Bad return status for rtl8821ce module build on kernel 6.16 [Solved]
Hi,
I installed yesterday linux616 without problems, but whit today update I recieved the following message.
 [2025-08-30T09:48:35-0300] [ALPM-SCRIPTLET] Deprecated feature: CLEAN (/usr/src/rtl8821ce-1.0.5.r176.g1bbfc
35/dkms.conf)
[2025-08-30T09:50:28-0300] [ALPM-SCRIPTLET] ==> dkms install --no-depmod rtl8821ce/1.0.5.r176.g1bbfc35 -k 6
.16.4-2-MANJARO
[2025-08-30T09:50:28-0300] [ALPM-SCRIPTLET] Deprecated feature: CLEAN (/var/lib/dkms/rtl8821ce/1.0.5.r176.g
1bbfc35/source/dkms.conf)
[2025-08-30T09:50:29-0300] [ALPM-SCRIPTLET]
[2025-08-30T09:50:29-0300] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.16.4-2-M
ANJARO (x86_64)
[2025-08-30T09:50:29-0300] [ALPM-SCRIPTLET] Consult /var/lib/dkms/rtl8821ce/1.0.5.r176.g1bbfc35/build/make.
log for more information.
[2025-08-30T09:50:29-0300] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod rtl8821ce/1.0.5.r176.g1b
bfc35 -k 6.16.4-2-MANJARO' exited 10
The fallback image was successfully made and I booted with the fallback image without problem, selecting it from the grub menu.
[2025-08-30T09:51:02-0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6
.12-x86_64-fallback.img'
[2025-08-30T09:51:03-0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2025-08-30T09:51:04-0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-08-30T09:51:04-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux616.pres
et: 'default'
[2025-08-30T09:51:04-0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-30T09:51:04-0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.16-x86_64 -g /boot/initramfs-6.16-x86_6
4.img
[2025-08-30T09:51:04-0300] [ALPM-SCRIPTLET] ==> Starting build: '6.16.4-2-MANJARO'
I also have installed linux612, in order to solve any boot problem. I do not know why this could happened.
The other problem which I usually ignore is the following:
[2025-08-30T09:51:38-0300] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
The output of the lsblk command is this:
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
nvme0n1     259:0    0 238,5G  0 disk
├─nvme0n1p1 259:1    0   300M  0 part /boot/efi
└─nvme0n1p2 259:2    0 238,2G  0 part /
The system information is the following:
inxi -v7azy
  Kernel: 6.16.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=7eed2277-6294-48ab-a3a2-6f9f4a101856 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver avail: i3lock,slock vt: 7
    dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: HP product: HP Laptop 15s-fq2xxx v: N/A
  Mobo: HP model: 87FE v: 57.28 serial: <superuser required>
    part-nu: 51Q80EA#ABZ uuid: <superuser required> UEFI: AMI v: F.38
    date: 01/03/2025
  ID-1: BAT0 charge: 24.2 Wh (68.2%) condition: 35.5/41.0 Wh (86.5%)
    volts: 11.5 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
    status: discharging cycles: 181
  System RAM: total: 8 GiB available: 7.4 GiB used: 1.7 GiB (22.9%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: Bottom - Slot 1 (left) type: no module installed
  Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Nanya Technology
    part-no: NT8GA64D88CX3S-JR serial: <filter>
  Info: model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBC
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB
    desc: 2x1.2 MiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 400 min/max: 400/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 23961
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
    pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
    sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: Hewlett-Packard
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a78 class-ID: 0300
  Device-2: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:5365
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.18 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 362x204mm (14.25x8.03")
    s-diag: 416mm (16.36")
  Monitor-1: eDP-1 model: BOE Display 0x09e2 built: 2017 res: mode: 1366x768
    hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT2)
    device-ID: 8086:9a78 memory: 7.23 GiB unified: yes
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k6.16.4-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: N/A modules: rtw88_8821ce port: 3000
    bus-ID: 0000:01:00.0 chip-ID: 10ec:c821 class-ID: 0280
  Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4:2 chip-ID: 0b95:1790
    class-ID: 0a00 serial: <filter>
  IF: enp0s20f0u4c2 state: up speed: 100 Mbps duplex: half mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:b00e
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 238.47 GiB used: 52.14 GiB (21.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HBJD-00BH1
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1NFAV temp: 39.9 C
    scheme: GPT
  ID-1: / raw-size: 238.18 GiB size: 233.38 GiB (97.99%)
    used: 52.14 GiB (22.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 7eed2277-6294-48ab-a3a2-6f9f4a101856
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 50EC-B8C6
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:1002 class-ID: 0301
  Device-2: 1-3:3 info: Quanta HP TrueVision HD Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
  Device-3: 1-10:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b00e class-ID: e001 serial: <filter>
  Device-1: 2-4:2 info: ASIX AX88179 Gigabit Ethernet
    type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
    chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
  System Temperatures: cpu: 38.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Processes: 199 Power: uptime: 15m states: freeze,mem,disk suspend: s2idle
    image: 2.88 GiB services: upowerd,xfce4-power-manager Init: systemd v: 257
  Packages: pm: pacman pkgs: 1406 libs: 392 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3
    running-in: xfce4-terminal inxi: 3.3.38
Maybe, I either forget something to do or I did not read any useful information.
