Auracle ( AUR ) macht Probleme beim Update
Beim Update von Auracle erhalte ich folgende Meldung:
13/13 auracle:auracle / test_update        OK              0.77s
Ok:                 9
Expected Fail:      0
Fail:               4
Unexpected Pass:    0
Skipped:            0
Timeout:            0
Full log written to /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/build/meson-logs/testlog.txt
==> FEHLER: Ein Fehler geschah in check().
    Breche ab...
Hier das testlog.txt :
Log of Meson test suite run on 2023-07-11T21:03:24.673561
Inherited environment: SHELL=/bin/bash SESSION_MANAGER=local/Lin001:@/tmp/.ICE-unix/1221,unix/Lin001:/tmp/.ICE-unix/1221 CSF_MDTVTexturesDirectory=/usr/share/opencascade/resources/Textures XDG_CONFIG_DIRS=/etc/xdg XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0 XDG_MENU_PREFIX=xfce- CSF_DrawPluginDefaults=/usr/share/opencascade/resources/DrawResources PYTHONHASHSEED=0 LC_ADDRESS=de_DE.UTF-8 CSF_LANGUAGE=us DOTNET_ROOT=/usr/share/dotnet LC_NAME=de_DE.UTF-8 TEXTDOMAINDIR=/usr/share/locale SSH_AUTH_SOCK=/tmp/ssh-XXXXXXyPCBhb/agent.1286 CSF_MIGRATION_TYPES=/usr/share/opencascade/resources/StdResource/MigrationSheet.txt PKGDEST=/home/ralf/.tmp/auracle DESKTOP_SESSION=xfce LC_MONETARY=de_DE.UTF-8 SSH_AGENT_PID=1287 CSF_OCCTResourcePath=/usr/share/opencascade/resources CSF_STEPDefaults=/usr/share/opencascade/resources/XSTEPResource EDITOR=/usr/bin/nano GTK_MODULES=canberra-gtk-module:canberra-gtk-module XDG_SEAT=seat0 PKGEXT=.pkg.tar PWD=/home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be SOURCE_DATE_EPOCH=1689101643 LOGNAME=ralf XDG_SESSION_DESKTOP=xfce QT_QPA_PLATFORMTHEME=qt5ct XDG_SESSION_TYPE=x11 DRAWHOME=/usr/share/opencascade/resources/DrawResources PANEL_GDK_CORE_DEVICE_EVENTS=0 CXXFLAGS='-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions         -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security         -fstack-clash-protection -fcf-protection' XAUTHORITY=/home/ralf/.Xauthority CSF_StandardLiteDefaults=/usr/share/opencascade/resources/StdResource XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/ralf MOTD_SHOWN=pam GDM_LANG=de_DE.utf8 COMMAND_MODE=legacy GTK2_RC_FILES=/home/ralf/.gtkrc-2.0 LDFLAGS=-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now HOME=/home/ralf LC_PAPER=de_DE.UTF-8 LANG=de_DE.utf8 XDG_CURRENT_DESKTOP=XFCE XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0 CSF_ShadersDirectory=/usr/share/opencascade/resources/Shaders DOTNET_BUNDLE_EXTRACT_BASE_DIR=/home/ralf/.cache/dotnet_bundle_extract CSF_EXCEPTION_PROMPT=1 CSF_XmlOcafResource=/usr/share/opencascade/resources/XmlOcafResource QT_QPA_PLATFORM=xcb CSF_SHMessage=/usr/share/opencascade/resources/SHMessage MAKEFLAGS=-j2 XDG_SESSION_CLASS=user LC_IDENTIFICATION=de_DE.UTF-8 USER=ralf CSF_StandardDefaults=/usr/share/opencascade/resources/StdResource CSF_IGESDefaults=/usr/share/opencascade/resources/XSTEPResource HTTP_USER_AGENT=Pamac/11.5.5_manjaro DISPLAY=:0.0 CSF_XCAFDefaults=/usr/share/opencascade/resources/StdResource SHLVL=1 LC_TELEPHONE=de_DE.UTF-8 LC_MEASUREMENT=de_DE.UTF-8 XDG_VTNR=1 CSF_PluginDefaults=/usr/share/opencascade/resources/StdResource CSF_TObjMessage=/usr/share/opencascade/resources/TObj XDG_SESSION_ID=2 CASROOT=/usr XDG_RUNTIME_DIR=/run/user/1000 DEBUGINFOD_URLS='https://debuginfod.archlinux.org ' LC_TIME=de_DE.UTF-8 QT_AUTO_SCREEN_SCALE_FACTOR=0 CSF_XSMessage=/usr/share/opencascade/resources/XSMessage MMGT_CLEAR=1 GTK3_MODULES=xapp-gtk3-module:xapp-gtk3-module XDG_DATA_DIRS=/home/ralf/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop:/usr/share CHOST=x86_64-pc-linux-gnu PATH=/home/ralf/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/home/ralf/.dotnet/tools:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin CSF_TObjDefaults=/usr/share/opencascade/resources/StdResource GDMSESSION=xfce CFLAGS='-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions         -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security         -fstack-clash-protection -fcf-protection' DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus MAIL=/var/spool/mail/ralf DRAWDEFAULT=/usr/share/opencascade/resources/DrawResources/DrawDefault LC_NUMERIC=de_DE.UTF-8 OLDPWD=/home/ralf/.tmp/auracle/src TEXTDOMAIN=pacman-scripts _=/usr/bin/meson
==================================== 1/13 ====================================
test:         auracle:libaur / libaur
start time:   19:03:24
duration:     0.04s
result:       exit status 0
command:      MALLOC_PERTURB_=138 /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/build/libaur_test
----------------------------------- stdout -----------------------------------
[==========] Running 11 tests from 2 test suites.
[----------] Global test environment set-up.
[----------] 8 tests from RequestTest
[ RUN      ] RequestTest.BuildsInfoRequests
[       OK ] RequestTest.BuildsInfoRequests (0 ms)
[ RUN      ] RequestTest.UrlEncodesParameterValues
[       OK ] RequestTest.UrlEncodesParameterValues (0 ms)
[ RUN      ] RequestTest.BuildsMultipleUrlsForLongRequests
[       OK ] RequestTest.BuildsMultipleUrlsForLongRequests (0 ms)
[ RUN      ] RequestTest.BuildsUrlForArgLongerThanMaxLen
[       OK ] RequestTest.BuildsUrlForArgLongerThanMaxLen (0 ms)
[ RUN      ] RequestTest.BuildsSearchRequests
[       OK ] RequestTest.BuildsSearchRequests (0 ms)
[ RUN      ] RequestTest.BuildsRawRequests
[       OK ] RequestTest.BuildsRawRequests (0 ms)
[ RUN      ] RequestTest.UrlForSourceFileEscapesReponame
[       OK ] RequestTest.UrlForSourceFileEscapesReponame (0 ms)
[ RUN      ] RequestTest.BuildsCloneRequests
[       OK ] RequestTest.BuildsCloneRequests (0 ms)
[----------] 8 tests from RequestTest (0 ms total)
[----------] 3 tests from ResponseTest
[ RUN      ] ResponseTest.ParsesSuccessResponse
[       OK ] ResponseTest.ParsesSuccessResponse (0 ms)
[ RUN      ] ResponseTest.ParsesErrorResponse
[       OK ] ResponseTest.ParsesErrorResponse (0 ms)
[ RUN      ] ResponseTest.GracefullyHandlesInvalidJson
[       OK ] ResponseTest.GracefullyHandlesInvalidJson (2 ms)
[----------] 3 tests from ResponseTest (3 ms total)
[----------] Global test environment tear-down
[==========] 11 tests from 2 test suites ran. (3 ms total)
[  PASSED  ] 11 tests.
