Baikal log-in issue following 2025-02-04 update
Update works fine, but I have now problems with Baikal, which works before the update flawless. When I want to log in via browser to the admin page, i get:
Access denied.
Environment:
  • baikal 0.10.1-1 AUR
  • nginx-mainline 1.27.3-1
  • php-legacy-fpm 8.2.27-1
  • php-legacy-symlinks 1-2
Welcome to the Forum!
I’ve moved your post into its own topic, as it relates to AUR packages.
Could you please provide some system information; the output of
inxi -zv8
is usually enough to start with. Highlight the copied & pasted text from your Terminal and format it using the </> button at the top of the reply window.
A bit more detail about Baikal and what it does may be helpful to those able to help with the issue.
Note that AUR packages are regarded as “unsupported” both here and in Arch Linux.
You should also be using Unstable (or at least Testing) branch when using AUR packages as those branches are closer to Arch, which AUR packages are typically written for.
The latest update introduced a new? AppArmor profile for php-fpm which resulted in “Acces denied” for me as well.
You could turn it (temporarily) off and see if it works again.
this one is not in the AUR - not anymore at least
so: that might be part of the problem
AUR (en) - baikal
Arch Linux - Package Search
That is just from looking at the provided and available info.
I actually have no idea about what baikal is or does … beyond the description
Baikal is a CalDAV / CardDAV Server, which I use to synchronize my Thunderbird calendar and address book with my cellphone.
`inxi -zv8
  Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
    root=UUID=20c46579-6f16-4ffb-b1b4-3dcb962fa1e4 rw rootflags=subvol=@
    cryptkey=/dev/silber_stick:1044480:2048 quiet
    cryptdevice=UUID=83644ee0-c75b-4164-abbd-40b2fbd785f6:luks-83644ee0-c75b-4164-abbd-40b2fbd785f6
    root=/dev/mapper/luks-83644ee0-c75b-4164-abbd-40b2fbd785f6 splash
  Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: ASUSTeK product: ZenBook UX325EA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX325EA v: 1.0 serial: <superuser required>
    part-nu: 1.0 UEFI: American Megatrends LLC. v: UX325EA.321 date: 02/27/2024
  ID-1: BAT0 charge: 31.0 Wh (76.9%) condition: 40.3/67.1 Wh (60.0%)
    volts: 16.8 min: 15.9 model: ASUSTeK UX325 type: Li-ion serial: <filter>
    status: charging cycles: 528
  System RAM: total: 16 GiB available: 15.32 GiB used: 2.76 GiB (18.0%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous
    size: 2 GiB speed: 4267 MT/s volts: curr: 0.6 min: 0.6 max: 0.6
    width (bits): data: 16 total: 16 manufacturer: Samsung
    part-no: UBE3D4AA-MGCR serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR4 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR4 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR4 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR4 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR4 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR4 detail: synchronous
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xB8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 38720
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4, HDMI-A-5 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 13d3:56eb
  Display: x11 server: X.org v: 1.21.1.15 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: Samsung 0x4158 built: 2020 res: 1920x1080 dpi: 166
    gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
    x: 0.137 y: 0.047 white: x: 0.314 y: 0.329 size: 294x165mm (11.57x6.5")
    diag: 337mm (13.3") ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 7.48 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  IF-ID-1: outline-tun0 state: down mac: N/A
  IP v4: <filter> scope: global
  Info: services: NetworkManager, nginx, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
    class-ID: e001
  Device-1: luks-83644ee0-c75b-4164-abbd-40b2fbd785f6 maj-min: 254:0
    type: LUKS dm: dm-0 size: 475.66 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 475.67 GiB
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 534.69 GiB used: 250.22 GiB (46.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
    lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 28.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: DataTraveler 3.0
