Trying to run Barrier on my RasPi4 Server ( Barrier is a mouse/kb share thingumy ).
It actually loads and you can configure it but,
when I try to run the server I get the following :-
Sep 08 14:21:18 dbus-daemon[286]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Sep 08 14:21:18 dbus-daemon[286]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.145' (uid=1000 pid=1569 comm="barrier ")
Sep 08 14:21:18 barrier[1569]:
*** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** The program 'barrier' called 'DNSServiceRegister()' which is not supported
(or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
There’s nothing on the forum about Barrier or Avahi-Compat.
Has anyone else tried using Barrier on i386 or ARM, and did it work
(It’s in the Official Repo)
