I set my prefs to auto log in at power up, how do I set it to require password?
What Desktop are you using?
Appologies XFCE
Sorry, I had to dig up one of the old forums.
Look for autologin-user and put a # before it.
I noticed (old post no longer valid) so
#autologin-user=??? did the trick.
Thanks ![]()
Just wondering, maybe I’ll be told to start another thread, is there a way to make the little box go away, I want a terminal style flashing cursor top left at log in, any ideas?
This is preferred as your question got answered and solved.
If you want a terminal/textual login - disable your display manager (service). You would have to start the graphical environment manually after login afterwards.
Nice catch. I had to read that post again.
