I am on testing branch with pipewire-pulse
. Earlier I was using wireplumber
but moved back to pipewire-media-session
due to a bug that caused clementine
to go silent after seeking.
Now I am experiencing this very weird bug that when I open up the volume control widget the audio stutters but only as long as the widget is open.
On top of that this bug interacts with the bug in clementine I mentioned above such that when volume widget is opened the audio comes back but with the usual stuttering.
opened 12:39AM - 27 Nov 21 UTC
### Before posting
Please follow the steps below and check the boxes with [x]… once you did the step.
- [ x ] I checked the issue tracker for similar issues
- [ x ] I checked the [changelog](https://github.com/clementine-player/Clementine/blob/master/Changelog) if the issue is already resolved
- [ x ] I tried the latest Clementine build from [here](https://builds.clementine-player.org/)
### System information
Please provide information about your system and the version of Clementine used.
- Operating System: Fedora 35 MATE
- Clementine version: clementine-1.4.0-7.rc1.20210104git479f1d4.fc35.3.x86_64 from Fedora's repository and also clementine-1.4.0rc1-2.762.g590ab22f8.fc35.x86_64.rpm downloaded from Clementine's GitHub releases: https://github.com/clementine-player/Clementine/releases/tag/1.4.0rc1-762-g590ab22f8
### Expected behaviour / actual behaviour
Seeking through a track, whether with the mouse or keyboard shortcuts, sometimes causes the playback to go silent or stutter. Other times it plays as normal. It seems unpredictable, but the problem occurs frequently.
### Steps to reproduce the problem (only for bugs)
1. Play a track
2. Seek forward or backwards within the track, with mouse or keyboard shortcuts
3. Repeat step 2 if problem is not observed immediately
Bugzilla report: https://bugzilla.redhat.com/show_bug.cgi?id=2027016
Seeking was tried on different audio files and it is not isolated to a specific file or type.
Also, seeking was tried with other media players such as VLC and SMPlayer which do not exhibit the problem to rule out a system-wide audio issue.