==================================== 2/13 ====================================
test:         auracle:libauracle / libauracle
duration:     0.42s
result:       killed by signal 4 SIGILL
command:      MALLOC_PERTURB_=165 /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/build/libauracle_test
[==========] Running 22 tests from 6 test suites.
[----------] 1 test from AuracleTest
[ RUN      ] AuracleTest.ParseDependencyKinds
[       OK ] AuracleTest.ParseDependencyKinds (0 ms)
[----------] 1 test from AuracleTest (0 ms total)
[----------] 4 tests from PackageCacheTest
[ RUN      ] PackageCacheTest.AddsPackages
[       OK ] PackageCacheTest.AddsPackages (0 ms)
[ RUN      ] PackageCacheTest.LooksUpPackages
[       OK ] PackageCacheTest.LooksUpPackages (0 ms)
[ RUN      ] PackageCacheTest.WalkDependencies
[       OK ] PackageCacheTest.WalkDependencies (0 ms)
[ RUN      ] PackageCacheTest.WalkDependenciesWithLimitedDeps
[       OK ] PackageCacheTest.WalkDependenciesWithLimitedDeps (0 ms)
[----------] 4 tests from PackageCacheTest (0 ms total)
[----------] 5 tests from FormatTest
[ RUN      ] FormatTest.DetectsInvalidFormats
[       OK ] FormatTest.DetectsInvalidFormats (0 ms)
[ RUN      ] FormatTest.CustomStringFormat
[       OK ] FormatTest.CustomStringFormat (0 ms)
[ RUN      ] FormatTest.CustomFloatFormat
[       OK ] FormatTest.CustomFloatFormat (0 ms)
[ RUN      ] FormatTest.CustomDateTimeFormat
==================================== 3/13 ====================================
test:         auracle:auracle / test_buildorder
duration:     0.93s
command:      MALLOC_PERTURB_=53 PYTHONDONTWRITEBYTECODE=1 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_buildorder.py
----------------------------------- stderr -----------------------------------
Ran 6 tests in 0.490s
OK
==================================== 4/13 ====================================
test:         auracle:auracle / test_clone
start time:   19:03:25
duration:     1.08s
command:      PYTHONDONTWRITEBYTECODE=1 MALLOC_PERTURB_=128 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_clone.py
Ran 7 tests in 0.688s
OK
==================================== 5/13 ====================================
test:         auracle:auracle / test_custom_format
duration:     1.11s
result:       exit status 1
command:      MALLOC_PERTURB_=46 PYTHONDONTWRITEBYTECODE=1 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_custom_format.py
F....
FAIL: testDateTimeFormat (__main__.TestInfo.testDateTimeFormat)
  File "/home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_custom_format.py", line 25, in testDateTimeFormat
    self.assertEqual(0, r.process.returncode)
AssertionError: 0 != -4
Ran 5 tests in 0.717s
FAILED (failures=1)
==================================== 6/13 ====================================
test:         auracle:auracle / test_outdated
start time:   19:03:26
duration:     0.74s
command:      MALLOC_PERTURB_=7 PYTHONDONTWRITEBYTECODE=1 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_outdated.py
Ran 3 tests in 0.249s
OK
==================================== 7/13 ====================================
test:         auracle:auracle / test_info
duration:     1.64s
command:      MALLOC_PERTURB_=241 PYTHONDONTWRITEBYTECODE=1 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_info.py
..FF
FAIL: testExitSuccessIfAtLeastOneFound (__main__.TestInfo.testExitSuccessIfAtLeastOneFound)
  File "/home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_info.py", line 15, in testExitSuccessIfAtLeastOneFound
FAIL: testSingleInfoQuery (__main__.TestInfo.testSingleInfoQuery)
  File "/home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_info.py", line 11, in testSingleInfoQuery
Ran 4 tests in 1.036s
FAILED (failures=2)
==================================== 8/13 ====================================
test:         auracle:auracle / test_raw_query
start time:   19:03:27
duration:     0.73s
command:      MALLOC_PERTURB_=79 PYTHONDONTWRITEBYTECODE=1 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_raw_query.py
Ran 5 tests in 0.370s
OK
==================================== 9/13 ====================================
test:         auracle:auracle / test_regex_search
duration:     0.92s
command:      PYTHONDONTWRITEBYTECODE=1 MALLOC_PERTURB_=246 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_regex_search.py
Ran 3 tests in 0.213s
OK
=================================== 10/13 ====================================
test:         auracle:auracle / test_show
start time:   19:03:28
duration:     0.46s
command:      PYTHONDONTWRITEBYTECODE=1 MALLOC_PERTURB_=2 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_show.py
Ran 4 tests in 0.181s
OK
=================================== 11/13 ====================================
test:         auracle:auracle / test_search
duration:     1.17s
command:      PYTHONDONTWRITEBYTECODE=1 MALLOC_PERTURB_=108 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_search.py
Ran 7 tests in 0.742s
OK
=================================== 12/13 ====================================
test:         auracle:auracle / test_sort
start time:   19:03:29
duration:     0.95s
command:      PYTHONDONTWRITEBYTECODE=1 MALLOC_PERTURB_=35 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_sort.py
....F.
FAIL: testSortInfoByPopularity (__main__.SortTest.testSortInfoByPopularity)
  File "/home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_sort.py", line 13, in testSortInfoByPopularity
Ran 6 tests in 0.525s
FAILED (failures=1)
=================================== 13/13 ====================================
test:         auracle:auracle / test_update
duration:     0.77s
command:      PYTHONDONTWRITEBYTECODE=1 MALLOC_PERTURB_=103 /usr/bin/python3 -W all /home/ralf/.tmp/auracle/src/auracle-87399290d15900a2fcbc4d1d382f57bdac2ee4be/tests/test_update.py
Ran 3 tests in 0.266s
OK
Summary of Failures:
 2/13 auracle:libauracle / libauracle      FAIL            0.42s   killed by signal 4 SIGILL
 5/13 auracle:auracle / test_custom_format FAIL            1.11s   exit status 1
 7/13 auracle:auracle / test_info          FAIL            1.64s   exit status 1
12/13 auracle:auracle / test_sort          FAIL            0.95s   exit status 1
Ok:                 9
Expected Fail:      0
Fail:               4
Unexpected Pass:    0
Skipped:            0
Timeout:            0
Hier mal ein Pactree auracle.
