I checked the most recent Announcement posts and searched the forum before posting, but the same topic was dealt with only back in 2023, and the solution from 2023 did not work for me (not a surprise)
Just yesterday I decided to update my Manjaro, KDE Plasma.
System info:
KDE Plasma Version: 6.5.4
KDE Frameworks Version: 6.21.0
Qt Version: 6.10.1
Kernel Version: 6.1.159-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × Intel® Xeon® E-2176M CPU @ 2.70GHz
Memory: 32 GiB of RAM (30.8 GiB usable)
There were more than 800 updates.
Things went well for most of them, but for 24 (BetterBird, CoreImage, Corepaint, Heroic, ZOOM, and some system updates - in total I see 24 not successful) I get a message “Authentication failed” and nothing can be done about it.
mirrors updated, but still things do not work, as they should - first time such a problem
All of those appear to be AUR packages, so you might be best updating them separately after doing a system update. Because of the polkit authorisation issue, follow the instructions in the post above to install a more recent kernel, reboot into it, and then see if you can update normally via your usual method.
Note though that Heroic is a little unusual, as both the Manjaro repos & the AUR contain a package with the same name: heroic-games-launcher. If that package is installed, make sure you have the version from the repos (v2.18.1-8), not the one in the AUR (v2.18.1-2):
pamac search heroic-games-launcher
heroic-games-launcher-git 2.18.1.r18.gd827d7053-2 AUR
Native GOG, Epic Games and Amazon games launcher for Linux
heroic-games-launcher-electron-git 2.18.1.r57.g645fae05a-1 AUR
Native GOG, Epic Games and Amazon games launcher. Development version
(Git) using system Electron.
heroic-games-launcher-bin 2.18.1-3 AUR
An Open source Launcher for Epic, Amazon and GOG Games
heroic-games-launcher 2.18.1-2 AUR
heroic-games-launcher 2.18.1-8 extra
Great! I did not know that this is a common issue currently.
I used to be more up-to-current-issues, but I am not anymore, and I see that I am very much ‘outdated’.
Big thanx to both of you.
Your explanations are clear and precise.
I understand the nature of the problem now.
I have very clear step-by-step instructions of how to fix the ‘common issue’.