    size: 57.75 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: PMAP scheme: GPT
  ID-1: / raw-size: 475.66 GiB size: 475.66 GiB (100.00%)
    used: 249.48 GiB (52.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-83644ee0-c75b-4164-abbd-40b2fbd785f6 label: N/A
    uuid: 20c46579-6f16-4ffb-b1b4-3dcb962fa1e4
  ID-2: /boot raw-size: 1000 MiB size: 1000 MiB (100.00%)
    used: 754.7 MiB (75.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: d25cddc6-0c16-4496-af7f-e76a43fc2123
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 93B4-5313
  ID-4: /home raw-size: 475.66 GiB size: 475.66 GiB (100.00%)
  ID-5: /swap raw-size: 475.66 GiB size: 475.66 GiB (100.00%)
  ID-6: /var/cache raw-size: 475.66 GiB size: 475.66 GiB (100.00%)
  ID-7: /var/log raw-size: 475.66 GiB size: 475.66 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  ID-1: /dev/sda1 maj-min: 8:1 size: 56.72 GiB fs: exfat label: Ventoy
    uuid: 7379-C5B0
  ID-2: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 3F32-27F5
  ID-3: /dev/sda3 maj-min: 8:3 size: 1023 MiB fs: exfat label: LiveDaten
    uuid: 8CFF-2262
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56eb class-ID: fe01
    serial: <filter>
  Device-2: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Device-1: 4-1:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
    chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 39.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1895 pm: dpkg pkgs: 0 pm: pacman pkgs: 1845 libs: 400
    tools: pamac,yay pm: flatpak pkgs: 30 pm: snap pkgs: 20
    1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://manjaro.kurdy.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 325
  1: cpu: 9.7% command: firefox pid: 2883 mem: 477.2 MiB (3.0%)
  2: cpu: 6.0% command: firefox pid: 2998 mem: 52.4 MiB (0.3%)
  3: cpu: 2.3% command: Xorg pid: 1949 mem: 86.6 MiB (0.5%)
  4: cpu: 1.7% command: firefox pid: 8082 mem: 265.4 MiB (1.6%)
  5: cpu: 1.1% command: firefox pid: 3161 mem: 61.8 MiB (0.3%)
  Memory top: 5 of 325
  1: mem: 477.2 MiB (3.0%) command: firefox pid: 2883 cpu: 9.7%
  2: mem: 265.4 MiB (1.6%) command: firefox pid: 8082 cpu: 1.7%
  3: mem: 225.4 MiB (1.4%) command: firefox pid: 3063 cpu: 0.2%
  4: mem: 179.0 MiB (1.1%) command: firefox pid: 5822 cpu: 0.1%
  5: mem: 166.7 MiB (1.0%) command: firefox pid: 6772 cpu: 0.1%
  Processes: 325 Power: uptime: 48m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.11 GiB services: upowerd,xfce4-power-manager
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
I have adapted/changed your formatting of the inxi output - use “preformatted text” → this symbol: </>
when posting terminal output
It will then look like what you saw - and be much more readable.
Thanks! Yes, deactivating Apparmor does the trick. Did it with
$ sudo systemctl stop apparmor
$ sudo systemctl disable apparmor
Restart computer
Do you know how to configure Apparmor for Baikal? For safety reasons I want to use Apparmor.
I wasn’t asked - and I don’t “know” how to configure it.
… I have disabled it for my system - but that is my choice …
This might help you:
AppArmor - ArchWiki
Thanks, when I figured out I will post it.
php-legacy
is compiled with (according to the PKGBUILD):
--with-fpm-user=http
--with-fpm-group=http
perhaps that helps with configuring Apparmor …
There is literally nothing else I could potentially add.
Depending on your threat model, you shouldn’t disable AppArmor permanently. Instead just disable the AppArmor profile for php-fpm as long as your NGINX is not publicly available on the internet.
ln -s /etc/apparmor.d/php-fpm /etc/apparmor.d/disable/
Or try to adjust the profile to your environment so it doesn’t create “Access denied”.
Btw this not specific for Baikal, but for all PHP scripts.
You are a genius :ok_hand: Your soft link worked. I wonder about this because I use the php-legacy-fpm package.
And Baikal it self should be also blocked. I don’t know much about AppArmor but I do know that things are generally blocked and have to be de-blocked actively to get it working. Never the less the solution is good enough, since I use Nginx only over my lokal WLAN no internet access.
Thanks a lot!
Thanks, for helping me to get a better Forum user.
My posts where aimed at furthering knowledge - yours and ours.
Not to be for you being “a good user” … “a good boy” …
