AUR Missing from add/remove software
AUR is missing from add/remove software, preferences and cannot find AUR, at least on my PC.
Can anyone please advise where/how to get it back?
It was quite useful and easy to install rtl wireless drivers for usb wifi dongles.
Go into the preferences of pamac and enable AUR support there
Also, make sure “Software Mode” is turned off or you won’t have the ability to choose AUR in Preferences.
Those preferences?
Sounds like a bug to me. :face_with_raised_eyebrow:
Would that be on purpose?
Sorry its not there. I know where it should be as I had done it several times already but after some update yesterday it is now gone.
OK, that worked, AUR is visible and is back.
Thanks for the help.
Yes that on purpose