So wie es aussieht hängt vieles davon ab, dahe rhabe ich es auch noch nicht deinstalliert.
pactree auracle
auracle
├─pacman>=5.2
│ ├─bash
│ │ ├─readline
│ │ │ ├─glibc
│ │ │ │ ├─linux-api-headers>=4.10
│ │ │ │ ├─tzdata
│ │ │ │ └─filesystem
│ │ │ │   └─iana-etc
│ │ │ ├─ncurses
│ │ │ │ ├─glibc
│ │ │ │ └─gcc-libs
│ │ │ │   └─glibc>=2.27
│ │ │ └─ncurses provides libncursesw.so=6-64
│ │ ├─readline provides libreadline.so=8-64
│ │ ├─glibc
│ │ ├─ncurses
│ │ └─bashrc-manjaro provides bashrc
│ │   └─bash
│ ├─glibc
│ ├─libarchive
│ │ ├─acl
│ │ ├─acl provides libacl.so=1-64
│ │ ├─bzip2
│ │ │ ├─glibc
│ │ │ └─bash provides sh
│ │ ├─expat
│ │ │ └─glibc
│ │ ├─lz4
│ │ │ └─glibc
│ │ ├─openssl
│ │ │ └─glibc
│ │ ├─openssl provides libcrypto.so=3-64
│ │ ├─xz
│ │ ├─zlib
│ │ │ └─glibc
│ │ └─zstd
│ │   ├─glibc
│ │   ├─gcc-libs
│ │   ├─zlib
│ │   ├─xz
│ │   └─lz4
│ ├─curl
│ │ ├─ca-certificates
│ │ │ └─ca-certificates-mozilla
│ │ │   └─ca-certificates-utils>=20181109-3
│ │ │     ├─bash
│ │ │     ├─coreutils
│ │ │     │ ├─glibc
│ │ │     │ ├─acl
│ │ │     │ ├─attr
│ │ │     │ │ └─glibc
│ │ │     │ ├─gmp
│ │ │     │ │ ├─gcc-libs
│ │ │     │ │ └─bash provides sh
│ │ │     │ ├─libcap
│ │ │     │ │ ├─glibc
│ │ │     │ │ └─pam
│ │ │     │ │   ├─glibc
│ │ │     │ │   ├─libtirpc
│ │ │     │ │   │ └─krb5
│ │ │     │ │   │   ├─glibc
│ │ │     │ │   │   ├─e2fsprogs
│ │ │     │ │   │   │ ├─bash provides sh
│ │ │     │ │   │   │ └─util-linux-libs
│ │ │     │ │   │   │   └─glibc
│ │ │     │ │   │   ├─libldap
│ │ │     │ │   │   │ └─libsasl
│ │ │     │ │   │   │   ├─gdbm
│ │ │     │ │   │   │   │ ├─glibc
│ │ │     │ │   │   │   │ ├─bash provides sh
│ │ │     │ │   │   │   │ ├─readline
│ │ │     │ │   │   │   │ └─readline provides libreadline.so=8-64
│ │ │     │ │   │   │   ├─gdbm provides libgdbm.so=6-64
│ │ │     │ │   │   │   └─openssl
│ │ │     │ │   │   ├─keyutils
│ │ │     │ │   │   │ └─bash provides sh
│ │ │     │ │   │   ├─libverto provides libverto-module-base
│ │ │     │ │   │   │ └─libevent
│ │ │     │ │   │   ├─keyutils provides libkeyutils.so=1-64
│ │ │     │ │   │   ├─e2fsprogs provides libss.so=2-64
│ │ │     │ │   │   ├─e2fsprogs provides libcom_err.so=2-64
│ │ │     │ │   │   └─libverto provides libverto.so=1-64
│ │ │     │ │   ├─pambase
│ │ │     │ │   ├─audit
│ │ │     │ │   │ ├─glibc
│ │ │     │ │   │ ├─krb5
│ │ │     │ │   │ ├─krb5 provides libkrb5.so=3-64
│ │ │     │ │   │ ├─krb5 provides libgssapi_krb5.so=2-64
│ │ │     │ │   │ ├─libcap-ng
│ │ │     │ │   │ └─libcap-ng provides libcap-ng.so=0-64
│ │ │     │ │   ├─audit provides libaudit.so=1-64
│ │ │     │ │   ├─libxcrypt
│ │ │     │ │   │ └─glibc
│ │ │     │ │   └─libxcrypt provides libcrypt.so=2-64
│ │ │     │ └─openssl
│ │ │     ├─findutils
│ │ │     │ ├─glibc
│ │ │     └─p11-kit>=0.24.0
│ │ │       ├─libp11-kit=0.25.0-1
│ │ │       │ ├─glibc
│ │ │       │ ├─libffi
│ │ │       │ │ └─glibc
│ │ │       │ └─libtasn1
│ │ │       │   └─glibc
│ │ │       ├─coreutils
│ │ │       ├─libp11-kit provides libp11-kit.so=0-64
│ │ │       └─systemd-libs provides libsystemd.so=0-64
│ │ │         ├─glibc
│ │ │         ├─gcc-libs
│ │ │         ├─libcap
│ │ │         ├─libgcrypt
│ │ │         │ └─libgpg-error
│ │ │         │   ├─glibc
│ │ │         ├─lz4
│ │ │         ├─xz
│ │ │         └─zstd
│ │ ├─brotli
│ │ │ └─glibc
│ │ ├─brotli provides libbrotlidec.so=1-64
│ │ ├─krb5
│ │ ├─libidn2
│ │ │ ├─libunistring
│ │ │ │ └─glibc
│ │ │ └─libunistring provides libunistring.so=5-64
│ │ ├─libidn2 provides libidn2.so=0-64
│ │ ├─libnghttp2
│ │ │ └─glibc
│ │ ├─libpsl
│ │ │ ├─libidn2
│ │ │ ├─libidn2 provides libidn2.so=0-64
│ │ ├─libpsl provides libpsl.so=5-64
│ │ ├─libssh2
│ │ │ ├─openssl
│ │ │ └─zlib
│ │ ├─libssh2 provides libssh2.so=1-64
│ │ ├─openssl
│ │ ├─zlib
│ │ ├─zstd
│ │ └─zstd provides libzstd.so=1-64
│ ├─gpgme
│ │ ├─libgpg-error
│ │ └─gnupg>=2
│ │   ├─bzip2
│ │   ├─bzip2 provides libbz2.so=1.0-64
│ │   ├─glibc
│ │   ├─gnutls
│ │   │ ├─gcc-libs
│ │   │ ├─libtasn1
│ │   │ ├─readline
│ │   │ ├─zlib
│ │   │ ├─nettle
│ │   │ │ ├─glibc
│ │   │ │ └─gmp
│ │   │ ├─p11-kit
│ │   │ ├─libidn2
│ │   │ ├─zstd
│ │   │ └─brotli
