suddenly I broke my headphone. so I was using AudioRelay software to sync sounds between my android device & pc(windows). that means… my android phone working as my computer sound system.
I just leave garbage windowsOS forever … basically I watch tutorials on my pc but now,I can’t find any linux version of AudioRelay
is there any way to do the same thing with manjaro with android?
There’s an early version of AudioRelay for Linux. It’s available in the forum but I can’t post any link here.
To try it, go to AudioRelay’s webpage → Click on forum → Announcements → Check the latest version.
(I’m the dev of AudioRelay)
Let me help a bit
Will also talk with the moderators if is the case to add you to contributors, so you can do more in this forum when and if you come back.
Update:
@Asapha - you are now Contributor with Trust Level 3.
Enjoy Manjaro forum and thanks for getting involved.
Welcome to the forum!
I’ve used your Purchased Apps Android app before.
I’ve added it to the AUR, let me know if you’d like to help maintain it: audiorelay
