Hi
I am trying to install “python-coloredlogs” as a dependency of “ocrmypdf”. However, during the build process, the package gives following error:
==> Starting build()...
/home/sal/.cache/paru/clone/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py:24: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
import distutils.sysconfig
/home/admin/.cache/paru/clone/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py:24: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
File "/home/sal/.cache/paru/clone/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py", line 30, in <module>
from setuptools import find_packages, setup
File "/usr/lib/python3.10/site-packages/setuptools/__init__.py", line 16, in <module>
import setuptools.version
File "/usr/lib/python3.10/site-packages/setuptools/version.py", line 1, in <module>
import pkg_resources
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3266, in <module>
def _initialize_master_working_set():
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3240, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3278, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 564, in _build_master
ws = cls()
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 557, in __init__
self.add_entry(entry)
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 613, in add_entry
for dist in find_distributions(entry, True):
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 2077, in find_on_path
for dist in factory(fullpath):
File "/usr/lib/python3.10/site-packages/pkg_resources/__init__.py", line 2135, in distributions_from_metadata
if len(os.listdir(path)) == 0:
PermissionError: [Errno 13] Permission denied: '/usr/lib/python3.10/site-packages/click-8.1.2.dist-info'
==> ERROR: A failure occurred in build().
Aborting...
error: failed to build 'python-coloredlogs-15.0.1-3':
error: packages failed to build: python-coloredlogs-15.0.1-3
I do not have sufficient knowledge about Python, therefore, I am struggling to understand this error. So, kindly guide to fix this error? Thanks
