Jakeo
28 March 2022 01:43
1
As title says when i try and use the aur helper my build just hangs up and at the very and i get (end) the terminal just hangs and i have to force close it. Any of the progams I try and install dont get installed. Any ideas as to what would be causing this
I am not sure but it looks like you are “proceeding to review” the PKGBUILD and don’t know how to exit then. Press n when asked :: Proceed to review? [Y/n]: or press q to exit when reviewed.
opened 11:06AM - 25 Feb 22 UTC
### Affected Version
**paru -V 1.9.3-1**
### System
**Artix-Linux Plasma Op… enRC**
### Description
**Paru stop working during upgrading AUR-packages**
##### Command
paru
### Output
system is up to date
world is up to date
galaxy is up to date
universe is up to date
omniverse is up to date
extra is up to date
community is up to date
there is nothing to do
:: Looking for AUR upgrades
:: Looking for devel upgrades
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
:: packages not in the AUR: kross-interpreters
:: marked out of date: masterpdfeditor-free
Aur (2) c++utilities-5.13.0-1 libpamac-aur-11.2.0-7
:: Proceed to review? [Y/n]: y
:: Downloading PKGBUILDs...
(1/1) libpamac-aur-11.2.0-7 [----------------------------------------------------------------------------------------------------------------------------------------------------------]
/home/tony/.cache/paru/clone/c++utilities/PKGBUILD
# Maintainer: Martchus <martchus@gmx.net>
# All my PKGBUILDs are managed at https://github.com/Martchus/PKGBUILDs where
# you also find the URL of a binary repository.
_reponame=cpp-utilities
pkgname=c++utilities
pkgver=5.13.0
pkgrel=1
arch=('i686' 'x86_64' 'armv6h' 'armv7h' 'aarch64')
pkgdesc='Common C++ classes and routines such as argument parser, IO and conversion utilities'
license=('GPL')
depends=('gcc-libs')
optdepends=("$pkgname-doc: API documentation")
makedepends=('cmake' 'ninja')
checkdepends=('cppunit')
url="https://github.com/Martchus/${_reponame}"
source=("${pkgname}-${pkgver}.tar.gz::https://github.com/Martchus/${_reponame}/archive/v${pkgver}.tar.gz")
sha256sums=('6ddca61b4ff38785a927eb5e2491e2edbf00eb8d003360f46f247cbb18eab970')
prepare() {
cd "$srcdir/${PROJECT_DIR_NAME:-$_reponame-$pkgver}"
build() {
cmake \
-G Ninja \
-DCMAKE_BUILD_TYPE:STRING='Release' \
-DCMAKE_INSTALL_PREFIX:PATH='/usr' \
-DBUILD_SHARED_LIBS:BOOL=ON \
ninja
check() {
ninja check
package() {
DESTDIR="${pkgdir}" ninja install
/home/tony/.cache/paru/clone/libpamac-aur/fix-appstream-data.hook
[Trigger]
Operation = Install
Operation = Upgrade
Type = Path
Target = usr/share/app-info/xmls/*.xml.gz
# attention: hook name before: update-appstream-cache.hook
[Action]
Description = fix appstream datas for pamac
When = PostTransaction
Depends = gzip
Exec = /etc/pacman.d/hooks.bin/fix-appstream-data.sh
NeedsTargets
/home/tony/.cache/paru/clone/libpamac-aur/fix-appstream-data.sh
#!/bin/bash
tmp="/tmp/fix-appstream-data"
while read -r archive; do
if [[ $(zcat "${archive}" | grep -cm1 '<em>') == "1" ]]; then
zcat "${archive}" | sed 's|<em>||g;s|<\/em>||g;' | sed 's|<code>||g;s|<\/code>||g;'| gzip > "${tmp}"
cp "${tmp}" "${archive}"
rm "${tmp}"
echo " archive ${archive} fixed"
fi
done
/home/tony/.cache/paru/clone/libpamac-aur/PKGBUILD
# Contributor: Zeph <zeph33@gmail.com>
# Maintainer: Zeph <zeph33@gmail.com>
# https://gitlab.manjaro.org/packages/extra/libpamac
ENABLE_FLATPAK=0
ENABLE_SNAPD=0
pkgname=libpamac-aur
pkgver=11.2.0
pkgrel=7
_pkgfixver=$pkgver
_commit='c11324de9e5615f2947f09e2c4d6de00e59e5ff3'
sha256sums=('1e32d68ccc2874192b6b7ada333b685ab345a69e1e8fbe72acca5ffad6a0e03f'
'6e0c25f0fcb0076ce78845b037e32925fcc3f1cd1670062c48ed35f564a10244'
'c2b943318a01ba1f3dabbf32e48e6a6f4b4b774e167ab86c6bfee31aa4a3424c')
