Automount failing
Hello, since yesterday’s update I experience a similar issue with automount failing:
-- Boot 94d97f5b2a17431ba67061899f46149a --
Mai 15 16:51:09 manjaro systemd[1]: Starting Automounts filesystems on demand...
Mai 15 16:51:09 manjaro (utomount)[1393]: autofs.service: Referenced but unset environment variable evaluates to an empty string: OPTIONS
Mai 15 16:51:09 manjaro systemd[1]: Started Automounts filesystems on demand.
Mai 16 14:13:52 manjaro systemd[1]: Stopping Automounts filesystems on demand...
Mai 16 14:13:52 manjaro systemd[1]: autofs.service: Deactivated successfully.
Mai 16 14:13:52 manjaro systemd[1]: Stopped Automounts filesystems on demand.
-- Boot f7b49a824cac4678a303e55ad95dbb42 --
Mai 17 16:36:33 manjaro systemd[1]: Starting Automounts filesystems on demand...
Mai 17 16:36:33 manjaro (utomount)[1910]: autofs.service: Referenced but unset environment variable evaluates to an empty string: OPTIONS
Mai 17 16:36:33 manjaro automount[1910]: /usr/bin/automount: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
Mai 17 16:36:33 manjaro systemd[1]: autofs.service: Main process exited, code=exited, status=127/n/a
Mai 17 16:36:33 manjaro systemd[1]: autofs.service: Failed with result 'exit-code'.
Mai 17 16:36:33 manjaro systemd[1]: Failed to start Automounts filesystems on demand.
Can this be related? Would the pamac history help to isolate?
Markus
Do you happen to have the autofs package from the AUR installed? That seems to be the one which provides the systemd autofs.service. If so, then you may need to rebuild it against the updated libxml2 library:
pamac build autofs
AUR (en) - autofs - A kernel-based automounter for Linux
Wow, your reply time is almost speed of light!
Thanx a lot, I’lll try later!
Your posts have been moved to a dedicated topic.
I note that your issue doesn’t seem to share anything remotely similar to the other member’s topic which you hijacked - adding your issue to another member’s topic is generally discouraged.
Please provide system information as described (below). Links are also provided to help understand forum guidelines for content and presentation.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
If that doesn’t work then you could install libxml2-legacy.
