: 16 GiB available: 15.43 GiB used: 4.75 GiB (30.8%)
Processes: 233 Uptime: 9m Init: systemd
Packages: 1868 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Bash v: 5.2.26
inxi: 3.3.35
After letting the laptop fully discharge, it is now stuck to 0% battery, which does not charge when the laptop if connected to the charger. If I unplug the charger, the laptop shuts down. This is the ouput of sudo tlp-stat --battery
--- TLP 1.6.1 --------------------------------------------
+++ Battery Care
Plugin: thinkpad
Supported features: charge thresholds, recalibration
Driver usage:
* natacpi (thinkpad_acpi) = active (charge thresholds, recalibration)
Parameter value ranges:
* START_CHARGE_THRESH_BAT0/1: 0(off)..96(default)..99
* STOP_CHARGE_THRESH_BAT0/1: 1..100(default)
+++ ThinkPad Battery Status: BAT0 (Main / Internal)
/sys/class/power_supply/BAT0/manufacturer = LGC
/sys/class/power_supply/BAT0/model_name = 5B10W13930
/sys/class/power_supply/BAT0/cycle_count = 874
/sys/class/power_supply/BAT0/energy_full_design = 51000 [mWh]
/sys/class/power_supply/BAT0/energy_full = 51990 [mWh]
/sys/class/power_supply/BAT0/energy_now = 0 [mWh]
/sys/class/power_supply/BAT0/power_now = 0 [mW]
/sys/class/power_supply/BAT0/status = Not charging
/sys/class/power_supply/BAT0/charge_control_start_threshold = 0 [%]
/sys/class/power_supply/BAT0/charge_control_end_threshold = 100 [%]
/sys/class/power_supply/BAT0/charge_behaviour = [auto] inhibit-charge force-discharge
Charge = 0.0 [%]
Capacity = 101.9 [%]
and this is the output of sudo acpi -V
Battery 0: Not charging, 0%
Battery 0: design capacity 3878 mAh, last full capacity 3953 mAh = 100%
Adapter 0: on-line
Thermal 0: ok, 59.0 degrees C
Thermal 0: trip point 0 switches to mode critical at temperature 128.0 degrees C
Cooling 0: Processor 0 of 10
Cooling 1: pch_cannonlake no state information available
Cooling 2: Processor 0 of 10
Cooling 3: iwlwifi_1 no state information available
Cooling 4: Processor 0 of 10
Cooling 5: TCC Offset 3 of 63
Cooling 6: Processor 0 of 10
Cooling 7: INT3400 Thermal no state information available
Cooling 8: Processor 0 of 10
Cooling 9: SEN2 no state information available
Cooling 10: Processor 0 of 10
Cooling 11: B0D4 no state information available
Cooling 12: Processor 0 of 10
Cooling 13: x86_pkg_temp no state information available
Cooling 14: intel_powerclamp 0 of 100
Cooling 15: Processor 0 of 10
Cooling 16: SEN1 no state information available
In particular
It looks like some setting is preventing the charge from starting, but I could not resolve the issue. Any help will be greatly appreciated!
