Bad resolution in my second screen
hello i have a problem with my laptop
Lenovo Yoga Pro 7 14IMH9
Intel® Core™ Ultra 7 155H × 22
NVIDIA GeForce RTX 4050 Laptop GPU GPU-cb49887e-2a34-c0c7-9cac-6e859f68a52d
when i load my second screen an hp envy 34" 4k via hdmi
i am blocked to 19201200 resolution i can’t use 34401440
i try an other hdmi cable same fight
nvidia 570.144
udo mhwd -a pci  nonfree 0300
> Skipping already installed config 'video-hybrid-intel-nvidia-prime' for device: 0000:00:02.0 (0300:8086:7d55) Display controller Intel Corporation Meteor Lake-P [Intel Arc Graphics]
mhwd -li -d
   ATTACHED: PCI
   VERSION: 2020.01.13
   INFO: X.org modesetting video driver.
   PRIORITY: 1
   FREEDRIVER: true
   DEPENDS: -
   CONFLICTS: -
   CLASSIDS: 0300
   VENDORIDS: *
   ATTACHED: PCI
   VERSION: 2025.01.13
   INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY: 8
   FREEDRIVER: false
   DEPENDS: video-modesetting
   CONFLICTS: video*nvidia*
   CLASSIDS: 0300 0302 0300
   VENDORIDS: 10de 8086
Screen 0: minimum 320 x 200, current 4800 x 1800, maximum 16384 x 16384
eDP-1 connected primary 2880x1800+1920+0 (normal left inverted right x axis y axis) 312mm x 195mm
   2880x1800    120.00*+  60.00
HDMI-1 connected 1920x1200+0+248 (normal left inverted right x axis y axis) 797mm x 333mm
   1920x1200     59.95*
   1920x1080     60.00    60.00    50.00    59.94
thanks for any help !
Welcome to the Manjaro community @yberges
Although the information you have posted so far will likely provide some assistance, it may be difficult to work out where the issue lies without more detailed system information. Could you please post the output of:
inxi -zv8
thanks for helping
  Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=c5831a18-5732-460e-8bd4-f7af62618665 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell with: ulauncher
    base: Arch Linux
  Type: Laptop System: LENOVO product: 83E2 v: Yoga Pro 7 14IMH9
    serial: <superuser required> Chassis: type: 10 v: Yoga Pro 7 14IMH9
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_83E2_BU_idea_FM_Yoga Pro 7
    14IMH9 uuid: <superuser required> UEFI: LENOVO v: N9CN30WW
    date: 12/26/2024
  ID-1: BAT0 charge: 55.4 Wh (76.6%) condition: 72.3/73.0 Wh (99.0%)
    volts: 16.6 min: 15.5 model: Sunwoda L22D4PF4 type: Li-poly serial: <filter>
    status: not charging cycles: 43
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.05 GiB used: 4.62 GiB (30.7%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 2 GiB speed: 7467 MT/s volts: curr: 0.5 width (bits): data: 16
    total: 16 manufacturer: Samsung part-no: K3KL8L80CM-MGCT serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
    KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1888 min/max: 400/4500:4800:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1888 2: 1888 3: 1888
    4: 1888 5: 1888 6: 1888 7: 1888 8: 1888 9: 1888 10: 1888 11: 1888 12: 1888
    13: 1888 14: 1888 15: 1888 16: 1888 17: 1888 18: 1888 19: 1888 20: 1888
    21: 1888 22: 1888 bogomips: 131824
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: DP-5,eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    DP-6, DP-7, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:28a1 class-ID: 0302
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:2 chip-ID: 174f:1820
  Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 4800x1800 s-size: <missing: xdpyinfo>
  Monitor-1: DP-5 mapped: DP-1-1 pos: left model: HP ENVY 34
    serial: <filter> built: 2017 res: mode: 1920x1200 hz: 60 scale: 100% (1)
    dpi: 191 gamma: 1.2 chroma: red: x: 0.671 y: 0.322 green: x: 0.294
    y: 0.643 blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 255x255mm (10.04x10.04") diag: 864mm (34") modes: 1920x1200,
    3440x1440, 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 68 2: parse_edid:
    unhandled CEA mode 69 3: parse_edid: unhandled CEA mode 75 4: parse_edid:
    unhandled CEA mode 76
  Monitor-2: eDP-1 pos: primary,right model: Samsung 0x4188 built: 2021 res:
    mode: 2880x1800 hz: 120 scale: 100% (1) dpi: 234 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white:
    x: 0.314 y: 0.329 size: 312x195mm (12.28x7.68") diag: 368mm (14.5")
    ratio: 16:10 modes: 2880x1800