│ │   ├─libgcrypt
│ │   ├─libgpg-error
│ │   ├─libksba
│ │   │ ├─bash
│ │   │ ├─libgpg-error
│ │   │ └─glibc
│ │   ├─libassuan
│ │   │ ├─glibc
│ │   ├─libassuan provides libassuan.so=0-64
│ │   ├─npth
│ │   │ ├─glibc
│ │   ├─npth provides libnpth.so=0-64
│ │   ├─pinentry
│ │   │ ├─glibc
│ │   │ ├─ncurses
│ │   │ ├─libcap
│ │   │ ├─libassuan
│ │   │ ├─libsecret
│ │   │ │ ├─glib2
│ │   │ │ │ ├─libffi
│ │   │ │ │ ├─libsysprof-capture
│ │   │ │ │ ├─pcre2
│ │   │ │ │ │ ├─zlib
│ │   │ │ │ │ ├─bzip2
│ │   │ │ │ │ └─bash
│ │   │ │ │ ├─util-linux-libs
│ │   │ │ │ ├─zlib
│ │   │ │ │ ├─libffi provides libffi.so=8-64
│ │   │ │ │ └─util-linux-libs provides libmount.so=1-64
│ │   │ │ ├─libgcrypt
│ │   │ │ └─tpm2-tss
│ │   │ │   ├─curl
│ │   │ │   ├─json-c
│ │   │ │   │ └─glibc
│ │   │ │   ├─openssl
│ │   │ │   └─json-c provides libjson-c.so=5-64
│ │   │ ├─glib2
│ │   │ ├─libsecret provides libsecret-1.so=0-64
│ │   │ ├─lib32-libcap provides libcap.so
│ │   │ │ ├─libcap=2.69
│ │   │ │ ├─lib32-gcc-libs
│ │   │ │ │ └─lib32-glibc>=2.27
│ │   │ │ │   └─glibc=2.37
│ │   │ │ ├─lib32-glibc
│ │   │ │ └─lib32-pam
│ │   │ │   ├─lib32-libtirpc
│ │   │ │   │ ├─lib32-krb5
│ │   │ │   │ │ ├─lib32-glibc
│ │   │ │   │ │ ├─lib32-gcc-libs
│ │   │ │   │ │ ├─lib32-e2fsprogs
│ │   │ │   │ │ │ ├─lib32-glibc
│ │   │ │   │ │ │ └─e2fsprogs
│ │   │ │   │ │ ├─lib32-libldap
│ │   │ │   │ │ │ ├─lib32-openssl
│ │   │ │   │ │ │ │ ├─lib32-glibc
│ │   │ │   │ │ │ │ └─openssl
│ │   │ │   │ │ │ ├─lib32-libxcrypt
│ │   │ │   │ │ │ │ └─libxcrypt
│ │   │ │   │ │ │ └─libldap
│ │   │ │   │ │ ├─lib32-keyutils
│ │   │ │   │ │ │ ├─lib32-krb5
│ │   │ │   │ │ │ └─keyutils
│ │   │ │   │ │ └─krb5
│ │   │ │   │ └─libtirpc
│ │   │ │   └─pam
│ │   │ ├─ncurses provides libncursesw.so=6-64
│ │   │ ├─libassuan provides libassuan.so=0-64
│ │   │ └─glib2 provides libglib-2.0.so=0-64
│ │   ├─readline
│ │   ├─sqlite
│ │   │ ├─readline
│ │   │ └─zlib
│ │   └─zlib
│ ├─gettext
│ │ ├─gcc-libs
│ │ ├─acl
│ │ ├─libunistring
│ │ └─libxml2
│ │   ├─icu
│ │   │ ├─gcc-libs
│ │   │ ├─glibc
│ │   ├─ncurses
│ │   ├─readline
│ │   ├─xz
│ │   └─zlib
│ ├─gawk
│ │ ├─glibc
│ │ └─mpfr
│ │   ├─glibc
│ │   └─gmp
│ ├─coreutils
│ ├─gnupg
│ ├─grep
│ │ ├─glibc
│ │ └─pcre2
│ ├─fakeroot
│ │ ├─glibc
│ │ ├─filesystem
│ │ ├─sed
│ │ │ ├─glibc
│ │ │ └─acl
│ │ ├─util-linux
│ │ │ ├─pam
│ │ │ ├─shadow
│ │ │ │ ├─acl
│ │ │ │ ├─acl provides libacl.so=1-64
│ │ │ │ ├─attr
│ │ │ │ ├─attr provides libattr.so=1-64
│ │ │ │ ├─audit
│ │ │ │ ├─glibc
│ │ │ │ ├─libxcrypt
│ │ │ │ ├─libxcrypt provides libcrypt.so=2-64
│ │ │ │ ├─pam
│ │ │ │ ├─pam provides libpam.so=0-64
│ │ │ │ └─pam provides libpam_misc.so=0-64
│ │ │ ├─coreutils
│ │ │ ├─systemd-libs
│ │ │ ├─systemd-libs provides libsystemd.so=0-64
│ │ │ ├─systemd-libs provides libudev.so=1-64
│ │ │ ├─libcap-ng
│ │ │ ├─libutempter
│ │ │ │ └─glibc
│ │ │ ├─libxcrypt
│ │ │ ├─file provides libmagic.so=1-64
│ │ │ │ ├─glibc
│ │ │ │ ├─zlib
│ │ │ │ ├─xz
│ │ │ │ ├─bzip2
│ │ │ │ ├─libseccomp
│ │ │ │ │ └─glibc
│ │ │ │ ├─libseccomp provides libseccomp.so=2-64
│ │ │ │ ├─zstd
│ │ │ │ └─zstd provides libzstd.so=1-64
│ ├─perl
│ │ ├─gdbm>=1.17
│ │ ├─db5.3
│ │ │ ├─gcc-libs
│ │ ├─db
│ │ │ ├─gcc-libs
│ │ ├─glibc
│ │ ├─libxcrypt
│ └─pacman-mirrors
│   ├─python
│   │ ├─bzip2
│   │ ├─expat
│   │ ├─gdbm
│   │ ├─libffi
│   │ ├─libnsl
│   │ │ ├─glibc
│   │ │ └─libtirpc
│   │ ├─libxcrypt
│   │ ├─openssl
│   │ └─zlib
│   ├─python-npyscreen
│   │ └─python
│   ├─python-requests
│   │ ├─python-urllib3
│   │ │ └─python
│   │ ├─python-chardet
│   │ │ └─python
│   │ └─python-idna
│   │   └─python
│   └─python-certifi
│     ├─ca-certificates
│     └─python
├─libarchive provides libarchive.so
├─curl provides libcurl.so=4-64
Weiß jemand warum dies abbricht?
Vielen Dank im voraus.
MfG R.Lehmeier
Weil 4 von 13 Tests fehlschlagen. Eventuell build Ordner aufräumen?
pamac clean --build-files
Denkfehler: Alles unterhalb des Abhängigkeitsbaums wird nicht entfernt, aber wird bei der Installation benötigt und ggf. installiert. Wenn etwas entfernt wird, dann wird auch das, was oberhalb dieses Paketes, von anderen Paketen gebraucht, versucht zu entfernen.
