I just installed the KDE version of Manjaro on a partition of my laptop. It’s an 2 in 1 laptop with a reversible monitor.
So I installed iio-sensor-proxy and the git version of screenrotator. Now on Plasma, the rotation of the screen works well but not on the SDDM login screen.
I tried to add the executable command screenrotator in this file /usr/share/sddm/scripts/Xsetup:
#!/bin/sh
# Xsetup - run as root before the login dialog appears
screenrotator
But it didn’t work. I don"t if screenrotator has been started on the SDDM Login screen or if it must be started with some options.
[LinkToAnswer]
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