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
    platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
    device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
    drv: iris inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 7.35 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  Device-2: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.5:3 chip-ID: 0bda:4014
    class-ID: 0102 serial: <filter>
  API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp12s0u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-2.1:4
  IF: enp13s0u2u1 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 12.72 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEJ4X112N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51040C31 temp: 25.9 C
    scheme: GPT
  ID-1: / raw-size: 303.76 GiB size: 303.76 GiB (100.00%)
    used: 12.68 GiB (4.2%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: c5831a18-5732-460e-8bd4-f7af62618665
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 42.5 MiB (16.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM_DRV uuid: 4E24-A9D4
  ID-3: /home raw-size: 303.76 GiB size: 303.76 GiB (100.00%)
  ID-4: /var/cache raw-size: 303.76 GiB size: 303.76 GiB (100.00%)
  ID-5: /var/log raw-size: 303.76 GiB size: 303.76 GiB (100.00%)
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 646.9 GiB fs: ntfs
    label: Windows-SSD uuid: 862E256C2E255689
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
    label: WINRE_DRV uuid: 50B8263BB8261FC8
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: vfat label: N/A
    uuid: 7BB7-6A4E
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-9:2 info: Syntek Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:1820 class-ID: fe01
    serial: <filter>
  Device-2: 3-10:3 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 5-1:2 info: Microchip (formerly SMSC) Hub ports: 7 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2807
  Device-1: 5-1.5:3 info: Realtek USB Audio type: audio
    driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:4014 class-ID: 0102
    serial: <filter>
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-8: 6-1:2 info: Microchip (formerly SMSC) Hub ports: 7 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5807
  Device-1: 6-1.2:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 256mA
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 7-2:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Hub-11: 7-2.2:4 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0801 class-ID: 0900
  Device-1: 7-2.5:5 info: VIA Labs USB Billboard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 2109:8888 class-ID: 1100 serial: <filter>
  Hub-12: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-13: 8-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  Device-1: 8-2.1:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
  Device-2: 8-2.4:3 info: Genesys Logic USB Storage type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 05e3:0764 class-ID: 0806
    serial: <filter>
  Src: /sys System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1231 libs: 345 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    2: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    3: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 438
  1: cpu: 9.0% command: firefox pid: 3279 mem: 581.8 MiB (3.7%)
  2: cpu: 5.2% command: kgx pid: 4440 mem: 295.9 MiB (1.9%)
  3: cpu: 4.7% command: firefox pid: 3791 mem: 207.9 MiB (1.3%)
  4: cpu: 2.2% command: gnome-shell pid: 1871 mem: 295.0 MiB (1.9%)
  5: cpu: 1.6% command: Xorg pid: 1765 mem: 123.0 MiB (0.7%)
  Memory top: 5 of 438
  1: mem: 967.3 MiB (6.2%) command: pamac-manager pid: 2909 cpu: 1.6%
  2: mem: 581.8 MiB (3.7%) command: firefox pid: 3279 cpu: 9.0%
  3: mem: 295.9 MiB (1.9%) command: kgx pid: 4440 cpu: 5.2%
  4: mem: 295.0 MiB (1.9%) command: gnome-shell pid: 1871 cpu: 2.2%
  5: mem: 264.7 MiB (1.7%) command: firefox pid: 4103 cpu: 0.7%
  Processes: 438 Power: uptime: 13m states: freeze,mem,disk suspend: s2idle
    image: 5.99 GiB services: gsd-power, power-profiles-daemon, upowerd
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: kgx inxi: 3.3.38
Hello no way ?