Beispiel: Firefox
Das braucht Firefox alles um zu funktionieren, aber wird nicht entfernt, sondern lediglich bei Installation, auch installiert, falls nicht vorhanden:
$ pactree firefox
firefox
├─dbus-glib
│ ├─dbus
│ │ ├─audit
│ │ │ ├─glibc
│ │ │ │ ├─tzdata
│ │ │ │   └─iana-etc
│ │ │ ├─krb5
│ │ │ │ ├─glibc
│ │ │ │ ├─e2fsprogs
│ │ │ │ │ │ │ ├─ncurses
│ │ │ │ │ │ │ │ └─gcc-libs
│ │ │ │ │ │ │ │   └─glibc>=2.27
│ │ │ │ │ │ │ └─ncurses provides libncursesw.so=6-64
│ │ │ │ │ │ ├─readline provides libreadline.so=8-64
│ │ │ │ │ │ ├─glibc
│ │ │ │ │ │ └─bashrc-manjaro provides bashrc
│ │ │ │ │ │   └─bash
│ │ │ │ │   └─glibc
│ │ │ │ ├─libldap
│ │ │ │ │ └─libsasl
│ │ │ │ │   ├─gdbm
│ │ │ │ │   │ ├─glibc
│ │ │ │ │   ├─glibc
│ │ │ │ │   └─openssl
│ │ │ │ │     └─glibc
│ │ │ │ ├─keyutils
│ │ │ │ │ ├─glibc
│ │ │ │ │ ├─glibc
│ │ │ │ │   └─openssl
│ │ │ ├─libcap-ng
│ │ │ │ └─glibc
│ │ ├─expat
│ │ │ └─glibc
│ │ ├─systemd-libs
│ │ │ ├─glibc
│ │ │ ├─gcc-libs
│ │ │ ├─libcap
│ │ │ │ ├─gcc-libs
│ │ │ │ ├─glibc
│ │ │ │ └─pam
│ │ │ │   ├─glibc
│ │ │ │   ├─libtirpc
│ │ │ │   │ └─krb5
│ │ │ │   ├─pambase
│ │ │ │   ├─audit
│ │ │ │   ├─libxcrypt
│ │ │ │   │ └─glibc
│ │ │ ├─libgcrypt
│ │ │ │   ├─glibc
│ │ │ ├─lz4
│ │ │ │ └─glibc
│ │ │ ├─xz
│ │ │ └─zstd
│ │ │   ├─glibc
│ │ │   ├─gcc-libs
│ │ │   ├─zlib
│ │ │   │ └─glibc
│ │ │   ├─xz
│ │ │   └─lz4
│ ├─expat
│ ├─glib2
│ │ ├─libffi
│ │ │ └─glibc
│ │ ├─pcre2
│ │ │ ├─readline
│ │ │ ├─zlib
│ │ │ ├─bzip2
│ │ │ │ ├─glibc
│ │ │ └─bash
│ │ ├─zlib
│ └─glibc
├─ffmpeg
│ ├─alsa-lib
│ │ ├─alsa-topology-conf
│ │ ├─alsa-ucm-conf
│ │ └─glibc
│ ├─aom
│ │ └─gcc-libs
│ ├─bzip2
│ ├─fontconfig
│ │ ├─expat
│ │ ├─freetype2
│ │ │ ├─brotli
│ │ │ │ └─glibc
│ │ │ ├─bzip2
│ │ │ ├─libpng
│ │ │ │ ├─zlib
│ │ │ ├─zlib
│ │ │ └─harfbuzz
│ │ │   ├─freetype2 provides libfreetype.so=6-64
│ │ │   ├─glib2 provides libglib-2.0.so=0-64
│ │ │   ├─glib2 provides libgobject-2.0.so=0-64
│ │ │   └─graphite provides libgraphite2.so=3-64
│ │ │     └─gcc-libs
│ │ ├─expat provides libexpat.so=1-64
│ │ └─freetype2 provides libfreetype.so=6-64
│ ├─fribidi
│ │ └─glibc
│ ├─gmp
│ │ ├─gcc-libs
│ ├─gnutls
│ │ ├─gcc-libs
│ │ ├─libtasn1
│ │ │ └─glibc
│ │ ├─readline
│ │ ├─zlib
│ │ ├─nettle
│ │ │ ├─glibc
│ │ │ └─gmp
│ │ ├─p11-kit
│ │ │ │ ├─glibc
│ │ │ │ ├─libffi
│ │ │ │ └─libtasn1
│ │ │ ├─coreutils
│ │ │ │ ├─glibc
│ │ │ │ ├─acl
│ │ │ │ ├─attr
│ │ │ │ │ └─glibc
│ │ │ │ ├─gmp
│ │ │ │ ├─libcap
│ │ │ │ └─openssl
│ │ ├─libidn2
│ │ │ │ └─glibc
│ │ ├─zstd
│ │ ├─libunistring
│ │ └─brotli
│ ├─gsm
│ │ └─glibc
│ ├─jack2 provides jack
│ │ ├─alsa-lib
│ │ ├─alsa-lib provides libasound.so=2-64
│ │ ├─db5.3
│ │ │ ├─gcc-libs
│ │ ├─dbus
│ │ ├─dbus provides libdbus-1.so=3-64
│ │ ├─gcc-libs
│ │ ├─glibc
│ │ ├─libsamplerate
│ │ │ └─glibc
│ │ ├─libsamplerate provides libsamplerate.so=0-64
│ │ ├─opus
│ │ │ └─glibc
│ │ ├─opus provides libopus.so=0-64
│ │ ├─systemd-libs
│ ├─lame
│ │ └─ncurses
│ ├─libass provides libass.so=9-64
│ │ ├─fontconfig
│ │ ├─fribidi
│ │ ├─glib2
│ │ ├─glibc
│ │ ├─harfbuzz
│ ├─libavc1394
│ │ ├─glibc
│ │ └─libraw1394
│ │   └─glibc
│ ├─libbluray provides libbluray.so=2-64
│ │ ├─fontconfig
│ │ └─libxml2
│ │   ├─icu
│ │   │ ├─gcc-libs
│ │   │ ├─glibc
│ │   ├─ncurses
│ │   ├─readline
│ │   ├─xz
│ │   └─zlib
│ ├─libbs2b provides libbs2b.so=0-64
│ │ ├─libsndfile
│ │ │ ├─glibc
│ │ │ ├─flac
│ │ │ │ ├─gcc-libs
│ │ │ │ └─libogg
│ │ │ │   └─glibc
│ │ │ ├─flac provides libFLAC.so=12-64
│ │ │ ├─lame
│ │ │ ├─lame provides libmp3lame.so=0-64
│ │ │ ├─libogg
│ │ │ ├─libogg provides libogg.so=0-64
│ │ │ ├─libvorbis
│ │ │ │ └─libogg provides libogg.so=0-64
│ │ │ ├─libvorbis provides libvorbis.so=0-64
│ │ │ ├─libvorbis provides libvorbisenc.so=2-64
│ │ │ ├─mpg123
│ │ │ │ └─alsa-lib
│ │ │ ├─mpg123 provides libmpg123.so=0-64
│ │ │ ├─opus
│ │ │ └─opus provides libopus.so=0-64
│ │ ├─gcc-libs
│ │ └─libsndfile provides libsndfile.so=1-64
│ ├─dav1d provides libdav1d.so=6-64
│ │ └─glibc
│ ├─libdrm
│ │ └─libpciaccess
│ │   ├─glibc
│ │   └─zlib
│ ├─libglvnd provides libgl
│ │ ├─libxext
│ │ │ └─libx11
