Hello,
I am trying to make a autostart script with the following command.
xset r rate 250 70
I have tried making a /etc/rc.local file with
#! /bin/bash
/usr/local/sbin/my-startup.sh
exit 0
#! /bin/sh
xset r rate 250 70
both files has chmod +x
Hi @Xlippo ,
I know that can be done with a systemd startup unit script. However, I’ve not done it yet. I have, however, an auto start script as well.
Just move/copy/symlink you script to ~/.config/plasma-workspace/env:
$ mv <currentScriptLocation>/my-startup.sh ~/.config/plasma-workspace/env/my-startup.sh
Well, that’s what I had to do for KDE anyway. Not sure 'bout other DEs. Neither to make it system-wide, but it’s limited to my user on purpose.
Hope this helps!
Thank you!
I tried making a service as you said.
/etc/systemd/system/my-startup.service
[Unit]
Description=My Startup
PartOf=graphical-session-target
[Service]
ExecStart=/usr/local/sbin/my-startup.sh
[Install]
WantedBy=graphical-session.target
â—Ź my-startup.service - My Startup
Loaded: loaded (/etc/systemd/system/my-startup.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Mar 03 15:45:18 manjaro systemd[1]: /etc/systemd/system/my-startup.service:3: Failed to add dependency on graphical-session-target, ignoring: Invalid argument
I have also tried with;
[Unit]
[Service]
[Install]
WantedBy=multi-user.target
But got error message that it cannot run xset r rate without graphical session. So it probably executed the file before graphical session started…?
I have also tried making a cron job
crontab -l
@reboot /usr/local/sbin/my-startup.sh
Xset requires xorg to be running. Your scripts run before xorg is online. Instead of systemd service, I suggest using your desktops inbuilt autostart functionality.
Hi,
I made a .desktop file in ~/home/.config/autostart
[Desktop Entry]
Name=my-startup
Exec=’/home/r/.config/autostart/my-startup.sh’
Terminal=false
Type=Application
StartupNotify=false
X-GNOME-Autostart-enabled=true
What am I doing wrong?
When I do
exec '/home/r/.config/autostart/my-startup.sh'
in the terminal it works. Must mean something is wrong with the .desktop file…?
Solved. It needed these entries in the .desktop file. Thanks!
[Desktop Entry]
Name=my-startup
GenericName=my-startup
Comment=Startup script
Exec='/home/r/.config/autostart/my-startup.sh'
Terminal=false
Type=Application
system
Closed
18 March 2021 19:45
10
