I have a mic issue where I like the gain at 65% (just perfect), but the audio subpanel auto-adjusts it higher which leads crackeling over the mic and my voice is over exposed in the signal. (the slider for the mic auto adjusts higher than I want it to).
Is there any way to stop it from doing this? I’ve recorded myself in OBS and I sound just fine on 65%, but the system has other plans when it hears me
Pulseaudio only adjusts the mic is module-echo-cancel is loaded and it is not your saying.
Zoom also adjust the mic but only if auto adjust is enabled, but it is disabled your saying.
So all you can do is kinda force it off. You have to edit some config files for this to disable it for every mic you use or tent to use.
In /usr/share/pulseaudio/alsa-mixer/paths/ you need to edit all configs with mic in it with the exception of analog-input-mic.conf.common
and set volume = merge to volume = zero
Within these configs you need to set this for: [Element Capture] and [Element Mic Boost] including all variations like [Element Internal Mic Boost]
