Running this command today and getting this output:
[I] sapo@accendino ~ (master)> pamac upgrade -a
Preparing...
Authenticating as: my name (sapo)
Password:
https://aur.manjaro.org/packages-meta-ext-v1.json.gz: Socket I/O timed out
Failed to synchronize AUR database
Nothing to do.
But wget downloads it correctly (I also tried browser and curl)
[I] sapo@accendino ~ (master)> wget https://aur.manjaro.org/packages-meta-ext-v1.json.gz
--2023-07-31 16:33:06-- https://aur.manjaro.org/packages-meta-ext-v1.json.gz
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving aur.manjaro.org (aur.manjaro.org)... 212.102.54.197, 2a02:6ea0:d500::7
Connecting to aur.manjaro.org (aur.manjaro.org)|212.102.54.197|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 10474598 (10,0M) [application/octet-stream]
Saving to: ‘packages-meta-ext-v1.json.gz’
packages-meta-ext-v1.json.gz 100%[==============================================>] 9,99M 11,2MB/s in 0,9s
2023-07-31 16:33:10 (11,2 MB/s) - ‘packages-meta-ext-v1.json.gz’ saved [10474598/10474598]
Is it possible to use the local copy to update the database while we get this timeout?
