Hi, manjaro gnome does not suffer from random freezes like manjaro kde, so I switched to gnome
how to hibernate to disk on lid close and automatically when not in use in a period of time ?
hibernate to disk on power button press works
Hello @ahmed-derbala and welcome
File: /etc/systemd/logind.conf
HandleLidSwitch=hibernate
HandleLidSwitch=suspend-then-hibernate
File: /etc/systemd/sleep.conf
HibernateDelaySec=180min
Test it: sudo systemctl suspend-then-hibernate
This works not everywhere and depends on firmware support.
Gnome3 has no GUI support for handling this. It has only “suspend after a period of time”.
FYI, hibernation is not enabled by default and requires manual setup. See Power management/Suspend and hibernate - ArchWiki
thank you
I see no /etc/systemctl/logind.conf file already created, even /etc/systemctl does not exist
do you mean /etc/systemd/logind.conf ?
i already tested these values in /etc/systemd/logind.conf
HandleLidSwitchExternalPower=hibernate
HandleLidSwitchDocked=hibernate
IdleAction=hibernate
IdleActionSec=30min
but it seems that /etc/systemd/logind.conf is being ignored. i removed # on the start of each of these lines
the option in settings > power > power button behavior > set to hibernate works , so when i press power button, my pc hibernate successfully and i can resume after
in KDE, automatic hibernate and hibernate on lid close were working flawlessly
Did you reboot afterward?
FYI, it’s better to use an override in /etc/systemd/logind.conf.d/
instead of directly editing the original file; i.e., /etc/systemd/logind.conf.d/custom.conf
. See logind.conf(5) — Arch manual pages
yes, i rebooted
with creating /etc/systemd/logind.conf.d/logind.conf now my pc goes to hibernate after 30 minutes , but lid close still doesnt work
Is there a way to replicate the same behavior for the normal menu shutdown or the power button press, not just the lid closing?
For the button press, I tried adding
HandlePowerKey=suspend-then-hibernate
to “/etc/systemd/logind.conf” but that didn’t work. I’m using Manjaro gnome too.
to hibernate on buton press, you can choose in settings > power > power button behavior
creating /etc/systemd/logind.conf.d/logind.conf.d fixed the issues
