Automount Partitions
Hey all!
I would like to know if there is any utility that automounts disk partitions. I know I can use fstab but if I don’t have the disk plugged in or it is corrupted my computer goes into emergency mode. I would rather have a utility that mounts when it senses the drive is connected. I do not have a desktop so any gui application would not help either.
https://wiki.archlinux.org/title/Fstab#Automount_with_systemd
Hi @Linuxious,
Have a look at [root tip] Use systemd to mount ANY device
I believe that will be your answer.
Thanks guys! I think this solved it!