pkgdesc="Pamac package manager library based on libalpm"
arch=('i686' 'x86_64' 'arm' 'armv6h' 'armv7h' 'aarch64')
url="https://gitlab.manjaro.org/applications/libpamac"
license=('GPL3')
depends=('glib2>=2.42' 'json-glib' 'libsoup' 'dbus-glib' 'polkit' 'vte3>=0.38'
'libnotify' 'pacman>=6.0' 'pacman<6.1' 'gnutls>=3.4' 'git'
'appstream-glib>=0.7.18-1' 'archlinux-appstream-data' 'git')
makedepends=('gettext' 'itstool' 'vala>=0.46' 'asciidoc' 'meson' 'ninja' 'gobject-introspection')
backup=('etc/pamac.conf')
conflicts=('libpamac' 'libpamac-all')
provides=('libpamac')
options=(!emptydirs !strip)
install=pamac.install
source=("libpamac-$pkgver-$pkgrel.tar.gz::$url/-/archive/$_commit/libpamac-$_commit.tar.gz"
fix-appstream-data.sh fix-appstream-data.hook)
define_meson=''
if [ "${ENABLE_FLATPAK}" = 1 ]; then
depends+=('flatpak')
define_meson+=' -Denable-flatpak=true'
fi
if [ "${ENABLE_SNAPD}" = 1 ]; then
depends+=('snapd' 'snapd-glib')
define_meson+=' -Denable-snap=true'
fi
prepare() {
cd "$srcdir/libpamac-$_commit"
# adjust version string
sed -i -e "s|\"$_pkgfixver\"|\"$pkgver-$pkgrel\"|g" src/version.vala
build() {
mkdir -p builddir
cd builddir
meson setup --buildtype=release \
--prefix=/usr \
--sysconfdir=/etc $define_meson
# build
meson compile
package() {
cd "$srcdir/libpamac-$_commit/builddir"
DESTDIR="$pkgdir" ninja install
# fix appstream issue
install -Dm644 "$srcdir/fix-appstream-data.hook" "$pkgdir/etc/pacman.d/hooks/fix-appstream-data.hook"
install -Dm755 "$srcdir/fix-appstream-data.sh" "$pkgdir/etc/pacman.d/hooks.bin/fix-appstream-data.sh"
# vim:set ts=2 sw=2 et:
/home/tony/.cache/paru/clone/libpamac-aur/.gitignore
*.gz
*.tar
*.tar.*
/pkg/*
/src/*
/home/tony/.cache/paru/clone/libpamac-aur/pamac.install
msg() {
ALL_OFF="\e[1;0m"
BOLD="\e[1;1m"
GREEN="${BOLD}\e[1;32m"
local mesg=$1; shift
printf "${GREEN}==>${ALL_OFF}${BOLD} ${mesg}${ALL_OFF}\n" "$@" >&2
restore_conf() {
PAMAC_NEW="$(date +%m%d%M%S)"
if [ -f "/etc/pamac.conf.pacsave" ]; then
msg "You had an old /etc/pamac.conf.pacsave file. We restore it for you."
msg "You can find your new pamac.conf saved as \`/etc/pamac-new-${PAMAC_NEW}.conf\`"
mv /etc/pamac.conf /etc/pamac-new-${PAMAC_NEW}.conf
mv /etc/pamac.conf.pacsave /etc/pamac.conf
fi
post_install() {
# enable flatpak repo
if [ -f /usr/bin/flatpak ]; then
flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
fi
# enable systemd timers
mkdir -p /etc/systemd/system/timers.target.wants
ln -sf /usr/lib/systemd/system/pamac-cleancache.timer /etc/systemd/system/timers.target.wants/pamac-cleancache.timer
# restore old conf
restore_conf
post_upgrade() {
fi
# restore old conf
if [ "$(vercmp $2 7.3.5-3)" -lt 0 ]; then
restore_conf
fi
if [ "$(vercmp $2 8.0.3-5)" -lt 0 ]; then
# remove wrong placed symlinks
msg "Updating timer symlinks"
[[ -e /etc/systemd/system/multi-user.target.wants/pamac-cleancache.timer ]] && rm -f /etc/systemd/system/multi-user.target.wants/pamac-cleancache.timer
# [[ -e /etc/systemd/system/multi-user.target.wants/pamac-mirrorlist.timer ]] && rm -f /etc/systemd/system/multi-user.target.wants/pamac-mirrorlist.timer
# ln -sf /usr/lib/systemd/system/pamac-mirrorlist.timer /etc/systemd/system/timers.target.wants/pamac-mirrorlist.timer
fi
post_remove() {
# disable systemd timers
rm -f /etc/systemd/system/timers.target.wants/pamac-cleancache.timer
# rm -f /etc/systemd/system/timers.target.wants/pamac-mirrorlist.timer
(END)
### Note-s
**downloading packages from github with `git clone...` and install them with `makepkg -si` works **
I had the very same situation, and this was the answer for me:
Start the installation with paru -S <your_pkg>
After the download roll down till the (END)
Press Q
Select proceed with instalation Y/n
Should have installed
I hope that work for you.
