I was wondering if any one of you have ever had a backlight issue before which stops Manjaro from loading completely. Every now and then when I boot up my screen just stays black and displays:
[FAILED] Failed to start Light Display Manager
[FAILED] Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0
[FAILED] Failed to start Load/Save Screen Backlight Brightness of backlight:amdgpu_b10
When this happens I need to do a force shutdown to try again. It doesn’t happen all the time (maybe 3x a week) but it’s like playing russian roulette for me.
Could it be that it’s looking for something that doesn’t exist? Just a guess.
I’m using a Cinnamon 20.2 with the 5.9.16-1 kernel (5.10 won’t boot at all). I bought my laptop just last year and is an ASUS Zenbook with a R7 processor.
Here is info on my system:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=42a788d1-3fe8-4602-8fcf-4e18283760d9 rw quiet apparmor=1
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.24 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: ZenBook UX434DA_UM433DA v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX434DA v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX434DA_UM433DA.301 date: 08/02/2019
ID-1: BAT0 charge: 17.5 Wh condition: 44.2/50.0 Wh (88%) volts: 11.9/11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 622
RAM: total: 13.68 GiB used: 2.54 GiB (18.6%)
Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108109 L2 cache: 2 MiB
bogomips: 36738
Speed: 1221 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz):
1: 1221 2: 1220 3: 1221 4: 1221 5: 1218 6: 1223 7: 1222 8: 1221
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:15d8
Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus ID: 3-2:3 chip ID: 13d3:56cb serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 96 s-size: 847x286mm (33.3x11.3")
s-diag: 894mm (35.2")
Monitor-1: eDP res: 1280x800 hz: 60 dpi: 105 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus ID: 01:00.0 chip ID: 8086:24fd
Local Storage: total: 2.75 TiB used: 2.21 TiB (80.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-00000
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: EXA7301Q temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD My Passport 0741 size: 1.82 TiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 1022
ID-1: / raw size: 35 GiB size: 34.2 GiB (97.72%) used: 11.55 GiB (33.8%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 42a788d1-3fe8-4602-8fcf-4e18283760d9
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 25.1 MiB (26.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 2CBC-EA3E
ID-3: /home raw size: 550.87 GiB size: 541.22 GiB (98.25%)
used: 389.99 GiB (72.1%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: d3cfc03b-a5bc-448f-819f-de25ad3f02ec
ID-4: /run/media/enchance/Darkness raw size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.82 TiB (100.0%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: Darkness uuid: 7555F10D0FBB4159
ID-5: /run/timeshift/backup raw size: 550.87 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: df8eed30-ad13-4e26-98e6-c2649602f5ce
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: N/A
uuid: 629C301A9C2FE6EF
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: ext4 label: N/A
uuid: 5b64da61-71ef-44e4-9a1f-2ac3f4a6797a
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 259.37 GiB fs: ntfs label: N/A
uuid: 0E70C89C70C88BC1
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 100 GiB fs: ntfs label: N/A
uuid: 78C354BA13EDCE44
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Hoksi DURGOD Taurus K320 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 2f68:0082
Hub-2: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 05e3:0610
Device-1: 1-3.1:6 info: Western Digital My Passport Ultra type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 1058:0741 serial: <filter>
Device-2: 1-3.3:5 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 30fa:0300
Device-3: 1-4:4 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2b
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-2: 3-2:3 info: IMC Networks USB2.0 HD IR UVC WebCam type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56cb
serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 53.6 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): cpu: 2300
Processes: 297 Uptime: 31m wakeups: 4 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1208 lib: 361 flatpak: 0 Shell: Bash v: 5.1.0
running in: terminator inxi: 3.2.02
Welcome to Manjaro!
