After a new update around a week ago, first I couldn’t shut down my laptop with the GUI button (I already fixed that) and second, battery started draining reaaallyy fast, and the fan is constantly working. Temperature of the CPU is above normal although not critical, around 60 degrees without anything serious opened and without a charger. I assume it just consumes a lot of energy even though CPU use is almost 0
Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=4e289715-eafe-4946-a4ad-8cc9140df87f rw quiet splash acpi=force
apm=power_off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Acer product: Aspire A515-56G v: V1.26
serial: <superuser required>
Mobo: TGL model: Iris_TL v: V1.26 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.26
date: 03/14/2022
ID-1: BAT1 charge: 40.3 Wh (94.4%) condition: 42.7/53.2 Wh (80.2%)
volts: 11.7 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: discharging cycles: 50
System RAM: total: 16 GiB available: 15.4 GiB used: 5.5 GiB (35.7%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMA81GS6DJR8N-XN serial: <filter>
Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 8 GiB
manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E1 serial: N/A
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel alternate: xe
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce MX450] vendor: Acer Incorporated ALI
driver: N/A alternate: nouveau non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 bus-ID: 0000:01:00.0 chip-ID: 10de:1f97 class-ID: 0302
Device-3: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b72b
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.52 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.10.11-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel bus-ID: 0000:03:00.0
chip-ID: 14c3:7961 class-ID: 0280
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:4 chip-ID: 04ca:3802
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 103.29 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 47.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 103.29 GiB (22.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 4e289715-eafe-4946-a4ad-8cc9140df87f
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CC8D-076F
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: SINO WEALTH Mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 256mA chip-ID: 258a:002e class-ID: 0301
Device-2: 1-8:3 info: Chicony HD User Facing type: video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b72b class-ID: fe01 serial: <filter>
Device-3: 1-10:4 info: Lite-On Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 264 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1533 pm: dpkg pkgs: 0 pm: nix-default pkgs: 53 pm: nix-sys
pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman pkgs: 1480 libs: 390 tools: pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.32 running-in: konsole inxi: 3.3.36
