Hello there,
So I found this old TV that has a max resolution of 1080i (CELCUS 19913dvd), and decided to use it as a monitor on my Manjaro laptop.
But it is displayed like this (When in 1080i):
(Outside the red lines is what I can not see, but is rendered)
And the quality is very bad.
I’m using an optimus laptop so I tried swithcing to the NVIDIA GPU but that made no difference.
The same thing happens when I switch to 720p and 1080p gives a “out of range” error on the TV.
How ever when I switch to 1680x1050 it works with better quality, and fits, but because it’s a 16:10 resolution it is squashed.
the resolution of 1366x768 works fine, but I need a resolution that is bigger than 1680x1050.
System info:
System: Host: idea-80tu Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=45f8ca37-5163-41c4-9a2d-421d3e4e9cbc
rw quiet apparmor=1 security=apparmor resume=UUID=41d868e9-9725-4954-8dc8-c727ba086936
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 80TU v: Lenovo ideapad 310-14IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 310-14IKB
Mobo: LENOVO model: Torronto 4C2 v: NO DPK serial: <superuser required> UEFI: LENOVO
v: 3JCN21WW date: 09/23/2016
Battery: ID-1: BAT0 charge: 23.7 Wh (100.0%) condition: 23.7/30.0 Wh (79.1%) volts: 8.6 min: 7.4
model: SMP L15M2PB2 type: Li-poly serial: 9238 status: Full
Memory: RAM: total: 7.67 GiB used: 2.45 GiB (32.0%)
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
Speed: 526 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 526 2: 545 3: 600 4: 549
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: Lenovo driver: nvidia v: 390.144
alternate: nouveau,nvidia_drm bus-ID: 03:00.0 chip-ID: 10de:134f class-ID: 0302
Device-3: Chicony EasyCamera type: USB driver: uvcvideo bus-ID: 1-4:5 chip-ID: 04f2:b57d
class-ID: 0e02 serial: 0001
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 110 s-size: 757x248mm (29.8x9.8") s-diag: 797mm (31.4")
Monitor-1: eDP-1-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: HDMI-1-1 res: 1920x1080 hz: 60 dpi: 3048 size: 16x9mm (0.6x0.4") diag: 18mm (0.7")
OpenGL: renderer: GeForce 920MX/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Drives: Local Storage: total: 379.89 GiB used: 233.8 GiB (61.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: 50026B73801F8542 rev: 0102
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9160412AS size: 149.05 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: 5VGCALEC rev: HPM1
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston model: DataTraveler 2.0 size: 7.27 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: C86000BDB9F2EE10AA310036 rev: PMAP
scheme: MBR
Partition: ID-1: / raw-size: 214.47 GiB size: 210.05 GiB (97.94%) used: 133.22 GiB (63.4%) fs: ext4
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.16 GiB (13.2%) priority: -2 dev: /dev/sda3
maj-min: 8:3
Sensors: System Temperatures: cpu: 49.5 C mobo: N/A gpu: nvidia temp: 45 C
Output of cvt -i 1920 1080
# 1920x1080 119.89 Hz (CVT 2.07M9) hsync: 69.78 kHz; pclk: 179.75 MHz
Modeline "1920x1080_60.00" 179.75 1920 2048 2248 2576 1080 1083 1088 1164 interlace -hsync +vsync
Output of cvt 1680 1050
# 1680x1050 59.95 Hz (CVT 1.76MA) hsync: 65.29 kHz; pclk: 146.25 MHz
Modeline "1680x1050_60.00" 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
Output of cvt 1366 768
# 1368x768 59.88 Hz (CVT) hsync: 47.79 kHz; pclk: 85.25 MHz
Modeline "1368x768_60.00" 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync
Please tell me if I need to give any additional info.
Thanks for the help.