Let me know, please.
Regards
Is this AUR package I guess? It’s a *-git package so depending on what tool you’re using to manage AUR packages upstream changes may not be detected and there was a change related to 6.16 last week.
If you don’t know what any of that means then just uninstall and re-install it. If that doesn’t work then post the content of that make.log.
Is completely harmless but if it bothers you then uninstall the memtest86+ package.
Hi @MrLavender,
Thank you for your comments, the AUR package is the one you mentioned.
The log file is the following, myabe I should uninstall linux616 for a while.
cat /var/lib/dkms/rtl8821ce/1.0.5.r176.g1bbfc35/build/make.log
DKMS (dkms-3.2.1) make.log for rtl8821ce/1.0.5.r176.g1bbfc35 for kernel 6.16.4-2-MANJARO (x86_64)
sáb 30 ago 2025 09:50:28 -03
Building module(s)
# command: 'make' -j4 KVER=6.16.4-2-MANJARO
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/6.16.4-2-MANJARO/build M=/var/lib/dkms/rtl8821ce/1.0.5.r176.g1bbfc35/build  modules
make[1]: Entering directory '/usr/lib/modules/6.16.4-2-MANJARO/build'
make[2]: Entering directory '/var/lib/dkms/rtl8821ce/1.0.5.r176.g1bbfc35/build'
  CC [M]  core/rtw_cmd.o
  CC [M]  core/rtw_security.o
  CC [M]  core/rtw_debug.o
  CC [M]  core/rtw_io.o
core/rtw_cmd.c:17:10: fatal error: drv_types.h: No such file or directory
   17 | #include <drv_types.h>
compilation terminated.
make[4]: *** [/usr/lib/modules/6.16.4-2-MANJARO/build/scripts/Makefile.build:287: core/rtw_cmd.o] Error 1
make[4]: *** Waiting for unfinished jobs....
core/rtw_security.c:17:10: fatal error: drv_types.h: No such file or directory
core/rtw_debug.c:17:10: fatal error: drv_types.h: No such file or directory
make[4]: *** [/usr/lib/modules/6.16.4-2-MANJARO/build/scripts/Makefile.build:287: core/rtw_security.o] Error 1
make[4]: *** [/usr/lib/modules/6.16.4-2-MANJARO/build/scripts/Makefile.build:287: core/rtw_debug.o] Error 1
core/rtw_io.c:47:10: fatal error: drv_types.h: No such file or directory
   47 | #include <drv_types.h>
make[4]: *** [/usr/lib/modules/6.16.4-2-MANJARO/build/scripts/Makefile.build:287: core/rtw_io.o] Error 1
make[3]: *** [/usr/lib/modules/6.16.4-2-MANJARO/build/Makefile:2003: .] Error 2
make[2]: *** [/usr/lib/modules/6.16.4-2-MANJARO/build/Makefile:248: __sub-make] Error 2
make[2]: Leaving directory '/var/lib/dkms/rtl8821ce/1.0.5.r176.g1bbfc35/build'
make[1]: *** [Makefile:248: __sub-make] Error 2
make[1]: Leaving directory '/usr/lib/modules/6.16.4-2-MANJARO/build'
make: *** [Makefile:2244: modules] Error 2
# exit code: 2
# elapsed time: 00:00:01
The message did not appeared when I run:
sudo mkinitcpio -P
I understood your last message, thank you for your support.
Regards,
Like I said, your package is out-of-date. When I build it I get rtl8821ce-dkms-git 1.0.5.r186.g5df613d-1 and that works fine on 6.16.
Hi @MrLavender ,
Thank you for your help, today I could build the package and there were no more errors.
Kind regards,
