Battery doesn't get found on surface pro 7?
Hello, after testing with my system for errors with
sudo systemctl --failed  (no error)
and
sudo journalctl -p 3 -xb
I got this error:
Mai 20 19:35:17 surface kernel: ov5693 i2c-INT33BE:00:
Failed to get clk from pmc_plt_clk_0: -2
Mai 20 19:35:17 surface kernel: ov5693 i2c-INT33BE:00: Couldn't set power mode for v1p2
Mai 20 19:35:17 surface kernel: ov5693 i2c-INT33BE:00: sensor power-up failed
(and much much more...)
now, I ran
sudo inxi --admin --verbosity=8 --filter --no-host --width
and it does not find my battery. How can I fix this?
Btw, my battery is build-in.
Thank you!
Hello,
Have a look here GitHub - linux-surface/linux-surface: Linux Kernel for Surface Devices
There is more information for each particular device, but requires surface kernel …
Thanks, but what are these out-of-tree modules (dkms) and does it only work on arch itself or on manjaro too?
They need the linux-headers for the running kernel, hence they work on Manjaro too, if are installed. Available via AUR in most cases.