│ │ │   ├─libxcb
│ │ │   │ ├─xcb-proto
│ │ │   │ ├─libxdmcp
│ │ │   │ │ ├─glibc
│ │ │   │ │ └─xorgproto
│ │ │   │ └─libxau
│ │ │   │   ├─glibc
│ │ │   │   └─xorgproto
│ │ │   ├─glibc
│ │ │   └─xorgproto
│ │ ├─mesa
│ │ │ ├─libdrm
│ │ │ ├─wayland
│ │ │ │ ├─glibc
│ │ │ │ ├─libffi
│ │ │ │ ├─expat
│ │ │ │ ├─libxml2
│ │ │ │ └─default-cursors
│ │ │ ├─libxxf86vm
│ │ │ │ └─libxext
│ │ │ ├─libxdamage
│ │ │ │ └─libxfixes
│ │ │ │   └─libx11
│ │ │ ├─libxshmfence
│ │ │ │ └─glibc
│ │ │ ├─libelf
│ │ │ │ ├─bzip2
│ │ │ │ ├─bzip2 provides libbz2.so=1.0-64
│ │ │ │ ├─curl
│ │ │ │ │ ├─ca-certificates
│ │ │ │ │ │ └─ca-certificates-mozilla
│ │ │ │ │ │   └─ca-certificates-utils>=20181109-3
│ │ │ │ │ │     ├─bash
│ │ │ │ │ │     ├─coreutils
│ │ │ │ │ │     ├─findutils
│ │ │ │ │ │     └─p11-kit>=0.24.0
│ │ │ │ │ ├─brotli
│ │ │ │ │ ├─brotli provides libbrotlidec.so=1-64
│ │ │ │ │ ├─krb5
│ │ │ │ │ ├─libidn2
│ │ │ │ │ ├─libidn2 provides libidn2.so=0-64
│ │ │ │ │ ├─libnghttp2
│ │ │ │ │ │ └─glibc
│ │ │ │ │ ├─libpsl
│ │ │ │ │ │ ├─libidn2
│ │ │ │ │ │ ├─libunistring
│ │ │ │ │ │ ├─libidn2 provides libidn2.so=0-64
│ │ │ │ │ │ └─libunistring provides libunistring.so=5-64
│ │ │ │ │ ├─libpsl provides libpsl.so=5-64
│ │ │ │ │ ├─libssh2
│ │ │ │ │ │ ├─openssl
│ │ │ │ │ │ └─zlib
│ │ │ │ │ ├─libssh2 provides libssh2.so=1-64
│ │ │ │ │ ├─openssl
│ │ │ │ │ ├─zlib
│ │ │ │ │ ├─zstd
│ │ │ │ │ └─zstd provides libzstd.so=1-64
│ │ │ │ ├─curl provides libcurl.so=4-64
│ │ │ │ ├─gcc-libs
│ │ │ │ ├─glibc
│ │ │ │ ├─xz
│ │ │ │ ├─xz provides liblzma.so=5-64
│ │ │ │ ├─zlib
│ │ │ │ ├─zstd
│ │ │ ├─libomxil-bellagio
│ │ │ │ └─glibc
│ │ │ ├─libunwind
│ │ │ │ ├─xz
│ │ │ │ └─zlib
│ │ │ ├─llvm-libs
│ │ │ │ ├─gcc-libs
│ │ │ │ ├─zlib
│ │ │ │ ├─zstd
│ │ │ │ ├─libffi
│ │ │ │ ├─libedit
│ │ │ │ │ ├─glibc
│ │ │ │ │ ├─ncurses
│ │ │ │ ├─ncurses
│ │ │ │ └─libxml2
│ │ │ ├─lm_sensors
│ │ │ ├─libglvnd
│ │ │ ├─zstd
│ │ │ ├─vulkan-icd-loader
│ │ │ │ └─glibc
│ │ │ ├─lm_sensors provides libsensors.so=5-64
│ │ │ └─expat provides libexpat.so=1-64
│ │ └─mesa provides opengl-driver
│ ├─libiec61883
│ │ └─libraw1394
│ ├─libjxl provides libjxl.so=0.8-64
│ │ ├─brotli
│ │ ├─giflib
│ │ │ └─glibc
│ │ ├─gperftools
│ │ │ ├─gcc-libs
│ │ │ ├─glibc
│ │ │ └─libunwind
│ │ ├─highway
│ │ │ └─gcc-libs
│ │ ├─libjpeg-turbo
│ │ │ └─glibc
│ │ ├─libpng
│ │ └─openexr
│ │   ├─zlib
│ │   └─imath
│ │     └─gcc-libs
│ ├─libmfx
│ │ └─gcc-libs
│ ├─libmodplug
│ │ └─gcc-libs
│ ├─libopenmpt provides libopenmpt.so=0-64
│ │ ├─flac
│ │ ├─gcc-libs
│ │ ├─glibc
│ │ ├─libogg
│ │ ├─libpulse
│ │ │ ├─dbus
│ │ │ ├─libasyncns
│ │ │ │ └─glibc
│ │ │ ├─libsndfile
│ │ │ ├─libxcb
│ │ │ └─systemd
│ │ │   ├─acl
│ │ │   ├─bash
│ │ │   ├─cryptsetup
│ │ │   │ ├─device-mapper
│ │ │   │ │ ├─glibc
│ │ │   │ │ ├─systemd-libs
│ │ │   │ │ └─systemd-libs provides libudev.so=1-64
│ │ │   │ ├─device-mapper provides libdevmapper.so=1.02-64
│ │ │   │ ├─openssl
│ │ │   │ ├─popt
│ │ │   │ │ └─glibc
│ │ │   │ ├─util-linux-libs provides libuuid.so=1-64
│ │ │   │ ├─json-c
│ │ │   │ │ └─glibc
│ │ │   │ ├─json-c provides libjson-c.so=5-64
│ │ │   │ ├─argon2
│ │ │   │ │ └─glibc
│ │ │   │ └─argon2 provides libargon2.so=1-64
│ │ │   ├─cryptsetup provides libcryptsetup.so=12-64
│ │ │   ├─dbus
│ │ │   ├─iptables
│ │ │   │ ├─libnftnl
│ │ │   │ │ └─libmnl
│ │ │   │ │   └─glibc
│ │ │   │ ├─libpcap
│ │ │   │ │ ├─glibc
│ │ │   │ │ ├─libnl
│ │ │   │ │ │ ├─glibc
│ │ │   │ │ └─dbus provides libdbus-1.so=3-64
│ │ │   │ ├─libnfnetlink
│ │ │   │ │ └─glibc
│ │ │   │ ├─libnetfilter_conntrack
│ │ │   │ │ ├─libnfnetlink
│ │ │   │ │ └─libmnl
│ │ │   │ └─bash
│ │ │   ├─kbd
│ │ │   │ ├─glibc
│ │ │   │ └─pam
│ │ │   ├─kmod
│ │ │   │ ├─glibc
│ │ │   │ ├─zlib
│ │ │   │ ├─openssl
│ │ │   │ ├─xz
│ │ │   │ └─zstd
│ │ │   ├─kmod provides libkmod.so=2-64
│ │ │   ├─hwdata
│ │ │   ├─libcap
│ │ │   ├─libcap provides libcap.so=2-64
│ │ │   ├─libgcrypt
│ │ │   ├─libxcrypt
│ │ │   ├─libidn2
│ │ │   ├─lz4
│ │ │   ├─pam
│ │ │   ├─libelf
│ │ │   ├─libseccomp
│ │ │   │ └─glibc
│ │ │   ├─util-linux
│ │ │   │ ├─pam
