When I try to build jpilot from the AUR, using the pamac GUI, the build aborts. I suspect I’m just missing something in my build environment, since this worked before in a regular XFCE installation, whereas this time I’m trying after just reinstalling Manjaro XFCE from the minimal installation. But that’s just a guess.
I’m providing config.log below and would be happy to provide any more information needed:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.65. Invocation command line was
$ ./configure --prefix=/usr --enable-conduits --enable-libusb --with-libiconv --with-libpng
## Platform. ##
hostname = optiplex380
uname -m = x86_64
uname -r = 5.14.0-0-MANJARO
uname -s = Linux
uname -v = #1 SMP PREEMPT Mon Aug 30 10:49:07 UTC 2021
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /home/barry/.local/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/local/sbin
PATH: /usr/bin/site_perl
PATH: /usr/bin/vendor_perl
PATH: /usr/bin/core_perl
## Core tests. ##
configure:2546: checking whether to enable maintainer-specific portions of Makefiles
configure:2555: result: no
configure:2642: checking build system type
configure:2656: result: x86_64-pc-linux-gnu
configure:2676: checking host system type
configure:2689: result: x86_64-pc-linux-gnu
configure:2709: checking target system type
configure:2722: result: x86_64-pc-linux-gnu
configure:2771: checking for a BSD-compatible install
configure:2839: result: /usr/bin/install -c
configure:2850: checking whether build environment is sane
configure:2900: result: yes
configure:3041: checking for a thread-safe mkdir -p
configure:3080: result: /usr/bin/mkdir -p
configure:3093: checking for gawk
configure:3109: found /usr/bin/gawk
configure:3120: result: gawk
configure:3131: checking whether make sets $(MAKE)
configure:3153: result: yes
configure:3283: checking for gcc
configure:3299: found /usr/bin/gcc
configure:3310: result: gcc
configure:3539: checking for C compiler version
configure:3548: gcc --version >&5
gcc (GCC) 11.1.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3559: $? = 0
configure:3548: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /build/gcc/src/gcc/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++,d --with-isl --with-linker-hash-style=gnu --with-system-zlib --enable-__cxa_atexit --enable-cet=auto --enable-checking=release --enable-clocale=gnu --enable-default-pie --enable-default-ssp --enable-gnu-indirect-function --enable-gnu-unique-object --enable-install-libiberty --enable-linker-build-id --enable-lto --enable-multilib --enable-plugin --enable-shared --enable-threads=posix --disable-libssp --disable-libstdcxx-pch --disable-libunwind-exceptions --disable-werror gdc_include_dir=/usr/include/dlang/gdc
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.1.0 (GCC)
configure:3548: gcc -V >&5
gcc: error: unrecognized command-line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:3559: $? = 1
configure:3548: gcc -qversion >&5
gcc: error: unrecognized command-line option '-qversion'; did you mean '--version'?
configure:3579: checking whether the C compiler works
configure:3601: gcc -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat =format-security -fstack-clash-protection -fcf-protection -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now conftest.c >&5
/usr/bin/ld: cannot find format-security: No such file or directory
collect2: error: ld returned 1 exit status
configure:3605: $? = 1
configure:3643: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| #define HOST_OS "x86_64-pc-linux-gnu"
| #define PACKAGE "pilot-link"
| #define VERSION "0.12.5"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:3648: error: in `/var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5':
configure:3652: error: C compiler cannot create executables
See `config.log' for more details.