Please i didn’t want to return on wind…
Have you tried a Wayland session? x11 isn’t getting much love these days.
If this doesn’t work, I’ll have to refresh myself on those xrandr commands I used to use; haven’t used x11 in some time now and have become a bit rusty.
i try in wayland same problem
xrandr
   2880x1620     59.96    59.97
   2560x1600     59.99    59.97
   2560x1440     59.99    59.99    59.96    59.95
   2048x1536     85.00    75.00    60.00
   1920x1440     85.00    75.00    60.00
   1856x1392     75.00    60.01
   1792x1344     75.00    60.01
   2048x1152     59.99    59.98    59.90    59.91
   1920x1200     59.88    59.95
   1920x1080     60.01    59.97    59.96    59.93
   1600x1200     85.00    75.00    70.00    65.00    60.00
   1680x1050     59.95    59.88
   1400x1050     74.76    59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     85.02    75.02    60.02
   1400x900      59.96    59.88
   1280x960      85.00    60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1280x800      59.99    59.97    59.81    59.91
   1152x864      75.00
   1280x720      60.00    59.99    59.86    59.74
   1024x768      85.00    75.05    60.04    85.00    75.03    70.07    60.00
   1024x768i     86.96
   960x720       85.00    75.00    60.00
   928x696       75.00    60.05
   896x672       75.05    60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   832x624       74.55
   960x540       59.96    59.99    59.63    59.82
   800x600       85.00    75.00    70.00    65.00    60.00    85.14    72.19    75.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       74.76    59.98
   800x450       59.95    59.82
   640x512       85.02    75.02    60.02
   700x450       59.96    59.88
   640x480       85.09    60.00    85.01    72.81    75.00    59.94
   720x405       59.51    58.99
   720x400       85.04
   684x384       59.88    59.85
   640x400       59.88    59.98    85.08
   576x432       75.00
   640x360       59.86    59.83    59.84    59.32
   640x350       85.08
   512x384       85.00    75.03    70.07    60.00
   512x384i      87.06
   512x288       60.00    59.92
   416x312       74.66
   480x270       59.63    59.82
   400x300       85.27    72.19    75.12    60.32    56.34
   432x243       59.92    59.57
   320x240       85.18    72.81    75.00    60.05
   360x202       59.51    59.13
   360x200       85.04
   320x200       85.27
   320x180       59.84    59.32
   320x175       85.27
   1920x1200     59.95*
   1600x1200     60.00
   1680x1050     59.88
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.90
   1280x720      60.00    50.00    59.94
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       60.00
   720x400       70.08
as you can my hdmi is limited. My other test
  • windows with same cable no problem my output is 3440*1440
  • an other computer + ubuntu + same cable my output is 3440*14400
it seems only with computer, i can use wayland if you think it better and if we can find a solution
regards
Hello i need some help…
I don’t have a real solution - but:
my nvidia 2070 works better with kernel 6.14…
sleep/resume etc. with kernel 6.14 and 570.140 driver is working reliable, but not with the 6.12 kernel on my notebook.
Probably you just give it a try and install kernel 6.14 in manjaro setting manager, reboot into this kernel and see whether it works or not.