│ │ │   │ ├─shadow
│ │ │   │ │ ├─acl
│ │ │   │ │ ├─acl provides libacl.so=1-64
│ │ │   │ │ ├─attr
│ │ │   │ │ ├─attr provides libattr.so=1-64
│ │ │   │ │ ├─audit
│ │ │   │ │ ├─glibc
│ │ │   │ │ ├─libxcrypt provides libcrypt.so=2-64
│ │ │   │ │ ├─pam
│ │ │   │ │ ├─pam provides libpam.so=0-64
│ │ │   │ │ └─pam provides libpam_misc.so=0-64
│ │ │   │ ├─coreutils
│ │ │   │ ├─systemd-libs provides libsystemd.so=0-64
│ │ │   │ ├─systemd-libs provides libudev.so=1-64
│ │ │   │ ├─libcap-ng
│ │ │   │ ├─libutempter
│ │ │   │ │ └─glibc
│ │ │   │ ├─libxcrypt
│ │ │   │ ├─file provides libmagic.so=1-64
│ │ │   │ │ ├─glibc
│ │ │   │ │ ├─zlib
│ │ │   │ │ ├─xz
│ │ │   │ │ ├─bzip2
│ │ │   │ │ ├─libseccomp
│ │ │   │ │ ├─libseccomp provides libseccomp.so=2-64
│ │ │   │ │ ├─zstd
│ │ │   ├─util-linux-libs provides libblkid.so=1-64
│ │ │   ├─util-linux-libs provides libmount.so=1-64
│ │ │   ├─xz
│ │ │   ├─pcre2
│ │ │   ├─audit
│ │ │   ├─openssl
│ │ │   ├─openssl provides libcrypto.so=3-64
│ │ │   └─openssl provides libssl.so=3-64
│ │ ├─libsndfile
│ │ ├─libvorbis
│ │ ├─mpg123
│ │ ├─portaudio
│ │ │ ├─gcc-libs
│ │ │ ├─glibc
│ │ │ ├─alsa-lib
│ │ │ ├─alsa-lib provides libasound.so=2-64
│ │ │ ├─jack2 provides jack
│ │ │ └─jack2 provides libjack.so=0-64
│ │ └─zlib
│ ├─libpulse
│ ├─rav1e provides librav1e.so=0-64
│ │ ├─gcc-libs
│ │ └─glibc
│ ├─libraw1394
│ ├─librsvg provides librsvg-2.so=2-64
│ │ ├─cairo
│ │ │ ├─fontconfig
│ │ │ ├─freetype2
│ │ │ ├─glib2
│ │ │ ├─libpng
│ │ │ ├─libx11
│ │ │ ├─libxcb
│ │ │ ├─libxext
│ │ │ ├─libxrender
│ │ │ │ └─libx11
│ │ │ ├─lzo
│ │ │ │ └─glibc
│ │ │ ├─pixman
│ │ │ │ └─glibc
│ │ │ └─zlib
│ │ ├─freetype2
│ │ ├─gdk-pixbuf2
│ │ │ ├─glib2
│ │ │ ├─libpng
│ │ │ ├─libtiff
│ │ │ │ ├─glibc
│ │ │ │ ├─libjpeg-turbo
│ │ │ │ ├─libjpeg-turbo provides libjpeg.so=8-64
│ │ │ │ ├─zlib
│ │ │ │ ├─xz
│ │ │ │ └─zstd
│ │ │ └─shared-mime-info
│ │ │   ├─libxml2
│ │ │   └─glib2
│ │ ├─glib2
│ │ ├─harfbuzz
│ │ ├─libxml2
│ │ └─pango
│ │   ├─cairo
│ │   ├─fribidi
│ │   ├─harfbuzz
│ │   ├─libthai
│ │   │ ├─glibc
│ │   │ └─libdatrie
│ │   │   └─glibc
│ │   └─libxft
│ │     ├─fontconfig
│ │     └─libxrender
│ ├─libsoxr
│ │ └─gcc-libs
│ ├─libssh
│ │ ├─zlib
│ │ └─openssl
│ ├─libtheora
│ │ ├─glibc
│ │ └─libogg
│ ├─libva provides libva.so=2-64
│ │ ├─libdrm
│ │ ├─libglvnd provides libgl
│ │ ├─libx11
│ │ ├─libxext
│ │ ├─libxfixes
│ │ └─wayland
│ ├─libva provides libva-drm.so=2-64
│ ├─libva provides libva-x11.so=2-64
│ ├─libvdpau
│ │ └─libxext
│ ├─vid.stab provides libvidstab.so=1.2-64
│ │ ├─gcc-libs
│ │ └─glibc
│ ├─libvpx provides libvpx.so=8-64
│ │ └─gcc-libs
│ ├─libwebp
│ │ ├─giflib
│ │ ├─libpng
│ │ └─libtiff
│ ├─libx11
│ ├─x264 provides libx264.so=164-64
│ │ └─l-smash provides liblsmash.so=2-64
│ │   └─glibc
│ ├─x265 provides libx265.so=199-64
│ │ └─gcc-libs
│ ├─libxcb
│ ├─libxext
│ ├─libxml2
│ ├─libxv
│ │ └─libxext
│ ├─xvidcore provides libxvidcore.so=4-64
│ │ └─glibc
│ ├─zimg provides libzimg.so=2-64
│ │ ├─gcc-libs
│ │ └─glibc
│ ├─ocl-icd
│ │ └─glibc
│ ├─opencore-amr
│ │ └─glibc
│ ├─openjpeg2
│ │ ├─zlib
│ │ ├─libpng
│ │ ├─libtiff
│ │ └─lcms2
│ │   └─libtiff
│ ├─opus
│ ├─sdl2
│ │ ├─glibc
│ │ ├─libxext
│ │ ├─libxrender
│ │ ├─libx11
│ │ ├─libxcursor
│ │ │ ├─libxfixes
│ │ │ ├─libxrender
│ │ ├─hidapi
│ │ │ ├─libusb
│ │ │ │ ├─glibc
│ │ └─libusb
│ ├─speex
│ │ ├─gcc-libs
│ │ ├─libogg
│ │ ├─speexdsp
│ │ │ └─gcc-libs
│ │ └─speexdsp provides libspeexdsp.so=1-64
│ ├─srt
│ │ ├─gcc-libs
│ │ └─openssl
│ ├─svt-av1
│ │ └─glibc
│ ├─v4l-utils
│ │ ├─hicolor-icon-theme
│ │ ├─gcc-libs
│ │ ├─libjpeg-turbo
│ │ ├─systemd-libs
│ │ └─json-c
│ ├─vmaf
│ │ └─gcc-libs
│ ├─xz
│ └─zlib
├─gtk3
│ ├─adwaita-icon-theme
│ │ ├─gtk-update-icon-cache
│ │ │ ├─gdk-pixbuf2
│ │ │ ├─librsvg
│ │ │ └─hicolor-icon-theme
│ │ ├─librsvg
│ │ └─adwaita-cursors
│ ├─at-spi2-core provides atk
│ │ ├─dbus
│ │ ├─glib2
│ │ ├─gsettings-desktop-schemas
│ │ │ ├─adobe-source-code-pro-fonts
│ │ │ ├─cantarell-fonts
│ │ │ ├─dconf
│ │ │ │ └─glib2
│ │ │ └─glib2
│ │ ├─libx11
│ │ ├─libxml2
│ │ ├─libxtst
│ │ │ ├─libxext
