I am a newbie at troubleshooting aur issues. Looking for some help to figure this out.
[demo@manjaro ~]$ sudo pamac update -a
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Cloning python2 build files...
Running as unit: run-u2919.service
fatal: not a git repository (or any parent up to mount point /var/cache/private)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Finished with result: exit-code
Main processes terminated with: code=exited/status=128
Service runtime: 6ms
CPU time consumed: 6ms
Running as unit: run-u2920.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 41ms
Running as unit: run-u2921.service
Service runtime: 1.163s
CPU time consumed: 93ms
Generating python2 information...
Running as unit: run-u2922.service
Service runtime: 1.037s
CPU time consumed: 1.151s
Checking python2 dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
python2 2.7.18-6 (2.7.18-5) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building python2...
Running as unit: run-u2923.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: python2 2.7.18-6 (Sun 25 Sep 2022 08:41:48 AM EDT)
==> Retrieving sources...
-> Downloading Python-2.7.18.tar.xz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 12.2M 100 12.2M 0 0 9.9M 0 0:00:01 0:00:01 --:--:-- 9.9M
-> Downloading Python-2.7.18.tar.xz.asc...
100 833 100 833 0 0 8065 0 --:--:-- --:--:-- --:--:-- 8166
-> Found mtime-workaround.patch
-> Downloading python-gentoo-patches-2.7.18_p15.tar.xz...
100 34956 100 34956 0 0 60481 0 --:--:-- --:--:-- --:--:-- 60582
==> Validating source files with sha512sums...
Python-2.7.18.tar.xz ... Passed
Python-2.7.18.tar.xz.asc ... Skipped
mtime-workaround.patch ... Passed
python-gentoo-patches-2.7.18_p15.tar.xz ... Passed
==> Verifying source file signatures with gpg...
Python-2.7.18.tar.xz ... cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Service runtime: 3.499s
CPU time consumed: 1.985s
Error: Failed to build python2
Your initial issue, after running Pamac a second time it will ask to add the keys, or add them directly maybe from terminal.
but it doesn’t build.
What do you require python2 for? If you don’t need the package that requires it, just remove it all, python2 has been dropped and it now requires to be build from AUR.
//EDIT: maybe this can help try command dependency-checker python2
I don’t know why you end up removing all the dependencies for python2.
You needed to remove the package python2, not its dependencies. You can re-install unrar and mtools if you want.
