Good afternoon. I have HUAWEI matebook 2022 with intel i5 12500H processor. After turning off the laptop, the battery drains very quickly. On windows 11, for 3 days in the off state, the charge decreased by 2%, on manjaro for 1 day -10%. I’ve tried disabling wifi, bt, fp, etc. through the bios - it doesn’t help. Shutting down with shutdown -P now doesn’t solve the problem either.
I’m using Manjaro XFCE 22.1.0 with kernel 6.2.10-1-MANJARO, tried different versions. Kernels > 5.2 simply did not start, the problem remained with the rest.
I know that the problem is common among laptops on linux, but I did not find a suitable solution.
The output of inxi -Fzx and list of loaded modules are below.
inxi -Fzx
Kernel: 6.2.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HUAWEI product: RLEF-XX v: M1010 serial: <filter>
Mobo: HUAWEI model: RLEF-XX-PCB v: M1010 serial: <filter> UEFI: HUAWEI
v: 1.24 date: 11/08/2022
ID-1: BAT0 charge: 57.5 Wh (95.4%) condition: 60.3/59.4 Wh (101.5%)
volts: 12.8 min: 11.6 model: DESAY HB5781P1EEW-31T status: discharging
Info: 12-core (4-mt/8-st) model: 12th Gen Intel Core i5-12500H bits: 64
type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.1 MiB L2: 9 MiB
L3: 18 MiB
Speed (MHz): avg: 2844 high: 3100 min/max: 400/4500:3300 cores: 1: 1041
2: 3100 3: 3100 4: 3100 5: 3100 6: 3100 7: 3100 8: 3100 9: 1076 10: 3100
11: 3100 12: 3100 13: 3100 14: 3100 15: 3100 16: 3100 bogomips: 99568
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Huawei driver: i915
v: kernel arch: Gen-12.2 bus-ID: 00:02.0
Device-2: Quanta FHD Camera type: USB driver: uvcvideo bus-ID: 2-7:3
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 1920x1200~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Huawei
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
API: ALSA v: k6.2.10-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.68 status: n/a (root, process)
Server-3: PulseAudio v: 16.1 status: active (root, process)
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
bus-ID: 2-10:4
Local Storage: total: 478.85 GiB used: 19.65 GiB (4.1%)
ID-1: /dev/nvme0n1 model: PCIe-8 SSD 512GB size: 476.94 GiB temp: 27.9 C
ID-2: /dev/sda type: USB vendor: Transcend model: JetFlash TS2GJF130
ID-1: / size: 97.87 GiB used: 18.64 GiB (19.0%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot size: 487.2 MiB used: 296 MiB (60.8%) fs: ext4
dev: /dev/nvme0n1p2
ID-3: /boot/efi size: 300.4 MiB used: 11.3 MiB (3.8%) fs: vfat
dev: /dev/nvme0n1p1
ID-4: /home size: 369.17 GiB used: 724.1 MiB (0.2%) fs: ext4
dev: /dev/nvme0n1p4
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 378 Uptime: 1m Memory: 15.35 GiB used: 1.41 GiB (9.2%)
Init: systemd Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1104
Shell: Bash v: 5.1.16 inxi: 3.3.26
cmdline and lsmod
cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-6.2-x86_64 root=UUID=f5990125-f7bc-4ac5-8500-881bbda5f967 rw splash udev.log_priority=3
lsmod
Module Size Used by
rfcomm 102400 16
ccm 20480 3
cmac 16384 3
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 36864 6 algif_hash,algif_skcipher
snd_ctl_led 24576 0
snd_soc_skl_hda_dsp 28672 6
snd_soc_intel_hda_dsp_common 20480 1 snd_soc_skl_hda_dsp
snd_soc_hdac_hdmi 49152 1 snd_soc_skl_hda_dsp
snd_sof_probes 28672 0
snd_hda_codec_hdmi 94208 1
snd_hda_codec_conexant 36864 1
snd_hda_codec_generic 110592 1 snd_hda_codec_conexant
bnep 36864 2
uas 36864 0
btusb 77824 0
btrtl 28672 1 btusb
btbcm 24576 1 btusb
btintel 53248 1 btusb
btmtk 16384 1 btusb
bluetooth 1077248 44 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic 16384 2 bluetooth
usb_storage 86016 1 uas
joydev 28672 0
mousedev 24576 0
spi_pxa2xx_platform 36864 0
hid_multitouch 32768 0
dw_dmac 16384 0
8250_dw 24576 0
qrtr 57344 4
snd_soc_dmic 16384 1
snd_sof_pci_intel_tgl 16384 0
snd_sof_intel_hda_common 229376 1 snd_sof_pci_intel_tgl
soundwire_intel 61440 1 snd_sof_intel_hda_common
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_cadence 45056 1 soundwire_intel
snd_sof_intel_hda 24576 1 snd_sof_intel_hda_common
snd_sof_pci 24576 2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_sof_xtensa_dsp 20480 1 snd_sof_intel_hda_common
snd_sof 376832 4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_probes,snd_sof_intel_hda
intel_tcc_cooling 16384 0
x86_pkg_temp_thermal 20480 0
snd_sof_utils 20480 1 snd_sof
intel_powerclamp 20480 0
