Hello, i tried some guides here and there but i cant get a script to run at boot. This script needs to execute a program in terminal. I tried both through the xfce settings manager and by pasting the script in config/autostart but nothing happens.
How to do?
Welcome to the forum!
I’m afraid we can’t really give you any advice without seeing the script. Type three backticks (```) on a new line, and paste the script underneath. Then put another line with three backticks below the script. This makes it more readable for everyone.
Hi!
You want to run your script in a Terminal at startup?
The script is executable?
It works as expected when you start it from a terminal?
What you’d need to do at startup/login is the same thing:
first start a terminal - and give it the script you wan to run in it
something like:
xfce4-terminal -e ’/path/to/script’ &
If that does what you want you can then put that command in the autostart.
HTH
It worked. In the xfce session&startup manager i originally input as new command
sh scriptname.sh
instead of plain
scriptname.sh
However thanks
yepp - if the script location is in your $PATH the script runs, without a terminal to run it in to provide feedback/output
I would have put:
sh -x script_name
so it would run without being marked executable
and perhaps even if the script didn’t contain:
#!/bin/sh
or
#!/bin/bash
as the first line
I don’t know what
sh
is calling in Manjaro - probably bash, but could be zsh
