Hello folks ![]()
I have bought a new laptop (Asus Scar 15 G533QS) and faced with a problem - awful sound quality through the speakers. Sound good only if I use earphones. On windows I don’t have this problem. I have tried different distros (Xubuntu, Fedora, Mint) to check if this problem exist on them, and yes, it does. All my music via speakers sounds like from barrel with 16-32kbps.
Would be grateful for any help.
inxi -Fza
Kernel: 6.7.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.7-x86_64
root=UUID=db7642e9-3dca-4011-bf50-1b20d70499da rw rootflags=subvol=@
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: ASUSTeK product: ROG Strix G533QS_G533QS v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G533QS v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G533QS.331
date: 02/24/2023
ID-1: BAT0 charge: 90.7 Wh (98.9%) condition: 91.7/90.0 Wh (101.8%)
power: 4.8 W volts: 17.6 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
serial: <filter> status: charging
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000B
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 607 high: 2537 min/max: 400/4890 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 2537 9: 1580 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 105448
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: ASUSTeK driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm
non-free: 545.xx+ status: current (as of 2024-02; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:249c class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 52.0 C
Display: x11 server: X.org v: 1.21.1.11 compositor: xfwm4 v: 4.18.0
driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: TL156VDXP0101 built: 2021 res: 1920x1080 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.3.5-manjaro1.1
renoir LLVM 16.0.6 DRM 3.57 6.7.4-2-MANJARO) device-ID: 1002:1638
memory: 500 MiB unified: no
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.7.4-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Info: services: NetworkManager,wpa_supplicant
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 13d3:3563
Local Storage: total: 4.57 TiB used: 983.91 GiB (21.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S4000G
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK1N.1 temp: 44.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 44.9 C scheme: GPT
ID-1: / raw-size: 150 GiB size: 150 GiB (100.00%) used: 21.67 GiB (14.4%)
fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:7
used: 15.4 MiB (16.0%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 150 GiB size: 150 GiB (100.00%)
used: 21.67 GiB (14.4%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:7
ID-4: /var/log raw-size: 150 GiB size: 150 GiB (100.00%)
System Temperatures: cpu: 62.0 C mobo: 46.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): cpu: 2200
Memory: total: 64 GiB note: est. available: 62.23 GiB used: 3.54 GiB (5.7%)
Processes: 393 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 24.86 GiB services: upowerd,xfce4-power-manager Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1197 libs: 347 tools: pamac Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26 running-in: xfce4-terminal
inxi: 3.3.33