snd_soc_hdac_hda 28672 1 snd_sof_intel_hda_common
snd_hda_ext_core 36864 4 snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda
coretemp 20480 0
snd_soc_acpi_intel_match 73728 2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_sof_intel_hda_common
kvm_intel 446464 0
soundwire_bus 135168 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
snd_soc_core 434176 8 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_probes,snd_soc_dmic,snd_soc_skl_hda_dsp
kvm 1323008 1 kvm_intel
snd_compress 32768 2 snd_soc_core,snd_sof_probes
irqbypass 16384 1 kvm
ac97_bus 16384 1 snd_soc_core
iTCO_wdt 16384 0
crct10dif_pclmul 16384 1
huawei_wmi 28672 0
iwlmvm 614400 0
snd_pcm_dmaengine 20480 1 snd_soc_core
crc32_pclmul 16384 0
intel_pmc_bxt 16384 1 iTCO_wdt
snd_hda_intel 65536 0
polyval_clmulni 16384 0
ledtrig_audio 16384 3 snd_ctl_led,snd_hda_codec_generic,huawei_wmi
pmt_telemetry 16384 0
mei_pxp 20480 0
mei_hdcp 28672 0
iTCO_vendor_support 16384 1 iTCO_wdt
ppdev 24576 0
polyval_generic 16384 1 polyval_clmulni
i915 3788800 25
wmi_bmof 16384 0
intel_rapl_msr 20480 0
sparse_keymap 16384 1 huawei_wmi
gf128mul 16384 1 polyval_generic
pmt_class 16384 1 pmt_telemetry
snd_intel_dspcfg 36864 3 snd_hda_intel,snd_sof,snd_sof_intel_hda_common
mac80211 1490944 1 iwlmvm
snd_intel_sdw_acpi 20480 2 snd_sof_intel_hda_common,snd_intel_dspcfg
uvcvideo 176128 0
ghash_clmulni_intel 16384 0
sha512_ssse3 57344 0
videobuf2_vmalloc 20480 1 uvcvideo
libarc4 16384 1 mac80211
aesni_intel 401408 6
snd_hda_codec 217088 8 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_soc_intel_hda_dsp_common,snd_soc_hdac_hda,snd_sof_intel_hda,snd_soc_skl_hda_dsp
videobuf2_memops 20480 1 videobuf2_vmalloc
crypto_simd 16384 1 aesni_intel
videobuf2_v4l2 40960 1 uvcvideo
cryptd 32768 3 crypto_simd,ghash_clmulni_intel
snd_hda_core 139264 11 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_intel_hda_dsp_common,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda
rapl 20480 0
videodev 352256 2 videobuf2_v4l2,uvcvideo
snd_hwdep 20480 1 snd_hda_codec
intel_cstate 24576 0
drm_buddy 20480 1 i915
pcspkr 16384 0
iwlwifi 544768 1 iwlmvm
snd_pcm 200704 12 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pcm_dmaengine
intel_uncore 258048 0
processor_thermal_device_pci 16384 0
spi_nor 135168 0
videobuf2_common 90112 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
ttm 102400 1 i915
snd_timer 53248 1 snd_pcm
processor_thermal_device 24576 1 processor_thermal_device_pci
vfat 24576 1
mc 81920 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
fat 102400 1 vfat
cfg80211 1277952 3 iwlmvm,iwlwifi,mac80211
mei_me 61440 2
processor_thermal_rfim 20480 1 processor_thermal_device
mtd 110592 3 spi_nor
snd 151552 25 snd_ctl_led,snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_sof,snd_timer,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_pcm
i2c_i801 45056 0
drm_display_helper 208896 1 i915
intel_lpss_pci 28672 2
processor_thermal_mbox 16384 2 processor_thermal_rfim,processor_thermal_device
mei 192512 5 mei_hdcp,mei_pxp,mei_me
soundcore 16384 2 snd_ctl_led,snd
i2c_smbus 20480 1 i2c_i801
rfkill 40960 7 iwlmvm,bluetooth,cfg80211
intel_lpss 16384 1 intel_lpss_pci
parport_pc 77824 0
processor_thermal_rapl 20480 1 processor_thermal_device
cec 86016 2 drm_display_helper,i915
video 73728 1 i915
idma64 20480 0
i2c_hid_acpi 16384 0
intel_vsec 20480 0
intel_rapl_common 36864 2 intel_rapl_msr,processor_thermal_rapl
intel_gtt 28672 1 i915
igen6_edac 32768 0
int3400_thermal 20480 0
parport 81920 2 parport_pc,ppdev
wmi 45056 3 video,huawei_wmi,wmi_bmof
i2c_hid 40960 1 i2c_hid_acpi
int3403_thermal 20480 0
acpi_thermal_rel 16384 1 int3400_thermal
int340x_thermal_zone 20480 2 int3403_thermal,processor_thermal_device
acpi_pad 24576 0
mac_hid 16384 0
squashfs 86016 3
vboxnetflt 40960 0
vboxnetadp 28672 0
vboxdrv 659456 2 vboxnetadp,vboxnetflt
crypto_user 20480 0
fuse 204800 5
dm_mod 225280 0
loop 40960 6
bpf_preload 24576 0
ip_tables 40960 0
x_tables 61440 1 ip_tables
ext4 1163264 3
crc32c_generic 16384 0
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 217088 1 ext4
nvme 69632 4
nvme_core 237568 5 nvme
spi_intel_pci 16384 0
xhci_pci 24576 0
crc32c_intel 24576 6
spi_intel 36864 1 spi_intel_pci
nvme_common 24576 1 nvme_core
xhci_pci_renesas 24576 1 xhci_pci
serio_raw 20480 0
atkbd 40960 0
libps2 20480 1 atkbd
vivaldi_fmap 16384 1 atkbd
i8042 53248 0
serio 28672 4 serio_raw,atkbd,i8042
