I recently switching from PulseAudio to PipeWire, and now audio is sporadically cutting out (every 5-25 seconds for ~10 seconds). If I have pavucontrol open, the bar indicating signal continues to move up and down while the audio cuts out.
I have tested with a couple applications and the issue persists.
inxi output:
Kernel: 5.4.212-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3a03c4a2-398d-49f8-90f8-b98c30a6924f rw loglevel=3 quiet
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: P8P67 PRO REV 3.1 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3602
date: 11/01/2012
RAM: total: 11.67 GiB used: 4.51 GiB (38.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-2500K bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2001 high: 2134 min/max: 1600/3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2034 2: 1916 3: 2134
4: 1920 bogomips: 26497
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
disabled
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 02:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia gpu: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 1-1:2
bus-ID: 00:1b.0 chip-ID: 0d8c:0014 chip-ID: 8086:1c20 class-ID: 0300
class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 02:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.4.212-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: 3.2.6-k port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
Device-1: ASUSTek Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 5-1.7:3 chip-ID: 0b05:179c class-ID: e001
Local Storage: total: 1.14 TiB used: 268.46 GiB (23.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2500BEVS-26VAT0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A11 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD5000AAKX-00U6AA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15
scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-222AL rev: SB01
dev-links: cdrom
ID-1: / raw-size: 452.62 GiB size: 444.44 GiB (98.19%) used: 268.44 GiB
(60.4%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 3a03c4a2-398d-49f8-90f8-b98c30a6924f
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 25.6 MiB
(8.5%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A uuid: D2B3-32CC
ID-1: swap-1 type: partition size: 12.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: d48a531e-1486-45c0-86cb-006940745ad3
ID-1: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: ntfs label: poop
uuid: 2E38355F6C108E76
ID-2: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb2 maj-min: 8:18 size: 465.22 GiB fs: ntfs label: N/A
uuid: A820EBF020EBC402
ID-4: /dev/sdb3 maj-min: 8:19 size: 531 MiB fs: ntfs label: N/A
uuid: D6FE9B07FE9ADED5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: C-Media Audio Adapter (Unitek Y-247A)
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0014 class-ID: 0300
Device-2: 1-2:3 info: Razer USA Pro Click type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0077 class-ID: 0300
Hub-2: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-4: 3-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-5: 4-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 4-1:2 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:0159 class-ID: 0300
Hub-6: 5-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-7: 5-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 5-1.7:3 info: ASUSTek Bluetooth Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 62 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 7%
Processes: 217 Uptime: 35m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1526 libs: 391 tools: pamac,yay Shell: Bash
v: 5.1.16 running-in: urxvtd inxi: 3.3.21
Any suggestions on things to try to stop the audio cutting out, or a command I can run to get more real-time information?