│ │ │ ├─libxi
│ │ │ │ ├─libxext
│ │ │ │ └─libxfixes
│ │ │ └─libxfixes
│ │ ├─systemd
│ │ └─xorg-xprop
│ │   └─libx11
│ ├─cairo
│ ├─cantarell-fonts
│ ├─dconf
│ ├─desktop-file-utils
│ │ ├─glib2
│ ├─fontconfig
│ ├─fribidi
│ ├─gdk-pixbuf2
│ ├─glib2
│ ├─harfbuzz
│ ├─iso-codes
│ ├─libcloudproviders
│ │ └─glib2
│ ├─libcolord
│ │ ├─glib2
│ │ ├─lcms2
│ │ └─systemd
│ ├─libcups
│ │ ├─gnutls
│ │ ├─avahi
│ │ │ ├─dbus
│ │ │ ├─expat
│ │ │ ├─gdbm
│ │ │ ├─glib2
│ │ │ ├─libcap
│ │ │ ├─libdaemon
│ │ ├─glibc
│ │ └─zlib
│ ├─libglvnd provides libegl
│ ├─libepoxy
│ │ ├─glibc
│ │ ├─libglvnd
│ │ └─libx11
│ ├─librsvg
│ ├─libxcomposite
│ │ └─libxfixes
│ ├─libx11
│ ├─libxcursor
│ ├─libxdamage
│ ├─libxext
│ ├─libxfixes
│ ├─libxi
│ ├─libxinerama
│ │ └─libxext
│ ├─libxkbcommon
│ │ ├─libxml2
│ │ └─xkeyboard-config
│ ├─libxrandr
│ │ ├─libxext
│ │ └─libxrender
│ ├─libxrender
│ ├─pango
│ ├─shared-mime-info
│ ├─tracker3
│ │ ├─glib2
│ │ ├─icu
│ │ ├─json-glib
│ │ │ ├─glib2
│ │ │ └─glib2 provides libgio-2.0.so=0-64
│ │ ├─libsoup3
│ │ │ ├─brotli
│ │ │ ├─glib-networking
│ │ │ │ ├─glib2
│ │ │ │ ├─gnutls
│ │ │ │ ├─gsettings-desktop-schemas
│ │ │ │ └─libproxy
│ │ │ │   ├─curl
│ │ │ │   ├─duktape
│ │ │ │   │ └─glibc
│ │ │ │   └─glib2
│ │ │ ├─glib2
│ │ │ ├─krb5
│ │ │ ├─libnghttp2
│ │ │ ├─libpsl
│ │ │ ├─sqlite
│ │ │ │ ├─readline
│ │ │ │ └─zlib
│ │ │ ├─glib2 provides libgio-2.0.so=0-64
│ │ │ └─libpsl provides libpsl.so=5-64
│ │ ├─libstemmer
│ │ │ └─glibc
│ │ ├─libxml2
│ │ └─sqlite
│ ├─wayland
│ └─gtk-update-icon-cache
├─libpulse
├─libxss
│ └─libxext
├─libxt
│ ├─libsm
│ │ ├─libice
│ │ │ ├─glibc
│ │ │ └─xorgproto
│ └─libx11
├─mailcap provides mime-types
├─nss
│ ├─nspr>=4.35
│ │ ├─glibc
│ ├─p11-kit>=0.23.19
│ ├─sqlite
│ ├─zlib
└─gnu-free-fonts provides ttf-font
Diese Pakete werden das Entfernen von firefox verhindern:
$ pactree -r firefox
firefox
├─firefox-i18n-de
├─firefox-i18n-en-us
└─firefox-i18n-it
Die Sprachpakete brauchen Firefox um zu funktionieren. Also hängt firefox-i18n-de von firefox ab.
Merke:
  1. Bei Installation verfolgt man die Hierachie nach unten.
  2. Beim Entfernen verfolgt man die Hierachie nach oben.
Leider brachte dies keine Änderung.
Wie bekomme ich es nun installiert ?
Mit den Fehlermeldungen kann ich leider nur wenig anfangen.
Keine Ahnung. Bei mir lief alles normal durch als ich es testweise installiert habe. :man_shrugging:
Hallo R. Lehmeier,
lass mich das mal ganz pragmatisch betrachten. Hast Du jemals auracle tatsächlich von Hand benutzt, so wie es hier beschrieben wird
https://wiki.archlinux.de/title/Auracle
Ich habe jetzt zum ersten Mal davon gehört, habe es auch nicht installiert und trotzdem fehlt mir nichts, auch nicht für das Bauen von Paketen aus dem AUR.
Nimm es mir nicht übel, aber ich habe den Eindruck, dass Du allerhand Sachen installiert hast, von denen Du nicht genau weisst, ob Du sie tatsächlich brauchst.
Mein Vorschlag, deinstalliere auracle und der Ärger hat ein Ende. Wenn auracle aber zu deinem täglichen Handwerkszeug gehört, na dann sieht es anders aus.
viele Grüsse gosia
Soviel ich weiß habe ich es nie benutzt oder installiert, daher gehe ich davon aus das es eine andere Anwendung installiert haben muß.
Ich versuche auch den Befehl zu finden mit dem ich feststellen kann welches Programm auracle benötigt, leider finde ich es nicht mehr.
Hallo R. Lehmeier,
ach, wenn Du nur beim Installieren auch so zurückhaltend wärst :wink:
Ich habe es mal probeweise installiert, und was sagt mir
pacman -Qi auracle
Benötigt von: Nichts
auracle stammt aus dem AUR und ist nichts weiter als ein AUR-Helferlein, eins von vielen. Also was soll passieren, schlimmstenfalls wird ein weiteres Schmuckstück aus dem AUR entfernt, aber da man in der Regel auch ohne AUR auskommt (am besten sogar ohne auskommen sollte) macht es mit deinem Kernsystem nichts.
Wenn Du immer noch zweifelst, dann mach ein Backup vorher, z.B. Timeshift ist dein Freund, das kann nie schaden.
viele Grüsse gosia
Danke für den Tip - auracle wurde entfernt und alles scheint zu laufen.
