I was curious if there’s a setting to keep ~/.bash_history from recording identical commands. So if you type the same thing many times in a row inside a console (Konsole in my case) it doesn’t add an entry each time, only once until you type something different. This can cause it to fill up pretty quickly and require more scrolling up to find an older command.
In addition, I was wondering if I could disable the console in Dolphin from creating pointless entries. I noticed that whenever I press F4 in the file browser to show its console I get random commands like “cd” and “clear” logged there except they start with a space.
However, that will not ignore duplicates which are separated by another command. It’ll only ignore successive invocations of the same command. And, it also allows for commands that start with a space to be excluded from the shell history.
