Avidemux keeps getting hallucination , it's not showing video
Avidemux not showing video , but instead displays a “ghost” image of whatever window was sitting behind it in my case browser
  Kernel: 6.1.165-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=f2158531-513d-457e-99eb-962cabe45fbd rw quiet apparmor=1
    security=apparmor resume=UUID=d4a2bbfe-f657-4b6d-ad7b-291b32ce3bb1
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Dell model: 0FGN4M v: A00 serial: <superuser required> part-nu: 078C
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 2.10.0
    date: 05/10/2019
  ID-1: BAT0 charge: 13.3 Wh (43.8%) condition: 30.3/41.4 Wh (73.1%)
    volts: 15.06 min: 14.8 model: LGC-LGC2.80 DELL 7PY0D37 type: Li-ion
    serial: <filter> charging: status: charging cycles: N/A
  System RAM: total: 8 GiB available: 7.63 GiB used: 2.71 GiB (35.5%)
  Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 4 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMA851S6AFR6N-UH serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
    manufacturer: 80CE000080CE part-no: M471A5244BB0-CRC serial: <filter>
  Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 402 min/max: 400/2000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 402 2: 402 3: 402 4: 402 bogomips: 16006
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb
    ibpb_exit_to_user ibrs intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake-U GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
    chip-ID: 1bcf:28c0 class-ID: 0e02
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0690 built: 2015 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.349 green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white:
    x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 7.45 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 6 device: 0 type: integrated-gpu name: Intel
    HD Graphics 520 (SKL GT2) driver: mesa intel v: 26.0.2-arch1.1
    device-ID: 8086:1916 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl
    bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.1.165-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-98-gb096 status: active with:
    tools: pacat,pactl
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
  IP v6: <filter> type: noprefixroute scope: global
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 0cf3:e009
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 836.54 GiB (89.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1002 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 82.63 GiB (84.4%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: f2158531-513d-457e-99eb-962cabe45fbd
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 6699-007E
  ID-3: /mnt/be9fd59c-519e-4b50-a158-0e15e4410673 raw-size: 822.42 GiB
    size: 808.43 GiB (98.30%) used: 753.89 GiB (93.3%) fs: ext4 dev: /dev/sda4
    maj-min: 8:4 label: N/A uuid: be9fd59c-519e-4b50-a158-0e15e4410673
  ID-1: swap-1 type: partition size: 8.59 GiB used: 12.7 MiB (0.1%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: d4a2bbfe-f657-4b6d-ad7b-291b32ce3bb1
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Sunplus Innovation Integrated_Webcam_HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:28c0 class-ID: 0e02
  Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-3: 1-8:4 info: Qualcomm Atheros type: bluetooth driver: btusb
    power: 100mA chip-ID: 0cf3:e009 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 42.0 C pch: 43.0 C mobo: 43.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: 1760 pm: pacman pkgs: 1754 libs: 478 tools: pamac pm: snap pkgs: 6
    1: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    5: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    6: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    8: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 211
  1: cpu: 100% command: ps pid: 9396 mem: 3.99 MiB (0.0%)
  2: cpu: 21.3% command: chromium pid: 9210 mem: 284.8 MiB (3.6%)
  3: cpu: 8.0% command: zsh pid: 9323 mem: 15.6 MiB (0.2%)
  4: cpu: 6.2% command: konsole pid: 9308 mem: 216.0 MiB (2.7%)
  5: cpu: 5.9% command: chromium pid: 8852 mem: 254.7 MiB (3.2%)
  Memory top: 5 of 211
  1: mem: 434.0 MiB (5.5%) command: chromium pid: 8556 cpu: 5.3%
  2: mem: 399.3 MiB (5.1%) command: plasmashell pid: 1337 cpu: 1.7%
  3: mem: 284.8 MiB (3.6%) command: chromium pid: 9210 cpu: 21.3%
  4: mem: 282.3 MiB (3.6%) command: K started-by: avidemux3_qt5 pid: 9129
    cpu: 1.0%
  5: mem: 279.8 MiB (3.5%) command: dolphin pid: 8986 cpu: 0.9%
  Processes: 211 Power: uptime: 3h 18m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 259 default: graphical tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
I think it has to do with my display session and right now I’m on wayland .
So I try to switch to x11 but I can’t since it’s not available on sddm session
Your system is not up-to-date, as linux61 is now on version 6.1.170-1 in Stable branch.
Also, Stable branch is currently on version 6.6.4-1 of Plasma
So, try updating your system, reboot, and see if the issue still occurs:
sudo pacman -Syu
Also, you might want to try a newer LTS kernel such as linux66, linux612 or linux618 due to polkit issues with kernel linux61 & earlier, as has been mentioned in the Known Issues section of each update announcement since the beginning of this year:
[Stable Update] 2026-05-02 - Kernels, Plasma, GNOME, Mesa, Systemd, VirtualBox, LibreOffice - #2 by discobot.
You can list kernels which are available for installation by running:
mhwd-kernel -l
To install a kernel (for example, linux618):
sudo mhwd-kernel -i linux618
After you have installed the newer kernel, reboot. Your system should automatically boot into the most recent kernel version.
Plasma defaults to Wayland now, and you will need to install the plasma-x11-session package if you want to access an x11 session. Note though, that X11 support will be completely removed from Plasma when v6.8 is released in the first quarter of 2027.
Yes, I have had that issue for some time, I think avidemux is not wayland ready.
A couple of suggestions I found in a Zorin Forum thread via a Google search:
I’ve never cared enough to go find out. It’s not an app I use. I’ll check out the ‘fix’
No need to switch to X11.
the following works fine under wayland
avidemux3_qt5 --platform 'xcb' %f
So in the Plasma Menu editor for avidemux add the following to the command-line arguments field
--platform 'xcb' %f
The application loads fine and loads the requested video file.
Thank you
