How can I make the Bash prompt look like this I use KDE 5.19. I saw this thing on arch Linux? Is it possible to make it on Manjaro?
That’s not bash
but zsh
. As far as I know, bash
does not support that kind of theming.
I myself do use a customized bash
prompt, with a shell function that allows me to choose a different color for the prompt if I want to. I’ve done this by adding the following to my ~/.bashrc
cprompt () {
if [ ! -z $1 ]
then
case $1 in
"green" )
clrprompt="\[\e[1;32m\]\n[\h:\$(/usr/bin/tty)][\${PWD}]\n[\t][\u] \[\e[1;37m\]>\[\e[0m\] "
"yellow" )
clrprompt="\[\e[1;33m\]\n[\h:\$(/usr/bin/tty)][\${PWD}]\n[\t][\u] \[\e[1;37m\]>\[\e[0m\] "
"blue" )
clrprompt="\[\e[1;34m\]\n[\h:\$(/usr/bin/tty)][\${PWD}]\n[\t][\u] \[\e[1;37m\]>\[\e[0m\] "
"pink" )
clrprompt="\[\e[1;35m\]\n[\h:\$(/usr/bin/tty)][\${PWD}]\n[\t][\u] \[\e[1;37m\]>\[\e[0m\] "
"cyan" )
clrprompt="\[\e[1;36m\]\n[\h:\$(/usr/bin/tty)][\${PWD}]\n[\t][\u] \[\e[1;37m\]>\[\e[0m\] "
"white" )
clrprompt="\[\e[1;37m\]\n[\h:\$(/usr/bin/tty)][\${PWD}]\n[\t][\u] \[\e[1;37m\]>\[\e[0m\] "
echo
echo " The only options available are: "
echo
echo " green | yellow | blue | pink | cyan | white"
echo
return
esac
PS1=${clrprompt}
else
echo
echo " No color specified."
echo
return
fi
cprompt yellow
export PS1
export -f cprompt
As for what my prompt then looks like…
[nx-74205:/dev/pts/3][/home/aragorn]
[17:10:17][aragorn] >
Ok I will try the zsh, Is it also the archiso shell?
Yes, zsh
is the default interactive shell in the latest Manjaro installers, and I believe in Arch as well.
Cool I found the completion so nice but I was unable to install GRUB correctly (and I’m happy that it don’t worked: Manjaro is the best)
The ZSH does not have the theme by default.
But the distribution called https://ohmyz.sh/ has such a theme.
Install
yay -S oh-my-zsh-git oh-my-zsh-powerline-theme-git
Then export envrironment variable @ ~/.zshrc
# Path oh-my-zsh installation.
export ZSH=/usr/share/oh-my-zsh/
Set the theme
ZSH_THEME="agnoster"
I seem to remember @codesardine mentioning that the Manjaro devs are working on a new default zsh
theme for Manjaro as well.
I’m not sure, try pureline https://github.com/chris-marsh/pureline
Wow, that’s cool.
I’ll mark your post as the solution ─ it’s much better than my own answer.
Exists also powerline go, silver and other … for bash or zsh or fish
Contrary to others, they are compiled programs and therefore faster
Looks like powerline-shell (GitHub - b-ryan/powerline-shell: A beautiful and useful prompt for your shell), install via AUR. To setup for bash, check here: GitHub - b-ryan/powerline-shell: A beautiful and useful prompt for your shell
It’s in the regular repo as well. I’ve just checked.
