Automating sound activation for droidcam
A problem regarding sound:
Using this command will correctly make the sound work:
$ pacmd load-module module-alsa-source device=$HW
But whenever I disconnect and reconnect the app after a few days I will need to use the command to make the sound work correctly. In other words, every time I need to use this command.
Is there any permanent solution for it?
You can edit ~/.config/pulse/default.pa and add the line:
Also, look at the global version, which is /etc/pulse/default.pa on my system, to see what else could go in this file.
More on PulseAudio/Examples - ArchWiki
It didn’t solve the problem unfortunately and still, I need to use the command every time.
