hi guys, problem with automatic operation of the vol service, i installed netctl, но выходит ошибка
netctl start WoL
Job for netctl@WoL.service failed because the control process exited with error code.
See “systemctl status netctl@WoL.service” and “journalctl -xeu netctl@WoL.service” for details.
Hi, it will help if you post the output of inxi -zv8
and the outputs of those suggested commands; highlight each of these outputs and click the </> button at the top of the reply window, as this will present the results in scrollable formatted boxes making it easier to read.
Cheers!
in the top row of the editor window - where you just pasted your inxi result into
mark your text again, then use this button to format it
it will then look like you saw it in your terminal
inxi -zv8
Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=e7c041f7-0b17-497e-8592-43928a9198e1 rw quiet splash
resume=UUID=217685ba-bac9-4b9a-8e5c-e658790bf674 udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: Micro-Star product: MS-7A38 v: 2.0
serial:
Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: uuid: UEFI: American
Megatrends LLC. v: A.L4 date: 05/17/2023
System RAM: total: 16 GiB available: 15.54 GiB used: 5.03 GiB (32.4%)
Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: HX432C16FB3/16 serial:
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: no module installed
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 1722 min/max: 550/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1722 2: 1722 3: 1722
4: 1722 5: 1722 6: 1722 7: 1722 8: 1722 9: 1722 10: 1722 11: 1722 12: 1722
bogomips: 86440
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com.
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 29:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: HDMI-0 res: 2560x1440 hz: 100 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 550.135 device-ID: 10de:1c82
surfaces: xcb,xlib
Device-1: NVIDIA GP107GL High Definition Audio vendor: eVga.com.
bus-ID: 29:00.1 chip-ID: 10de:0fb9 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
IF-ID-1: neko-tun state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v4: scope: global broadcast:
IP v6: virtual: stable-privacy proto kernel_ll scope: link
IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A mac:
IP v6: virtual: proto kernel_ll scope: link
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac:
IF-ID-4: ztnfagsh7e state: unknown speed: 10000 Mbps duplex: full
mac:
Info: services: NetworkManager, smbd, systemd-networkd, systemd-timesyncd
WAN IP:
Local Storage: total: 447.13 GiB used: 351.1 GiB (78.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: B1E1 scheme: GPT
ID-1: / raw-size: 438.93 GiB size: 430.97 GiB (98.19%)
used: 351.1 GiB (81.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: e7c041f7-0b17-497e-8592-43928a9198e1
ID-2: /boot/efi raw-size: 401 MiB size: 400.2 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 4856-C725
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 217685ba-bac9-4b9a-8e5c-e658790bf674
Device-1: 3-3:2 info: Corsair Gaming K55 RGB Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300
serial:
Device-2: 3-4:3 info: A4Tech USB Device type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:3782 class-ID: 0300
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Packages: pm: pacman pkgs: 1351 libs: 379 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
2: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
3: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
5: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
6: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
7: https://mirror.easyname.at/manjaro/stable/$repo/$arch
8: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
9: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
10: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
11: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
12: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
13: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
14: https://mirror.zetup.net/manjaro/stable/$repo/$arch
15: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
16: https://muug.ca/mirror/manjaro/stable/$repo/$arch
17: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
18: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
19: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
20: https://mirror.funami.tech/manjaro/stable/$repo/$arch
21: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
24: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
25: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
26: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
27: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
28: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
29: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
30: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
31: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
32: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
33: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
34: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
35: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
36: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
38: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
39: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
40: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
41: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
42: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
43: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
44: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirror.23m.com/manjaro/stable/$repo/$arch
46: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
47: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
48: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
49: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
50: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
51: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
52: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
53: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
54: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
55: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
56: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
57: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
58: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
60: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
61: https://linorg.usp.br/manjaro/stable/$repo/$arch
62: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
63: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
64: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
65: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
66: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
67: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
68: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
69: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
70: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
71: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
72: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
73: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
74: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
75: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
76: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
77: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
78: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
79: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
80: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
81: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
82: http://mirror.fcix.net/manjaro/stable/$repo/$arch
83: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
84: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
85: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
86: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
87: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
88: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://mirror.dc.uz/manjaro/stable/$repo/$arch
90: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
91: http://manjaro.mirror.ac.za/stable/$repo/$arch
92: http://manjaro.grena.ge/stable/$repo/$arch
93: https://manjaro.ynh.ovh/stable/$repo/$arch
94: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
95: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
96: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
98: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
99: https://mirror.init7.net/manjaro/stable/$repo/$arch
100: https://mirrors.manjaro.org/repo/stable/$repo/$arch
101: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
102: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
103: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
104: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
105: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
106: https://mirrors2.manjaro.org/stable/$repo/$arch
107: https://manjaro.kurdy.org/stable/$repo/$arch
108: https://mirror.koddos.net/manjaro/stable/$repo/$arch
109: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
110: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
111: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
112: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
113: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
114: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 376
1: cpu: 26.7% command: chrome pid: 1811 mem: 553.1 MiB (3.4%)
2: cpu: 21.0% command: chrome pid: 1898 mem: 355.7 MiB (2.2%)
3: cpu: 18.0% command: chrome pid: 2257 mem: 363.2 MiB (2.2%)
4: cpu: 16.2% command: chrome pid: 2514 mem: 298.4 MiB (1.8%)
5: cpu: 15.5% command: konsole pid: 2839 mem: 158.2 MiB (0.9%)
Memory top: 5 of 376
1: mem: 553.1 MiB (3.4%) command: chrome pid: 1811 cpu: 26.7%
2: mem: 503.0 MiB (3.1%) command: plasmashell pid: 928 cpu: 3.1%
3: mem: 477.2 MiB (2.9%) command: chrome pid: 2355 cpu: 12.1%
4: mem: 363.2 MiB (2.2%) command: chrome pid: 2257 cpu: 18.0%
5: mem: 355.7 MiB (2.2%) command: chrome pid: 1898 cpu: 21.0%
Processes: 376 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
I have wake on lan working via cron, but I would like to learn how to do it via netctl, via systemd it is very easy, I don’t even want to try, it is a standard unit that is configured easily
I can’t contribute any knowledge about WOL.
sorry bro(((
