If you mean something similar to ‘Time Machine’ on macOS, the short answer is no.
The software already mentioned share a common theme: they all rely on imaging your chosen drive (or partition); effectively cloning it. None of them are truly a backup solution, in the traditional sense.
That said, cloning a drive is an effective way to ‘backup everything’, and yes, booting with a dvd/usb is the safest way to restore the data.
CloneZilla is ideal for this.
Using gnome-disk-utility may allow easier restoration from the image; but I’ve never tried it, so don’t quote me. My opinion is that its just as easy to create a ‘tarball’ (or a zip archive) rather than the disk-utility method. Cheers.
