$ ffmpeg -h encoder=av1_nvenc
ffmpeg version n5.1.2 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 12.2.0 (GCC)
configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-amf --enable-avisynth --enable-cuda-llvm --enable-lto --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libdav1d --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libiec61883 --enable-libjack --enable-libmfx --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librav1e --enable-librsvg --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-libzimg --enable-nvdec --enable-nvenc --enable-opencl --enable-opengl --enable-shared --enable-version3 --enable-vulkan
libavutil 57. 28.100 / 57. 28.100
libavcodec 59. 37.100 / 59. 37.100
libavformat 59. 27.100 / 59. 27.100
libavdevice 59. 7.100 / 59. 7.100
libavfilter 8. 44.100 / 8. 44.100
libswscale 6. 7.100 / 6. 7.100
libswresample 4. 7.100 / 4. 7.100
libpostproc 56. 6.100 / 56. 6.100
Codec 'av1_nvenc' is not recognized by FFmpeg.
This encoder is supposed to be present since libavcodec 52.
https://git.ffmpeg.org/gitweb/ffmpeg.git/commit/5c288a44ad16087c3d3a7563490cb634790e751f
Olli
5 January 2023 12:56
2
may you check if this 3 packages are installed
dav1d
rav1e
svt-av1
$ pacman -S dav1d rav1e svt-av1
warning: dav1d-1.0.0-1 is up to date -- reinstalling
warning: rav1e-0.6.1-1 is up to date -- reinstalling
warning: svt-av1-1.4.1-1 is up to date -- reinstalling
Zesko
5 January 2023 13:09
4
No, he means the libs
$ ffmpeg -i {INPUT}.mp4 vcodec libsvtav1 {OUTPUT}.mkv
But it does not use hardware acceleration of Nvidia.
Zesko
5 January 2023 13:16
5
Do you use Nvidia 4000 series?
There is no AV1 codec hardware acceleration when using older than Nvidia 3000 series.
Nvidia 3000 series supports AV1 decode only, not AV1 encode.
Nvidia 4000 series fully supports AV1.
$ ffmpeg -i 020123-022541.mp4 -c:v libsvtav1 test.mkv
ffmpeg version N-109530-g4a80db5fc2 Copyright (c) 2000-2023 the FFmpeg developers
configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-amf --enable-avisynth --enable-cuda-llvm --enable-lto --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libdav1d --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libiec61883 --enable-libjack --enable-libmfx --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librav1e --enable-librsvg --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-libzimg --enable-nvdec --enable-nvenc --enable-shared --enable-version3
libavutil 57. 43.100 / 57. 43.100
libavcodec 59. 56.100 / 59. 56.100
libavformat 59. 34.102 / 59. 34.102
libavdevice 59. 8.101 / 59. 8.101
libavfilter 8. 53.100 / 8. 53.100
libswscale 6. 8.112 / 6. 8.112
libswresample 4. 9.100 / 4. 9.100
libpostproc 56. 7.100 / 56. 7.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '020123-022541.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf59.27.100
Duration: 00:00:05.55, start: 0.000000, bitrate: 1614 kb/s
Stream #0:0[0x1](und): Video: h264 (High 4:4:4 Predictive) (avc1 / 0x31637661), yuv444p(tv, bt2020nc/bt709/bt470m, progressive), 2560x1440 [SAR 1:1 DAR 16:9], 1479 kb/s, 60 fps, 60 tbr, 15360 tbn (default)
Metadata:
handler_name : VideoHandler
vendor_id : [0][0][0][0]
encoder : Lavc59.37.100 h264_nvenc
Stream #0:1[0x2](und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 131 kb/s (default)
Metadata:
handler_name : SoundHandler
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> av1 (libsvtav1))
Stream #0:1 -> #0:1 (aac (native) -> vorbis (libvorbis))
Press [q] to stop, [?] for help
Svt[info]: -------------------------------------------
Svt[info]: SVT [version]: SVT-AV1 Encoder Lib v1.4.1-dirty
Svt[info]: SVT [build] : GCC 12.2.0 64 bit
Svt[info]: LIB Build date: Dec 14 2022 06:04:17
Svt[info]: Number of logical cores available: 16
Svt[info]: Number of PPCS 135
Svt[info]: [asm level on system : up to avx2]
Svt[info]: [asm level selected : up to avx2]
