~ lspci -v ✔
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge - DMI (rev 0a)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7924
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation Broadwell-U PCI Express x16 Controller (rev 0a) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: f6000000-f70fffff [size=17M] [32-bit]
Prefetchable memory behind bridge: e0000000-f1ffffff [size=288M] [32-bit]
Kernel driver in use: pcieport
00:14.0 USB controller: Intel Corporation 9 Series Chipset Family USB xHCI Controller (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 31
Memory at f7400000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 9 Series Chipset Family ME Interface #1
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f7419000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 9 Series Chipset Family USB EHCI Controller #2 (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f7417000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 9 Series Chipset Family HD Audio Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Device d924
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at f7410000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 1 (rev d0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: [disabled] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
00:1c.2 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 3 (rev d0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: f7300000-f73fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: f2100000-f21fffff [size=1M] [32-bit]
00:1c.3 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 4 (rev d0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: f7200000-f72fffff [size=1M] [32-bit]
00:1c.4 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 5 (rev d0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: f7100000-f71fffff [size=1M] [32-bit]
00:1d.0 USB controller: Intel Corporation 9 Series Chipset Family USB EHCI Controller #1 (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7416000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation Z97 Chipset LPC Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 9 Series Chipset Family SATA Controller [AHCI Mode] (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 30
I/O ports at f070 [size=8]
I/O ports at f060 [size=4]
I/O ports at f050 [size=8]
I/O ports at f040 [size=4]
I/O ports at f020 [size=32]
Memory at f7415000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 9 Series Chipset Family SMBus Controller
Flags: medium devsel, IRQ 18
Memory at f7414000 (64-bit, non-prefetchable) [size=256]
I/O ports at f000 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3060 Ti Lite Hash Rate] (rev a1) (prog-if 00 [VGA controller])
Subsystem: eVga.com. Corp. Device 4663
Flags: bus master, fast devsel, latency 0, IRQ 35
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f7080000 (32-bit, non-prefetchable) [size=16K]
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Flags: bus master, fast devsel, latency 0, IRQ 18
I/O ports at d000 [size=256]
Memory at f7300000 (64-bit, non-prefetchable) [size=4K]
Memory at f2100000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 Network controller: Qualcomm Atheros AR93xx Wireless Network Adapter (rev 01)
Subsystem: Qualcomm Atheros Device 3112
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at f7200000 (64-bit, non-prefetchable) [size=128K]
Expansion ROM at f7220000 [disabled] [size=64K]
Kernel driver in use: ath9k
Kernel modules: ath9k
05:00.0 Audio device: C-Media Electronics Inc CM8888 [Oxygen Express]
Subsystem: C-Media Electronics Inc HDA Controller
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f7100000 (32-bit, non-prefetchable) [size=16K]