Second idea (but I do not exactly know if it is still relevant as I did read somewhere that this is obsolet as the new driver uses this as a default - anyhow, it is not wrong):
append “nvidia_drm.modeset=1” in /etc/default/grub at the end of the options listed at “GRUB_CMDLINE_LINUX_DEFAULT=”…"
followed by a sudo update-grub and a reboot
hello i already on kernel 6.14 and i use wayland
your logs say 6.12
my news inxi -zv8
  Kernel: 6.14.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    base: Arch Linux
    date: 12/26/2024
  ID-1: BAT0 charge: 57.6 Wh (79.4%) condition: 72.5/73.0 Wh (99.3%)
    volts: 16.8 min: 15.5 model: Sunwoda L22D4PF4 type: Li-poly serial: <filter>
    status: not charging cycles: 44
  System RAM: total: 16 GiB available: 15.05 GiB used: 4.47 GiB (29.7%)
  Speed (MHz): avg: 2000 min/max: 400/4500:4800:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2000 2: 2000 3: 2000
    4: 2000 5: 2000 6: 2000 7: 2000 8: 2000 9: 2000 10: 2000 11: 2000 12: 2000
    13: 2000 14: 2000 15: 2000 16: 2000 17: 2000 18: 2000 19: 2000 20: 2000
    21: 2000 22: 2000 bogomips: 131788
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
    built: 2023+ ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:4 chip-ID: 174f:1820
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: Dell E2414H serial: <filter> built: 2014
    res: 1920x1080 dpi: 92 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.314 y: 0.620 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9
    modes: 1920x1080, 1600x900, 1280x1024, 1152x864, 1024x768, 800x600,
    640x480, 720x400
  Monitor-2: eDP-1 model: Samsung 0x4188 built: 2021 res: 2880x1800 dpi: 234
    gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
    x: 0.137 y: 0.047 white: x: 0.314 y: 0.329 size: 312x195mm (12.28x7.68")
    diag: 368mm (14.5") ratio: 16:10 modes: 2880x1800
    device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
    device-ID: 8086:7d55 memory: 7.35 GiB unified: yes display-ID: :0.0
    x11: xprop,xrandr
  API: ALSA v: k6.14.6-1-MANJARO status: kernel-api with: aoss
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:3
  IF: enp0s13f0u1u1 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 24.24 GiB (2.5%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51040C31 temp: 32.9 C
    scheme: GPT
    used: 24.2 GiB (8.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
    uuid: 7BB7-6A4E
  Hub-3: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
  Device-1: 2-1.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-5: 3-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
  Hub-6: 3-1.2:5 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 3-1.2.2:8 info: Alcor Micro Multi Flash Reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
  Device-2: 3-1.2.3:9 info: Dell USB Wired Entry Keyboard type: keyboard,HID
    chip-ID: 413c:2111 class-ID: 0300
  Device-3: 3-1.2.4:10 info: Primax Asus gaming Mouse (G112) type: mouse
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 0461:4d99 class-ID: 0301
  Device-4: 3-1.4:7 info: Alcor Micro Multi Flash Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 058f:6366 class-ID: 0806
    serial: <filter>
  Device-5: 3-5:3 info: Xiaomi Mi/Redmi series (MTP) type: <vendor specific>
    driver: usbfs interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 2717:ff40 class-ID: 0000 serial: <filter>
  Device-6: 3-9:4 info: Syntek Integrated Camera type: video
    serial: <filter>
  Device-7: 3-10:6 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
  Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Src: /sys System Temperatures: cpu: 51.0 C mobo: N/A
  Packages: 1254 pm: pacman pkgs: 1241 libs: 346
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 13
Processes:
  CPU top: 5 of 470
  1: cpu: 37.7% command: firefox pid: 2744 mem: 682.0 MiB (4.4%)
  2: cpu: 26.5% command: firefox pid: 2856 mem: 411.3 MiB (2.6%)
  3: cpu: 18.4% command: kgx pid: 3200 mem: 206.4 MiB (1.3%)
  4: cpu: 14.4% command: firefox pid: 2963 mem: 309.4 MiB (2.0%)
  5: cpu: 11.8% command: gnome-shell pid: 1824 mem: 346.1 MiB (2.2%)
  Memory top: 5 of 470
  1: mem: 707.3 MiB (4.5%) command: pamac-checkupdates pid: 2607 cpu: 8.5%
  2: mem: 682.0 MiB (4.4%) command: firefox pid: 2744 cpu: 37.7%
  3: mem: 411.3 MiB (2.6%) command: firefox pid: 2856 cpu: 26.5%
  4: mem: 346.1 MiB (2.2%) command: gnome-shell pid: 1824 cpu: 11.8%
  5: mem: 309.4 MiB (2.0%) command: firefox pid: 2963 cpu: 14.4%
  Processes: 470 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
  Compilers: gcc: 15.1.1 Shell: Bash v: 5.2.37 running-in: kgx inxi: 3.3.38
I have no further idea … sorry @yberges … hopefully some other might help
last comment, I just used Dr. Google:
did you see this?