## Cache variables. ##
ac_cv_build=x86_64-pc-linux-gnu
ac_cv_env_BLUEZ_CFLAGS_set=
ac_cv_env_BLUEZ_CFLAGS_value=
ac_cv_env_BLUEZ_LIBS_set=
ac_cv_env_BLUEZ_LIBS_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=set
ac_cv_env_CFLAGS_value='-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection'
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=set
ac_cv_env_LDFLAGS_value=-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_YACC_set=
ac_cv_env_YACC_value=
ac_cv_env_YFLAGS_set=
ac_cv_env_YFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=x86_64-pc-linux-gnu
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/usr/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
ac_cv_target=x86_64-pc-linux-gnu
## Output variables. ##
ACLOCAL='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/missing --run aclocal-1.11'
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/missing --run tar'
AR=''
AUTOCONF='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/missing --run autoconf'
AUTOHEADER='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/missing --run autoheader'
AUTOMAKE='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/missing --run automake-1.11'
AWK='gawk'
BLUEZ_CFLAGS=''
BLUEZ_LIBS=''
BUILD_XML_FALSE=''
BUILD_XML_TRUE=''
CAT_ENTRY_END=''
CAT_ENTRY_START=''
CC='gcc'
CCDEPMODE=''
CFLAGS='-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat =format-security -fstack-clash-protection -fcf-protection'
CPP=''
CPPFLAGS=''
CVS_BUILD_FALSE=''
CVS_BUILD_TRUE=''
CYGPATH_W='echo'
DEFS=''
DEPDIR=''
DOCBOOK_ROOT=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ENABLE_CONDUITS_FALSE=''
ENABLE_CONDUITS_TRUE=''
ENABLE_XSLTPROC_FALSE=''
ENABLE_XSLTPROC_TRUE=''
EXEEXT=''
F77=''
FFLAGS=''
FGREP=''
GREP=''
ICONV_CFLAGS=''
ICONV_LIBS=''
INCLUDED_POPT_FALSE=''
INCLUDED_POPT_TRUE=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
JAR=''
JAVA=''
JAVABASE=''
JAVAC=''
JAVA_VERSION=''
LD=''
LDFLAGS='-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now'
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIPO=''
LN_S=''
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/missing --run makeinfo'
MKDIR_P='/usr/bin/mkdir -p'
NM=''
NMEDIT=''
OBJDUMP=''
OBJEXT=''
OTOOL64=''
OTOOL=''
PACKAGE='pilot-link'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_URL=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
PIC_LIBS=''
PILOT_LINK_MAJOR='12'
PILOT_LINK_MINOR='5'
PILOT_LINK_PATCH=''
PILOT_LINK_VERS='0'
PISOCK_AGE='0'
PISOCK_CURRENT='9'
PISOCK_REVISION='2'
PISYNC_AGE='0'
PISYNC_CURRENT='1'
PISYNC_REVISION='3'
PKG_CONFIG=''
PNG_CFLAGS=''
PNG_LIBS=''
POPT_INCLUDES=''
POPT_LIBS=''
PTHREAD_CC=''
PTHREAD_CFLAGS=''
PTHREAD_LIBS=''
PYTHON=''
PYTHON_CFLAGS=''
PYTHON_H=''
PYTHON_LIBS=''
PYTHON_VERSION=''
RANLIB=''
RL_LIBS=''
SED=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TCLSH_PROG=''
TCL_BIN_DIR=''
TCL_DEFS=''
TCL_EXTRA_CFLAGS=''
TCL_INCLUDES=''
TCL_LD_FLAGS=''
TCL_LIBS=''
TCL_LIB_FILE=''
TCL_LIB_FLAG=''
TCL_LIB_SPEC=''
TCL_SHLIB_LD_LIBS=''
TCL_SRC_DIR=''
TCL_STUB_LIB_FILE=''
TCL_STUB_LIB_FLAG=''
TCL_STUB_LIB_SPEC=''
TCL_VERSION=''
VERSION='0.12.5'
WISH_PROG=''
WITH_BLUEZ_FALSE=''
WITH_BLUEZ_TRUE=''
WITH_DARWINUSB_FALSE=''
WITH_DARWINUSB_TRUE=''
WITH_FREEBSDUSB_FALSE=''
WITH_FREEBSDUSB_TRUE=''
WITH_JAVA_FALSE=''
WITH_JAVA_TRUE=''
WITH_LIBUSB_FALSE=''
WITH_LIBUSB_TRUE=''
WITH_LINUXUSB_FALSE=''
WITH_LINUXUSB_TRUE=''
WITH_PERL_FALSE=''
WITH_PERL_TRUE=''
WITH_PYTHON_FALSE=''
WITH_PYTHON_TRUE=''
WITH_TCL_FALSE=''
WITH_TCL_TRUE=''
WITH_USB_FALSE=''
WITH_USB_TRUE=''
XML_CATALOG=''
XSLTPROC=''
XSLTPROC_FLAGS=''
YACC=''
YFLAGS=''
ac_ct_CC='gcc'
ac_ct_DUMPBIN=''
ac_ct_F77=''
acx_pthread_config=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__include=''
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-pc-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='pc'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-pc-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='pc'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /var/tmp/pamac-build-barry/pilot-link/src/pilot-link-0.12.5/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
lt_ECHO='echo'
mandir='${datarootdir}/man'
mkdir_p='/usr/bin/mkdir -p'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/usr'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-pc-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='pc'
usb_libs=''
## confdefs.h. ##
/* confdefs.h */
configure: exit 77
