Audio Volume keeps resetting to 100%
Every time I open any app it resets said app volume to 100%, every time any of my audio/video players switch to next file in playlist their volume also goes to 100%
  Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=e4975a60-729d-4320-8313-56fb80924cdd rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=46046209-d15d-44ca-9b63-4d9394d59367 udev.log_priority=3
  Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE V2 v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F13
    date: 07/08/2021
  RAM: total: 31.36 GiB used: 12.87 GiB (41.0%)
  RAM Report:
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3729 high: 4131 min/max: N/A cores: 1: 3693 2: 3693
    3: 3693 4: 3693 5: 3693 6: 3693 7: 3693 8: 4131 9: 3693 10: 3693 11: 3693
    12: 3693 bogomips: 88678
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: NVIDIA GK208B [GeForce GT 720] vendor: Micro-Star MSI
    driver: nvidia v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 1
    speed: 2.5 GT/s lanes: 2 link-max: gen: 2 speed: 5 GT/s lanes: 8
    bus-ID: 03:00.0 chip-ID: 10de:1288 class-ID: 0300
  Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI
    driver: nvidia v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 05:00.0 chip-ID: 10de:1b81 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
    s-diag: 693mm (27.3")
  Monitor-1: HDMI-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
    diag: 686mm (27")
  OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
    v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
  Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 2
    link-max: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 10de:0e0f
    class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 05:00.1 chip-ID: 10de:10f0 class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.47 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
  Local Storage: total: 1.88 TiB used: 634.16 GiB (32.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100
    type: HDD rpm: 7200 serial: <filter> rev: A750 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
    model: DataTraveler 2.0 size: 28.87 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
  ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Generic
    model: STORAGE DEVICE size: 7.4 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 1532 scheme: MBR
  ID-1: / raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
    used: 23.34 GiB (26.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: e4975a60-729d-4320-8313-56fb80924cdd
  ID-2: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%)
    used: 568 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: NO_LABEL
    uuid: 3734-6F75
  ID-3: /home raw-size: 826.97 GiB size: 826.97 GiB (100.00%)
    used: 607.42 GiB (73.5%) fs: btrfs dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 181b75b2-a58a-4401-992c-d4e9f9793f89
  ID-4: /run/media/wilkogryf/MJUZIK raw-size: 28.87 GiB
    size: 28.86 GiB (99.95%) used: 3.41 GiB (11.8%) fs: vfat dev: /dev/sdc1
    maj-min: 8:33 label: MJUZIK uuid: 3793-2E18
  ID-5: /var/cache raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
  ID-6: /var/log raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.11 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 46046209-d15d-44ca-9b63-4d9394d59367
  ID-1: /dev/sdb1 maj-min: 8:17 size: 914.34 GiB fs: ext4 label: N/A
    uuid: 4e5332b0-cc41-47b3-9a6f-79bfa7a51995
  ID-2: /dev/sdb2 maj-min: 8:18 size: 17.17 GiB fs: swap label: N/A
    uuid: 4933b910-f99a-424e-a91e-926f277f5b1c
  ID-3: /dev/sdd1 maj-min: 8:49 size: 28.87 GiB fs: vfat label: PENDRAJW
    uuid: 41C0-0F4C
  ID-4: /dev/sde1 maj-min: 8:65 size: 7.4 GiB fs: vfat label: XACTI
    uuid: N/A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-1:2
    info: Toshiba TransMemory-Mini / Kingston DataTraveler 2.0 Stick
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 200mA chip-ID: 0930:6544 class-ID: 0806
    serial: <filter>
  Device-2: 1-2:3
    serial: <filter>
  Hub-2: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-7:5 info: Integrated Express ITE Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-9:6 info: Genesys Logic SD Card Reader and Writer
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
    speed: 480 Mb/s power: 500mA chip-ID: 05e3:0749 class-ID: 0806
    serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
    serial: <filter>
  Device-2: 3-4:3 info: ROCCAT Vulcan 100 AIMO type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 1e7d:307a class-ID: 0300
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 41.0 C mobo: 39.0 C gpu: nvidia temp: 83 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 82%
  Processes: 409 Uptime: 2h 13m wakeups: 0 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1433
  pacman: 1404 lib: 366 flatpak: 13 snap: 16 Shell: Zsh v: 5.8.1 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.13
How do I fix this?
have you tried to install and use ‘pavucontrol’ ?
It says it’s for PulseAudio and I’m using pipewire, is this a problem or should I try anyway?
you can try it anyway. doesn’t matter if pulse or pipe
Does not help, audio volume keeps resetting
I replaced PulseAudio with Pipewire a few weeks ago to see if it solved my audio glitch issue (which it mostly did with some tweaking), and I could reproduce this behavior on my end by running paplay --volume and pw-play --volume on a random sound file. It appears that something in Pipewire is ignoring the command’s initial volume request, so it would play at 100% volume every single time I run either command.
Note that with the manjaro-pulse metapackage installed, the “pa” commands are still present in the system to maintain compatibility with existing apps and scripts that use them.
Hi
I have the same problem. Any solution to this?