https://wiki.archlinux.org/title/Kernel_mode_setting#Forcing_modes_and_EDID
I’m off now as I can not help anymore
outch too hard for me my linux skills are too limited no more help please
There’s also this :arrow_down:, it should work for X.
https://wiki.archlinux.org/title/Xrandr#Adding_undetected_resolutions
Not sure about Wayland.
as i understand i need to do this
$ xrandr --addmode hdmi 3440x1440_30.00 for testing this it ?
I just noticed you have hybrid graphics, it’s possible that you just need to use your dGPU instead of your iGPU. I’m not sure, as I don’t have an real experience with hybrid graphics. :man_shrugging:
I’ve never actually needed to do this, so I’m going from the Arch wiki and I haven’t tested it. As I said before this is for X, not wayland.
cvt 3440 1440
# or if you need 30Hz
cvt 3440 1440 30
# which should give you something like this:
# 3440x1440 59.94 Hz (CVT) hsync: 89.48 kHz; pclk: 419.50 MHz
Modeline "3440x1440_60.00"  419.50  3440 3696 4064 4688  1440 1443 1453 1493 -hsync +vsync
# take the modeline, minus  "Modeline", and add a new mode for xrandr
xrandr --newmode "3440x1440_60.00"  419.50  3440 3696 4064 4688  1440 1443 1453 1493 -hsync +vsync
# add that mode to the monitor
xrandr --addmode HDMI-1 3440x1440_60.00
# test it, this will switch to the new mode for 10s
# then switch back in case it doesn't work
xrandr --output HDMI-1 --mode 3440x1440_60.00 && sleep 10 && xrandr --output HDMI-1 --mode 1920x1200
# if it works then use it
Note that these settings only take effect during this session. See Autostarting#On Xorg startup for a way to automatically apply them on startup.
Why do you keep running xrandr commands when you are on Wayland?
xrandr does not work on Wayland. It is for the X11 display server, which Wayland does not use.
pamac info xorg-xrandr
Version               : 1.5.3-1
Description           : Primitive command line interface to RandR extension
URL                   : https://xorg.freedesktop.org/
Licenses              : HPND-sell-variant
Repository            : extra
Installed Size        : 75.5 kB
Groups                : xorg-apps xorg
Depends On            : libxrandr libx11 glibc
Optional Dependencies : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Andreas Radke <andyrtr@archlinux.org>
Build Date            : Fri 08 Nov 2024 16:42:03
Validated By          : MD5 Sum  SHA-256 Sum  Signature
pamac list -f xorg-xrandr
/usr/bin/xrandr
/usr/share/licenses/xorg-xrandr/COPYING
/usr/share/man/man1/xrandr.1.gz
I’m afraid that there are few, if any, xrandr alternatives for Wayland that work on Manjaro, due to Manjaro not supporting wlr-output-management-unstable-v1. The usual one I’ve seen recommended over the past year is wlr-randr, however you will most likely get this error if you try to run it:
wlr-randr
compositor doesn't support wlr-output-management-unstable-v1
Still, you might want to give it a go. Maybe it will work on your Gnome system (I’m on Plasma Wayland).
Edit: Here’s some further reading if you want to understand the difference between X11 & Wayland:
Article 1:
What Is Wayland on Linux, and How Is It Different From X? - How-To Geek
Article 2:
@scotty65 did i have “same” solution with wayland ?
I don’t understand what you mean with that comment.
You have posted 2 lots of inxi in this topic, with the first one (8 days ago) showing you as using X11, and latest one (2 days ago) showing you are on Wayland. I was looking at the most recent inxi when I posted that you cannot use xrandr on Wayland.
Could you please confirm what display environment you are using (X11 or Wayland)? You can check by running the following command:
echo $XDG_SESSION_TYPE
sorry i try to find a solution via a lot of ways … sometime user says to set x11 and sometime wayland
i can select what we need if we can found a solution solution
for now i am in wayland