Svt[info]: SVT [config]: main profile tier (auto) level (auto)
Svt[info]: SVT [config]: width / height / fps numerator / fps denominator : 2560 / 1440 / 60 / 1
Svt[info]: SVT [config]: bit-depth / color format : 8 / YUV420
Svt[info]: SVT [config]: preset / tune / pred struct : 10 / PSNR / random access
Svt[info]: SVT [config]: gop size / mini-gop size / key-frame type : 321 / 32 / key frame
Svt[info]: SVT [config]: BRC mode / rate factor : CRF / 35
SvtMalloc[info]: SVT Memory Usage:
SvtMalloc[info]: total allocated memory: 3.90 GB
SvtMalloc[info]: malloced memory: 1.09 GB
SvtMalloc[info]: callocated memory: 359.38 MB
SvtMalloc[info]: allocated aligned memory: 2.45 GB
SvtMalloc[info]: mutex count: 27171
SvtMalloc[info]: semaphore count: 3274
SvtMalloc[info]: thread count: 799
SvtMalloc[info]: hash table fulless: 0.226559, hash bucket is healthy
SvtMalloc[info]: top 10 malloced memory locations:
SvtMalloc[info]: (313.89 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbCodingUnit.c:121
SvtMalloc[info]: (157.51 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:124
SvtMalloc[info]: (130.52 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:1586
SvtMalloc[info]: (91.58 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Common/Codec/EbBitstreamUnit.c:36
SvtMalloc[info]: (88.60 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:125
SvtMalloc[info]: (72.51 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:1590
SvtMalloc[info]: (53.31 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbModeDecisionProcess.c:215
SvtMalloc[info]: (35.94 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:1201
SvtMalloc[info]: (28.75 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:1178
SvtMalloc[info]: (17.97 MB): /build/svt-av1/src/SVT-AV1/Source/Lib/Encoder/Codec/EbPictureControlSet.c:1174
Output #0, matroska, to 'test.mkv':
Metadata:
major_brand : isom
minor_version : 512
encoder : Lavf59.34.102
Stream #0:0(und): Video: av1 (AV01 / 0x31305641), yuv420p(tv, bt2020nc/bt709/bt470m, progressive), 2560x1440 [SAR 1:1 DAR 16:9], q=2-31, 60 fps, 1k tbn (default)
Metadata:
encoder : Lavc59.56.100 libsvtav1
Stream #0:1(und): Audio: vorbis (oV[0][0] / 0x566F), 48000 Hz, stereo, fltp (default)
Metadata:
encoder : Lavc59.56.100 libvorbis
[libvorbis @ 0x55fb277b41c0] Queue input is backward in timeitrate= 213.3kbits/s speed=0.181x
Last message repeated 10 times
frame= 333 fps= 67 q=35.0 Lsize= 750kB time=00:00:05.53 bitrate=1110.9kbits/s speed=1.12x
video:639kB audio:99kB subtitle:0kB other streams:0kB global headers:4kB muxing overhead: 1.642042%
SvtMalloc[info]: you have no memory leak
I am using an nvidia 3000 series card, but even if that is the case, should ffmpeg not include the option and just fail when I try to run it?
Olli
5 January 2023 13:26
7
@Zesko , @rabcor
is it possible that you have to uninstall the ffmpeg-package and install the ffmpeg-full-git from aur ? just a question from me. maybe @Zesko or others can answer.
Zesko
5 January 2023 13:27
8
rabcor:
That looks you have the limit of memory size. What size is your RAM? Did you enable Swap?
ffmpeg uses the lib libsvtav1
from the package svt-av1
that does not use Nvidia hardware acceleration, but your CPU and RAM.
Your Nvidia 3000 series does not have the ability AV1 encode.
See the wiki
32GB RAM, no swap, although i should probably enable that been lazy about getting around to it.
Olli
5 January 2023 13:45
10
there’s no need to enable swap if you’re running 32 GB RAM with even some extraordinary use. if so use a swapfile, that’s a far better than a swap-partition.
Zesko
5 January 2023 13:55
11
Sorry, you can ignore this message. I can reproduce it, but it is not error after video conversion without any issue
rabcor
5 January 2023 14:46
12
Yeah it is not an error, no memory leak is a good thing.
system
Closed
8 January 2023 04:46
13
