Does Pamac offer AUR updates as they become available, or are they offered together with the regular Manjaro update installments at specific times?
For instance, what happens if I install a AUR browser, such as Google Chrome? Do I receive the update as soon as it comes out, or a week or two later?
They are available as soon as they come out, but it is up to you to install them.
Thanks, so by default, do I get a notification that such an update is available? Or can I configure Pamac to notify?
I don’t know ─ I don’t use the GUI. Why don’t you check the settings yourself?
I would, if I had Manjaro installed at the moment. But thanks anyway.
I am weighing whether to switch from pure Arch to Manjaro, and I understand that Manjaro uses a customized version of Pamac. Thus my question.
What do you mean? It uses Pamac. Pamac is a Manjaro tool made by guinux here on the forum.
//EDIT: here is an album with Pamac settings for you Pamac Settings - Album on Imgur (it doesn’t have the Snap or Flatpak settings tabs as I removed these Pamac plugins, I don’t use that).
Cool, I didn’t know that Manjaro people created it.
