Bad quality icon sound/ battery
Hello, after reinstalling Manjaro Linux Gnome I ran into a problem sound icon when adjusting sound with f1 f2 f3 keys I attached a screenshot, also bad quality battery icon Im dont post photo but i can give link [ ttps://imgur.com/a/sQpxECi ] add “h” in start link
My guess is that you have a icon set that does not scale correctly or something else is wrong, try changing the icons options under appearance in the Tweaks tool.
what is your hardware?
I used laptop Dell Inspirion 15 (Intel core i5 7300HQ , Nvidia Geforce GTX 1050(4 gb) , 16 gb)
Thank you, I found the same icons only with a normal sound icon/battery icon
